    [Plugin] Remove Inner Faces
    23 Posts 15 Posters 32.0k Views 15 Watching
    • E Offline
      EA-d
      Does exist a ruby script for kill the internal surfaces but not the edges of these surfaces (after a Pushpull + Ctrl for example)?
      [/attachment]
      How about one for killing external surfaces, after an intersection of multiple groups, when forming internal models only (eg for export for light or acoustic modelling)? I'd like to place a marker (or the camera) inside my room and have a plugin automatically trim and delete any surfaces not reachable from that point. Sort of like doing a blow-mould!
      Would be very handy!
      • irwanwrI Offline
        irwanwr
        merci monsieur Pilou 👍
        and wikii of course 😄
          Lain Iwakura
          wikii, thank u very much. Great tool for retop.
            Seems you have this result with a blender of normal selections (right to left, left to right), Inverse Selection by Tig, Selection Toys by Thomthom...
              j_forrester
              Hi Guys,
              Just a quick one.
              Does this still work for Skecthup 2016? I have re-named the zip folder extension to ".rbz" hoping this would install it correctly. I says it did install but i cant seem to see it anywhere in the menus? Any help would be very much appreciated.
                glro
                @j_forrester said:
                Hi Guys,
                Just a quick one.
                just put this file in your plugins folder
                remove inner faces
                  j_forrester
                  @glro said:
                  @j_forrester said:
                  Hi Guys,
                  Just a quick one.
                  Thank you very much, worked perfectly!
                  • PixeroP Offline
                    Pixero
                    Just a side note.
                    Sdmitch made a script for me that works like ctrl+pushpull without creating inner faces.
                    It seems he hasn't released it publicly but you could perhaps ask him to release it if interested.
                      blusben11
                      I get this:
                      Error Loading File remove_inner_faces.rb
                      Error: #<NoMethodError: undefined method file_loaded?' for main:Object> D:/Program Files/SketchUp/SketchUp 2015/Tools/remove_inner_faces.rb:23:in <top (required)>'
                      Thanks in advance
                      • iichiversiiI Offline
                        iichiversii
                        This plugin hasn't worked for sometime, its a shame as it really helped me out a lot, is there any plans in updating this or is there any alternative plugin that does the same?
                        Bring on the Rain...
                          TBoy
                          Solid Inspectorby thomthom will do the job.
                          F 1 Reply Last reply Reply Quote 0
                          • F Offline
                            FelipiFalcao @TBoy
                            Perfect!
                            • 2 / 2
