    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Create groups of instances correctly
    8 Posts 3 Posters 506 Views 3 Watching
      dacastror
      Hi all, I want to create a new group and place inside group or component with previously created in sketchup. I have observed that writing .Add_group(component) or .Add_group(group) may cause bug splats.. I do not know how to do this properly, Thanks in advance for your help
      (google translator)
      • Dan RathbunD Offline
        Dan Rathbun
        See this snippet example: [Code] encapsulate instance into group
        The error that was causing BugSplats was supposed to be fixed in v8.
        I'm not here much anymore.
          You should use gp=entities.add_group()
          Then immediately gents=gp.entities
          then add things to the ' gents'...
          The only time you can add a group specifying its contents directly is if you are SURE that the contents are in the sane context as the group itself.
          It you 'cross-thread' context and entities you get splats...
          If you manually select some items and then 'group' them then that group is in the same context as the items selected - you cannot manually select items across different contexts...
          Similarly in code, you can only add items to a group directly IF they are BOTH in the active_entities context...
          So this will work:
          model=Sketchup.active_model ss=model.selection gp=model.active_entities.add_group(ss.to_a)
          BUT this MIGHT fail if the model.entities != model.entities
          model=Sketchup.active_model ss=model.selection gp=model.entities.add_group(ss.to_a)
          The selection might NOT be in the model.entities context.
          However, since a [manual] selection is always in the active_entities, it might be safe.
          A foolproof way would be:
          ss=model.selection
          gp=ss[0].parent.entities.add_group(ss.to_a)[/ruby]
          Just THINK what you are coding šŸ˜’
            dacastror
            thank you very much Dan and TIG this information is exactly what I needed šŸ˜„
              dacastror
              Unfortunately I have to perform the task outside the active context for what I'm going to use the method proposed by Dan, but I think you need to add the following properties;
              material, attribute_dictionaries, layer, description, entity_name, name, receives_shadows, casts_shadows
              I wonder if there are more properties that can be inherited by the new instance
              (google translator)
                material ?
                  dacastror
                  Yes, if the user has applied a material without opening the instance, the material is assigned to the instance and not to the faces, then it would seem that after executing the code, the object has lost color
                    Dan Rathbun
                    @dacastror said:
                    ... Dan, but I think you need to add the following properties;
                    (google translator)
                    Yes you are correct. Just before the old instance is deleted, it's properties need to be copied over to the new instance.
