    Plugins folder
    3 Posts 3 Posters 308 Views 3 Watching
      jerrymich
      Probably a silly question, but where is the plugins folder in sketchup 2014? Or, how do you install files that are in a zipped folder. I have done this before in 2013 with no issues.
      thanks, Jerry
      • micioneM
        micione
        It has a new place:
        Username/AppData/Roaming/Sketchup2014/Sketchup/Plugins
        But look on the forum SketchUp
        and you will find indications.
        • BoxB
          The best thing to do is install the Sketchucation Plugin store which you can do without even knowing where the plugin folder is. Download it from the link at the top of the page and install it using Window/Preferences/Install Extension
          Then once you have that you can download all your plugins fresh and updated. There is even an addon to the plugin tool (easily auto installed via the tool itself) that will open your plugin folder for you.
          The other main option is to use the Extensions Warehouse which you will find within Sketchup, Window/Extension Warehouse.
          Once you get going with those any manual installs you might want to do you can do by clicking the Open Plugins Folder from the Sketchucation submenu.
          It is strongly recommended that you install new plugins rather than copying your old ones across.
