    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] GKWare Door Maker
    46 Posts 10 Posters 8.7k Views 10 Watching
    • OxerO Offline
      Oxer
      Thanks for the plugin!!
      I have created the Spanish Language file.
      Spanish Language
        Garry K
        I am now working on the "pro" version of door maker.
        New menu items
        1. Add Edge Profile
        2. Add Panel Raise profile
        3. Add Handle
        New input values / drop downs
        1. Handle Style including "None"
          128 mm bar pul
          96 mm wire pull
          96 mm flat bar pull
          Round knob
        2. Handle location drop down possibilties:
          Top Left
          Top Center
          Top Right
          Center
          Bottom Left
          Bottom Center
          Bottom Right
        3. Handle Offset input value
        4. Front Edge profile drop down default values include:
          None
          Round over
          Bead
          Chamfer
          Cupboard
        5. Back Edge profile drop down default values include:
        6. Panel profile drop down default values include:
          Cove with bead
          Cove with ogee
          Cove with slant
          Slant with bead
          Slant with ogee
          Slant with slant
          Ogee with bead
          Ogee with ogee
          Ogee with slant
        7. Lower Rail height input value
        8. Lowest Panel height input value
        • KrisidiousK Offline
          Krisidious
          Looks great Garry...
          By: Kristoff Rand
            Garry K
            You will also be able to add door handles and pulls into the gkware_doormaker/handles folder and they will appear in the drop down list of handles.
            You will get 1 skp file with Edge profiles and 1 skp file as panel profiles. You can add more profiles and use the Add Edge Profiles button or Add Panel Profiles button. This will go through the geometry and add a file into the appropriate folder. The entries will then appear in the various drop down lists.
            These are examples of the supplied edge profiles.
            The one marked "Cupboard" is designed for the old style American Face Frame construction complete with a 10 mm x 10 mm rabbet. This can be accomplished by choosing "inlay" and by setting the gap to 8 mm and the protrusion to 12 mm.
            • MacG333M Offline
              MacG333
              Thanks for the plugin! Very nice and complete.
              I have created the italian language file.
              I hope you helpful.
              it.lang
              • unclebimU Offline
                unclebim
                Very nice options! Adding some more profiles and handles is very useful too, e.g. many customers want longer handles.
                What would be the pricing for the pro version of your DoorMaker plugin?
                  Krisidious
                  You'll be able to add profiles and handles to the library as you wish and I think the price will be between $10-$20US. Not sure though.
                  By: Kristoff Rand
                    Garry K
                    Kristoff is correct. That is the range for the pricing for the Door Maker Pro.
                    Here is the Input Box for Door Maker Pro.
                    If anyone has suggestions or comments - now is the time to start talking.
                    Door Maker Pro InputBox
                    Some InputBox terms
                      Krisidious
                      I can't think of anything I would add Garry...
                      By: Kristoff Rand
                      • unclebimU Offline
                        unclebim
                        It all looks great.
                        Something about the materials though. The textures provided with the DoorMaker plugin so far are not seamless and . I made a quick seamless version of the images provided within the images subfolder in the .rbz file and you may find them attached. Some don't look good but the source texture file has too little of the wood grain. If you need some assistance with the textures I would be happy to help.
                        Besides the applied material's size is too large for the most of the materials.
                        One more issue: I am missing some style of the doors referring to your manual, what am I doing wrong:
                        images1.zip
                        images2.zip
                          Garry K
                          To get your missing doors it is actually quite simple.
                          All you need to do is adjust the thickness of the panel.
                          Change it to something like 6 mm. What the code does is for any panel that is 15 mm or thicker it brings the panel face flush with the stiles and rails. Any panel that is thinner than 15 mm it puts it behind the bead and drops the cove cutter (no panel raise).
                          And of course I would love to learn more about textures.
                          I pulled most of these from here:
                          http://www.fritz-kohl.de/en/preview-veneers.28.0.0.0.0.html
                          Here are a couple of other interesting places to look for wood grain patterns:
                          http://www.woodmagazine.com/materials-guide/lumber/wood-grain-textures/
                          http://forums.sketchucation.com/viewtop ... lit=madhav
                          http://www.veneeronline.com/species.asp ... ory=lwdbdl
                          Perhaps you noticed the textures.txt file. It contains the name of the texture a coma and the length. So I'm assuming you want to play around with this number - I just set it to 36 for all textures.
                          The required _ver is because I used to carry vertical and horizontal patterns. I was able to drop the horizontal one but the _ver is still there for backwards compatibility.
                            Garry K
                            The pro version is in final testing. Here are some doors that can be made along with a sketchup file that I've used to create these profiles.
                            Keep the geometry simple. Arcs are 3 to 5 segments. Straight lines are not divided.
                            When you are happy with a profile just select the face and click the new "Add Profile" button. Select which profile group and give the new profile a name. We simply add a txt file into 1 of the 4 profile group folders.
                            The next time you run Door Maker Pro - the profile will be in the drop down list.
                            Here is the contents of gkware_doormaker/panel profiles/Ogee.txt
                            0.000000,0.342090
                            0.000000,0.000000
                            1.181102,0.000000
                            1.181102,0.078740
                            1.069553,0.087210
                            0.960561,0.112427
                            0.856627,0.153812
                            0.760133,0.210415
                            0.663639,0.267019
                            0.559705,0.308404
                            0.450714,0.333620
                            0.339164,0.342090
                            New Doors Pro version
                            Door Profiles
                            Door Profiles sketchup file
                              Krisidious
                              Awesome Garry...
                              By: Kristoff Rand
                                Garry K
                                Door Maker Pro lets you build passage doors. Just set the Stile Width to say 4-5 inches and set the Bottom Rail to 8-10 inches. You can set it to what ever you want.
                                Some of these examples make use of the new "Glass Combo" choice where the Top Panel is glass and the other panel(s) are your door material.
                                Also notice that doors that are >= 30 mm thick have the panel raise and moulding on both sides.
                                Door Section
                                Passage Doors
                                • marsahlM Offline
                                  marsahl
                                  Thanks for the great plugin!! šŸ‘ šŸ‘
                                  I have created the German Language file.
                                  German language file
                                  • marsahlM Offline
                                    marsahl
                                    Hey Garry, my translation file is German language, not Italien...
                                      Garry K
                                      Sorry - I knew that - it was a copy and paste error !!
                                        Garry K
                                        Here is the new web interface for the Door Maker plugin.
                                        I am looking for a few testers for Mac and Windows 8.
                                        There are a few advantages that web dialog brings to the plugin.
                                        • Web dialog takes less room.
                                        • Open help file directly from web dialog.
                                        • A few of the inputs now have tool tips (captions in red).
                                        • Options now grouped a bit more intuitively.
                                        • Some options now interact with each other. Change handle location and 'Click Action' automatically changes. You can override the 'Click Action' when you need to.
                                          BdhSdfCr
                                          Just downloaded and installed Doormaker using the Sketchucation plugin store auto install and the dialog box will not come up. (Running SkecthUp 2014 on a a Mac OSX 10.9.4). Uninstalled the plugin and did a direct download from the Sketchucation website and installed the plugin through the preferences window and have the same problem. Here is what the dialog box reports when using auto install...
                                          gkware_doormaker_v1.0.30
                                          AutoInstall Finished.
                                          Using Main Plugins Folder.
                                          /Users/b-d-hayes/Library/Application Support/SketchUp 2014/SketchUp/Plugins
                                          I can select Door Maker from the Plugins menu and the sketch up script tells me to "select first corner of door" I do this then select a diagonal point and I get what looks like an arched top panel only, no styles or rails.
                                            Garry K
                                            Can you start a new session and run be ruby console prior to running the door maker? Also, I do write information to the gkware_doormaker\config folder - so you need to have rights to that folder.
                                            I don't have mavericks - I run Windows 7 OS. I can give you a stripped down version that just pops up a web dialog box if that will help figure out the problem.
                                            • 3 / 3
