    • Anmelden
    [Plugin] GKWare Door Maker
    Geplant Angeheftet Gesperrt Verschoben Plugins
    46 Beiträge 10 Kommentatoren 8.6k Aufrufe 10 Watching
    Lade mehr Beiträge
    • Älteste zuerst
    • Neuste zuerst
    • Meiste Stimmen
    Antworten
    • In einem neuen Thema antworten
    Anmelden zum Antworten
    Dieses Thema wurde gelöscht. Nur Nutzer mit entsprechenden Rechten können es sehen.
      pomelo3d
      zuletzt editiert von
      as is download?
      1 Antwort Letzte Antwort Antworten Zitieren 0
        Garry K
        @guanjin said:
        1.0.18Not work well in sketcup2014, click on the toolbar icon, you can not open the dialog box.
        You are right - 1.0.18 does not work with SU 2014
        I uploaded version 1.0.19 to Plugin Stores this morning.
        • guanjinG Offline
          guanjin
          @pomelo3d said:
          as is download?
          Activation Tool,No selection dialog。
            Garry K
            Is this SU 2014 and 1.0.19 on Windows??
            • guanjinG Offline
              guanjin
              Thank you, have a private letter to you 👍
              • KrisidiousK Offline
                Krisidious
                Drag option seems to put drawer on backwards starting from bottom right dragging to top left. all other start points put drawer off to sides.
                can I 'select the area' make doors or drawers.
                Ability to select lines while in menu to read entity info.
                By: Kristoff Rand
                  Garry K
                  There are 3 drag options - All work from bottom left to bottom top.
                  The bottom left hand corner of the door / drawer is based on the first point chosen.
                  If you bottom right hand corner then top left hand corner then the door will be place backwards as if you are on the other side of the cabinet.
                  I'm not sure what you are asking?
                    Krisidious
                    got it. a note to that effect in the info text on the bottom might be good.
                    like "pick bottom left corner"
                    these are two different questions...
                    Can I 'select the area' make doors or drawers. I draw cabinets out or use my stock base and upper units, then I decide things per project like drawer fronts and tolerances. as you see in the screen grab If I could select a face I want to be drawer or door that would be awesome.
                    If I can't select a face and make it a drawer or door, then it would be nice if when I forget to find out what the size of door and drawer fronts are, I could click out side the menu, back in the model, while leaving the menu open. A few plugins do this, most don't.
                    By: Kristoff Rand
                      Garry K
                      Good idea! I will add this to my "to do" list for next version. It would also be simple to let user pick top left hand corner and then bottom right hand corner.
                      I think what you are asking is for a different interface where you pre select 1 or more face, bring up menu, set up tolerances and select door, drawer etc. Then click "OK" and convert ( delete and replace ) the faces with the door / drawer.
                      This would mean for each face I would have to detect which side is in and which side is out otherwise doors / drawers could be put on backwards. What happens if the faces aren't rectangular or if they are on a weird plane? I'm thinking there are a lot of tests.
                      Next version may include items like door handles ( positioning and selection ), user added profiles for edge and for panel raising etc.
                      I'm not sure that I could work with multiple faces and figure out door pull positions at the same time. I suppose for example, if user picked multiple faces where all of them could have a handle on the same relative location, that might work. But it might just add to the confusion because it would mean doing things in a very specific order.
                      Are you saying you want to suspend the door / drawer operation so you can perform some other sketchup operation like right click a line and read entity? So that you can get its length etc.
                      Currently if you make changes to the door menu (input box) and click OK or press enter, then the settings are still intact when you go back into the door menu. So you could:
                      1. make changes to door menu
                      2. click ok or press enter - box disappears and mouse cursor changes to door insert
                      3. press escape, choose a line, right click and choose "entity"
                      4. go back into door menu - last choices are all still intact. Adjust something based on what is in "entity". press enter or click ok.
                      Leaving a menu open means a rewrite for the interface. Change the sketchup inputbox to a web dialog box.
                        Garry K
                        Kristoff,
                        Version 1.0.20
                        1. Fixed the draging operation. User can now chose any corner and drag to the opposite diagonal corner.
                        2. Added config folder. Users should put their edited defaults.txt and or textures.txt files in this folder. They will be preserved with future updates.
                        3. Added Chinese(Simplified) language file zh_cn.lang
                          Krisidious
                          Koooool. I'll give it a try.
                          By: Kristoff Rand
                          • OxerO Offline
                            Oxer
                            Thanks for the plugin!!
                            I have created the Spanish Language file.
                            Spanish Language
                              Garry K
                              I am now working on the "pro" version of door maker.
                              New menu items
                              1. Add Edge Profile
                              2. Add Panel Raise profile
                              3. Add Handle
                              New input values / drop downs
                              1. Handle Style including "None"
                                128 mm bar pul
                                96 mm wire pull
                                96 mm flat bar pull
                                Round knob
                              2. Handle location drop down possibilties:
                                Top Left
                                Top Center
                                Top Right
                                Center
                                Bottom Left
                                Bottom Center
                                Bottom Right
                              3. Handle Offset input value
                              4. Front Edge profile drop down default values include:
                                None
                                Round over
                                Bead
                                Chamfer
                                Cupboard
                              5. Back Edge profile drop down default values include:
                              6. Panel profile drop down default values include:
                                Cove with bead
                                Cove with ogee
                                Cove with slant
                                Slant with bead
                                Slant with ogee
                                Slant with slant
                                Ogee with bead
                                Ogee with ogee
                                Ogee with slant
                              7. Lower Rail height input value
                              8. Lowest Panel height input value
                                Krisidious
                                Looks great Garry...
                                By: Kristoff Rand
                                  Garry K
                                  You will also be able to add door handles and pulls into the gkware_doormaker/handles folder and they will appear in the drop down list of handles.
                                  You will get 1 skp file with Edge profiles and 1 skp file as panel profiles. You can add more profiles and use the Add Edge Profiles button or Add Panel Profiles button. This will go through the geometry and add a file into the appropriate folder. The entries will then appear in the various drop down lists.
                                  These are examples of the supplied edge profiles.
                                  The one marked "Cupboard" is designed for the old style American Face Frame construction complete with a 10 mm x 10 mm rabbet. This can be accomplished by choosing "inlay" and by setting the gap to 8 mm and the protrusion to 12 mm.
                                  • MacG333M Offline
                                    MacG333
                                    Thanks for the plugin! Very nice and complete.
                                    I have created the italian language file.
                                    I hope you helpful.
                                    it.lang
                                    • unclebimU Offline
                                      unclebim
                                      Very nice options! Adding some more profiles and handles is very useful too, e.g. many customers want longer handles.
                                      What would be the pricing for the pro version of your DoorMaker plugin?
                                        Krisidious
                                        You'll be able to add profiles and handles to the library as you wish and I think the price will be between $10-$20US. Not sure though.
                                        By: Kristoff Rand
                                          Garry K
                                          Kristoff is correct. That is the range for the pricing for the Door Maker Pro.
                                          Here is the Input Box for Door Maker Pro.
                                          If anyone has suggestions or comments - now is the time to start talking.
                                          Door Maker Pro InputBox
                                          Some InputBox terms
                                            Krisidious
                                            I can't think of anything I would add Garry...
                                            By: Kristoff Rand
                                            • 3 / 3
                                            • Erster Beitrag
                                              Letzter Beitrag
