    1001Bit Bug Splats
    10 Posts 4 Posters 1.1k Views 4 Watching
      KrisM
      I love these tools but have a problem with SU 2013. Most of the tools are fine but two in particular cause problems. I have had discussions with the plugin author but so far he has been unable to track down the problem. Specifically - The "Extend Line to Edge or Face" causes a bugsplat every time (even with no plugins installed except 1001bit). The other culprit in the "Info" tool which splats about 80% of the time. I use these tools all the time (or I would if they worked) and miss their functionality. Does anyone have a similar experience or perhaps have discovered a solution?
      Kris
      • KrisidiousK Offline
        Krisidious
        Do you have the Vray Beta installed? I was having issues with the two together.
        By: Kristoff Rand
          KrisM
          Kristoff,
          With "Extend Line" I removed ALL plugins. No Vray at any time.
          Kris
            Krisidious
            That's a feature in the set I don't use, when I just tried, my SU didn't splat but locked up and had to be ended.
            By: Kristoff Rand
              manamana
              I'm having this issue as well (just bumped up to 2013)
              Anyone found a solution?
                gohch
                hi guys,
                I have been trying to catch the crashing bug for 1001bit in SU2013, the odd thing is, for some pcs, it crashes a few times and then seems to solve itself without me doing anything.
                I tried to run 1001bit inside SU2014, Windows8.1;
                it crashes initially, after i changed SU2014 to run under Win7 compatibility mode, it no longer crashes.
                Thought I update everyone on this.
                Cheers!
                GohCH
                  gohch
                  ok, this is really odd, i ran SU2014 in Win7 and the crash occurred,
                  and then i ran SU2014 on Win7 again with compatibility mode set to XP(service pack 3) and no more crashes.
                  Ran SU2014 on Win7 with compatibility set to Vista SP2 no crashes.
                  So, in Win8 i have to run as compatibility for Win7
                  and in Win7 i have to run as compatibility for XP or Vista
                  odd...
                    gohch
                    Managed to catch the BUG!!!
                    The bugs in the tools that caused the crashes:
                    "extend to edge or face"
                    "information between 2 points"
                    have been fixed in the latest rbz file:
                    http://www.1001bit.com/pro/download/1001bit_pro(v2.2).rbz
                    I have tested the other tools to work fine in SU2014,
                    if anyone has any issue, please let me know and i will look into it.
                    Thanks and cheers!
                    Goh
                      Krisidious
                      Goh is this something only people who are upgrading to 20154 should use? or is it safe for all versions?
                      By: Kristoff Rand
                        gohch
                        hi Krisidious, this is ok for all version of SU.
                        cheers!
