    Ruby script to output outer face loop?
    20 Posts 4 Posters 3.7k Views 4 Watching
      slbaumgartner
      You find the same curve again and again for each Edge associated with it. When you find a curve, you need to use its edges method to get the other Edges in the same Curve and remove them from further consideration. For instance,
      require 'sketchup'
      model = Sketchup.active_model
      face = model.selection[0]
      used_edges = []
      if (face)
        loop = face.outer_loop
        edgeuses = loop.edgeuses
        edgeuses.each do|edgeuse|
          edge = edgeuse.edge
          next if used_edges.index edge
          curve = edge.curve
          if (curve)
            used_edges = used_edges | curve.edges
            if curve.is_a? Sketchup;;ArcCurve
              UI.messagebox "Edge is an Arc Curve"
            else
              UI.messagebox "Edge is a Curve"
          else
              UI.messagebox "Edge is a Line"
        end  # end edgeuses each
      • E Offline
        emptyvessel
        I think you gentlemen may be giving me too much credit for my knowledge of ruby.
        I am a rank beginner and do not get everything your are saying or showing in your snippets.
        slbaumgartner: your code still displays a arccurve message for all facets of the arc.
        How is "next if used_edges.index edge" suppose to remove edges from consideration?
        tt_su: Your code fails to run at all. "EdgeUses not found"
        Would you be so kind as to explain how each line of your snippet works.
        Regards,
        • E Offline
          emptyvessel
          Okay, Looked up the 'Uniq' method Now I am even more puzzled.
          The following code is a modified version of tt_su's.
          Uniq appears to be returning the wrong number of array elements.
          if face
            count = 0
            edges_and_curves = []
            edges_filtered = []
              count += 1
              edge = edgeuse.edge
              edges_and_curves << edge.curve || edge
            edges_filtered = edges_and_curves.uniq
            UI.messagebox(edges_filtered.length)  # Reports 5 Should be 8
            UI.messagebox(count) # Correctly reports 52. (4 sides and 4 arcs * 12 facets)  Correct.
            slbaumgartner
            Regards,
            Hmm. I edited my post after I found errors (typed too fast) - did you try the latest version? I drew a rectangle, changed all the corners to arcs, and ran this and it report four Edges and four ArcCurves... When it completes it dumps a whole Array of stuff on the Console, but that is just because Ruby always returns the last thing it evaluated and I didn't bother to stop it.
            If you have a specific example skp, please post it and I'll try to see what went astray.
            Also, it looks to me like TT also typed in haste. I don't think his code is right...for instance edgeuses is undefined!
            Steve
            • tt_suT Offline
              tt_su
              <span class="syntaxdefault"><br />model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">if face<br />  edges_and_curves </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[]<br /></span><span class="syntaxdefault">  face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">outer_loop</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edgeuses</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">edgeuse</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">    edge </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> edgeuse</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edge<br />    edges_and_curves </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> edge<br />  </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># Because we will have added the Curve entities for each edge segment.<br /></span><span class="syntaxdefault">  edges_and_curves</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">end<br /></span>
              • tt_suT Offline
                tt_su
                In deed - I typed in a hurry and made a mess out of it. I made changes in a hurry now as well, but I still haven't checked it properly. Sorry. I'll get back to this next week. Now I need to get to bed as I'm catching a plane early in the morning.
                • E Offline
                  emptyvessel
                  Okay I worked on this this weekend and I am ALMOST getting the output I want...
                  'VB.NET Code output
                  gp.AddLine(0.000,10.000,0.000,2.000)
                  gp.AddArc(0.000,8.000,4.000,4.000,0.000,90.000)
                  gp.AddLine(10.000,12.000,2.000,12.000)
                  gp.AddArc(8.000,8.000,4.000,4.000,0.000,90.000)
                  gp.AddLine(12.000,2.000,12.000,10.000)
                  gp.AddArc(8.000,-0.000,4.000,4.000,0.000,90.000)
                  gp.AddLine(2.000,0.000,10.000,-0.000)
                  gp.AddArc(0.000,0.000,4.000,4.000,0.000,90.000)
                  The start and end arc angles all appear to be 0 and 90.
                  The x,y center point is different for each so I know I am getting each arc in the loop.
                  How does this work?
                  My latest conversion code.
                  require 'sketchup'
                  # Task; Convert sketchup face outer loop to VB.NET graphicpath code
                  def ConvertToDotNetLine(edge)
                    # Convert to VB.NET code graphicpath line definition
                    startpt = edge.start.position
                    endpt = edge.end.position
                    s = "gp.AddLine("
                    s += "%.3f" % startpt.x.to_f + ","
                    s += "%.3f" % startpt.y.to_f + ","
                    s += "%.3f" % endpt.x.to_f + ","
                    s += "%.3f" % endpt.y.to_f + ")\n"
                    return s
                  def ConvertToDotNetArc(arc)
                    # Convert to VB.NET code graphicpath arc definition
                    x = arc.center[0]-arc.radius # Left of arc circle's bounding box.
                    y = arc.center[1]-arc.radius # Top  of arc circle's bounding box.
                    wt = arc.radius * 2          # width of arc circle's bounding box.
                    ht = wt                      # height of arc circle's bounding box.
                    startang = arc.start_angle
                    endang = arc.end_angle
                    s = "gp.AddArc("
                    s += "%.3f" % x.to_f + ","
                    s += "%.3f" % y.to_f + ","
                    s += "%.3f" % wt.to_f + ","
                    s += "%.3f" % ht.to_f + ","
                    s += "%.3f" % startang.radians + ","
                    s += "%.3f" % endang.radians + ")\n"
                    return s
                  if (face)
                    sout = ""
                    used_edges = []
                      edge = edgeuse.edge
                      curve = edge.curve
                      if (curve)
                          sout += ConvertToDotNetArc(curve)
                          # UI.messagebox "Edge is an Arc Curve"
                        else
                      else
                          sout += ConvertToDotNetLine(edge)
                          # UI.messagebox "Edge is a Line"
                    f = File.open("C;\\aaapath.txt", "w")
                    f.write(sout)
                    f.close
                    UI.messagebox(sout)
                  • E Offline
                    emptyvessel
                    Discovered the Angle_Between() method and I am now calculating the start angle.
                    Things are looking better...
                    Except now I see that an outer loop in Sketchup is not a true path.
                    Endpoints of edges are not necessarily coincident with the start point of the next edge.
                    Is there some method or setting that will force this situation?
                    Otherwise I am looking at recreating every edge and curve in the correct order.
                    This is turning into a much bigger project than I had originally hoped.
                    • tt_suT Offline
                      tt_su
                      Use the Loop and EdgeUse objects that a face will give you:
                      http://www.sketchup.com/intl/en/developer/docs/ourdoc/face.php#loops
                      That will let you traverse the edges and vertices of a face in correct order.
                      • E Offline
                        emptyvessel
                        Thank you Thomas for the reply.
                        So to verify you are saying that the Loops object returns edges in order, but the outer_loop does not. Correct?
                        [Edit]
                        Nope doesn't seem to matter. It is still creating lines flipped around.
                        (see attachment)
                        [/Edit]
                        Output from my ruby.  Drawn in Top view.
                        • tt_suT Offline
                          tt_su
                          face.outer_loop returns a Loop object. Loop object will return vertices in order and it will return EdgeUse objects in order.
                          If you have an Edge and want to figure out it's direction in relationship with a face you must use edge.reversed_in?(face).
