    Ruby script to output outer face loop?
    20 Posts 4 Posters 3.7k Views 4 Watching
    • E Offline
      emptyvessel
      Hi gang,
      It has been a couple of years since I started to delve into the sketchup api and ruby.
      I am doing a couple of jobs in VB.NET at the moment that could benefit from
      converting 2D sketchup geometry into VB.NET code for it's graphicalpath class.
      Would some kind soul tutor me through creating the script.
      I tossed the following together from memory, but I am sure it is way off base.
      # Output a VB.NET graphicalpath for a closed face
      # bounded by 2D lines and arcs to the windows clipboard.
      require 'sketchup'
      include Win32
      model = Sketchup.active_model
      face = model.selection[0]
      if (Face)
        if Face.is_a? Sketchup;;Face
          loop = face.outerloop
          edgeuses = loop.edgeuses
          sout = ""
          edgeuses.each do|edgeuse|
            edge = edgeuse.edge
            if edge.is_a? Sketchup;;Line
              line = edge.line
      	s + ConvertToNetLine(line)
            Elsif edge.is_a? Sketchup;;ArcCurve
              arc = edge.arccurve
              s + ConvertToNETArc(arc)
          clipboard.set_data(sout)
        else
          # Show 'Select a single Face and try again'
      #--- Functions ---
      def ConvertToDotNetLine(line)
        # Convert to VB.NET code graphicpath line definition
        return "gp.AddLine( + line[0] + "," + line[1] + ","  + line[3] + ","  + line[4] + ")\n"
      def ConvertToDotNetArc(arc)
        # Convert to VB.NET code graphicpath arc definition
        x = arc.center[0]-arc.radius # Left of arc circle's bounding box.
        y = arc.center[y]-arc.radius # Top  of arc circle's bounding box.
        wt = arc.radius * 2          # width of arc circle's bounding box.
        ht = wt                      # height of arc circle's bounding box.
        startang = degrees(arc.start)
        endang = degrees(arc.stop-arcstart) # Delta of arc angle
        Return = "gp.AddArc(" + x + "," + y + "," + wt +  "," + ht + "," + startang "," + endang + "\n"
      def degrees(radians)
        return radians / 2 * 3.1415
      • tt_suT Offline
        tt_su
        What is the question here? What is it that you're stuck with?
          Aerilius
          The best way to create a script is to create line by line on the console. This makes sure that every line has been tested.
          Here are some things I saw:
          • You probably meant
            sout += ConvertToNetLine(line)
          • There is no Sketchup::Line, but Sketchup::Edge.
          • edge.line has only two elements: [Sketchup::Point3d, Sketchup::Vector3d]
          • Ruby is uses consistent case (case sensitive), everything is lower case except of constants:
            E̶l̶s̶i̶f̶ elsif
            R̶e̶t̶u̶r̶n̶ ̶=̶ return
          • the SketchUp API returns coordinates (and other numbers) as "Length" (of the Length class). Those take their units along into the string, and you would get "AddLine(~2.2cm,…)". So you change the type from Length to Float using to_f.
          • if edge.is_a? Sketchup::Edge cs = edge.vertices.map{ |v| p = v.position; [p.x.to_f, p.y.to_f] }.flatten s + ConvertToNetLine(*cs)
          • E Offline
            emptyvessel
            Thank you gentlemen for the replies.
            I really want to get into this conversation, but right now I am slammed
            with work.
            My company just upgraded our MRP system and every app I've ever written that leverages the database it is broken.
            I will get back to this question sometime in the near future... perhaps in a week or two.
            Regards,
            Tom
            • E Offline
              emptyvessel
              I guess I am confused about straight lines.
              From the API documentation I was under the impression that an Edge could be
              A line, curve, or arccurve.
              How do I determine which is which in an if statement.
              Won't All three be true for "if edge.is_a? Sketchup::Edge"?
              • tt_suT Offline
                tt_su
                An Edge can be part of an ArcCurve or Curve.
                Use Edge.curve to check this, it will return the curve instance if it is and nil if it't not.
                http://www.sketchup.com/intl/en/developer/docs/ourdoc/edge.php#curve
                  slbaumgartner
                  The tricky part for Ruby developers is that ArcCurve and Curve do not appear in the Entities collection. That is, you can't detect that they exist by scanning the Entities. You have to test Edges to find them.
                  Steve
                  • tt_suT Offline
                    tt_su
                    True that - they are meta-entities.
                    • E Offline
                      emptyvessel
                      Okay I have a test script that iterates over the outer loop of a simple rectangle with
                      a radius at each corner. What I cannot figure out is how to return just the four lines and four arcs.
                      What I get with the following code is four lines and a hit for every facet in each arc.
                      What am I doing wrong?
                      require 'sketchup'
                      if (face)
                        loop = face.outer_loop
                          edge = edgeuse.edge
                          curve = edge.curve
                          if (curve)
                            if curve.is_a? Sketchup;;ArcCurve
                              UI.messagebox "Edge is an Arc Curve"
                            else
                              UI.messagebox "Edge is a Curve"
                          else
                              UI.messagebox "Edge is a Line"
                        end  # end edgeuses each
                        slbaumgartner
                        You find the same curve again and again for each Edge associated with it. When you find a curve, you need to use its edges method to get the other Edges in the same Curve and remove them from further consideration. For instance,
                        require 'sketchup'
                        used_edges = []
                        if (face)
                            edge = edgeuse.edge
                            next if used_edges.index edge
                            curve = edge.curve
                            if (curve)
                              used_edges = used_edges | curve.edges
                              else
                            else
                        • E Offline
                          emptyvessel
                          I think you gentlemen may be giving me too much credit for my knowledge of ruby.
                          I am a rank beginner and do not get everything your are saying or showing in your snippets.
                          slbaumgartner: your code still displays a arccurve message for all facets of the arc.
                          How is "next if used_edges.index edge" suppose to remove edges from consideration?
                          tt_su: Your code fails to run at all. "EdgeUses not found"
                          Would you be so kind as to explain how each line of your snippet works.
                          Regards,
                          • E Offline
                            emptyvessel
                            Okay, Looked up the 'Uniq' method Now I am even more puzzled.
                            The following code is a modified version of tt_su's.
                            Uniq appears to be returning the wrong number of array elements.
                            if face
                              count = 0
                              edges_and_curves = []
                              edges_filtered = []
                                count += 1
                                edge = edgeuse.edge
                                edges_and_curves << edge.curve || edge
                              edges_filtered = edges_and_curves.uniq
                              UI.messagebox(edges_filtered.length)  # Reports 5 Should be 8
                              UI.messagebox(count) # Correctly reports 52. (4 sides and 4 arcs * 12 facets)  Correct.
                              slbaumgartner
                              Regards,
                              Hmm. I edited my post after I found errors (typed too fast) - did you try the latest version? I drew a rectangle, changed all the corners to arcs, and ran this and it report four Edges and four ArcCurves... When it completes it dumps a whole Array of stuff on the Console, but that is just because Ruby always returns the last thing it evaluated and I didn't bother to stop it.
                              If you have a specific example skp, please post it and I'll try to see what went astray.
                              Also, it looks to me like TT also typed in haste. I don't think his code is right...for instance edgeuses is undefined!
                              Steve
                              • tt_suT Offline
                                tt_su
                                <span class="syntaxdefault"><br />model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">if face<br />  edges_and_curves </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[]<br /></span><span class="syntaxdefault">  face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">outer_loop</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edgeuses</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">edgeuse</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">    edge </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> edgeuse</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edge<br />    edges_and_curves </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> edge<br />  </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># Because we will have added the Curve entities for each edge segment.<br /></span><span class="syntaxdefault">  edges_and_curves</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">end<br /></span>
                                • tt_suT Offline
                                  tt_su
                                  In deed - I typed in a hurry and made a mess out of it. I made changes in a hurry now as well, but I still haven't checked it properly. Sorry. I'll get back to this next week. Now I need to get to bed as I'm catching a plane early in the morning.
                                  • E Offline
                                    emptyvessel
                                    Okay I worked on this this weekend and I am ALMOST getting the output I want...
                                    'VB.NET Code output
                                    gp.AddLine(0.000,10.000,0.000,2.000)
                                    gp.AddArc(0.000,8.000,4.000,4.000,0.000,90.000)
                                    gp.AddLine(10.000,12.000,2.000,12.000)
                                    gp.AddArc(8.000,8.000,4.000,4.000,0.000,90.000)
                                    gp.AddLine(12.000,2.000,12.000,10.000)
                                    gp.AddArc(8.000,-0.000,4.000,4.000,0.000,90.000)
                                    gp.AddLine(2.000,0.000,10.000,-0.000)
                                    gp.AddArc(0.000,0.000,4.000,4.000,0.000,90.000)
                                    The start and end arc angles all appear to be 0 and 90.
                                    The x,y center point is different for each so I know I am getting each arc in the loop.
                                    How does this work?
                                    My latest conversion code.
                                    require 'sketchup'
                                    # Task; Convert sketchup face outer loop to VB.NET graphicpath code
                                    def ConvertToDotNetLine(edge)
                                      startpt = edge.start.position
                                      endpt = edge.end.position
                                      s = "gp.AddLine("
                                      s += "%.3f" % startpt.x.to_f + ","
                                      s += "%.3f" % startpt.y.to_f + ","
                                      s += "%.3f" % endpt.x.to_f + ","
                                      s += "%.3f" % endpt.y.to_f + ")\n"
                                      return s
                                      y = arc.center[1]-arc.radius # Top  of arc circle's bounding box.
                                      startang = arc.start_angle
                                      endang = arc.end_angle
                                      s = "gp.AddArc("
                                      s += "%.3f" % x.to_f + ","
                                      s += "%.3f" % y.to_f + ","
                                      s += "%.3f" % wt.to_f + ","
                                      s += "%.3f" % ht.to_f + ","
                                      s += "%.3f" % startang.radians + ","
                                      s += "%.3f" % endang.radians + ")\n"
                                      return s
                                    if (face)
                                      sout = ""
                                      used_edges = []
                                        edge = edgeuse.edge
                                        curve = edge.curve
                                        if (curve)
                                            sout += ConvertToDotNetArc(curve)
                                            # UI.messagebox "Edge is an Arc Curve"
                                          else
                                        else
                                            sout += ConvertToDotNetLine(edge)
                                            # UI.messagebox "Edge is a Line"
                                      f = File.open("C;\\aaapath.txt", "w")
                                      f.write(sout)
                                      f.close
                                      UI.messagebox(sout)
                                    • E Offline
                                      emptyvessel
                                      Discovered the Angle_Between() method and I am now calculating the start angle.
                                      Things are looking better...
                                      Except now I see that an outer loop in Sketchup is not a true path.
                                      Endpoints of edges are not necessarily coincident with the start point of the next edge.
                                      Is there some method or setting that will force this situation?
                                      Otherwise I am looking at recreating every edge and curve in the correct order.
                                      This is turning into a much bigger project than I had originally hoped.
                                      • tt_suT Offline
                                        tt_su
                                        Use the Loop and EdgeUse objects that a face will give you:
                                        http://www.sketchup.com/intl/en/developer/docs/ourdoc/face.php#loops
                                        That will let you traverse the edges and vertices of a face in correct order.
                                        • E Offline
                                          emptyvessel
                                          Thank you Thomas for the reply.
                                          So to verify you are saying that the Loops object returns edges in order, but the outer_loop does not. Correct?
                                          [Edit]
                                          Nope doesn't seem to matter. It is still creating lines flipped around.
                                          (see attachment)
                                          [/Edit]
                                          Output from my ruby.  Drawn in Top view.
                                          • tt_suT Offline
                                            tt_su
                                            face.outer_loop returns a Loop object. Loop object will return vertices in order and it will return EdgeUse objects in order.
                                            If you have an Edge and want to figure out it's direction in relationship with a face you must use edge.reversed_in?(face).
