    Drawing And Then Editing On Terrain Or Curved Surfaces
    13 Posts 4 Posters 1.7k Views 4 Watching
    • mitcorbM
      mitcorb
      Hi, Calstock:
      If you are using the Sandbox Tools, that draped footpath would at least be a Group, right? If so, then it is not stuck to the terrain. If it is a group, then it can be a Component, and copied to produce an instance that can be moved away from the terrain and edited. Everything you do to the instance will happen in the original component.
      I am sure I have misunderstood your point, but this is what I get from the drape portion of your writing.
      As for Layers, an important advisory would be that only Groups or Components would be layered. Raw geometry done only on default Layer 0.
      • C
        Calstock
        Hi Mitcorb,
        Thanks very much for your reply. When I drape something onto a terrain, it doesn't end up as a group, it ends up as part of the topography. Am I doing something wrong there ? Secondly, even if it was a group an arc ends up split into individual, small sections of an arc, making editing far more tricky.
        For those of you that don't deal with terrains, perhaps think of applying a line drawn pattern to a vase and then wanting to edit that pattern. The pattern may start of as simple lines, arcs and circles but once draped onto the vase, they become far more complicated / split "components" of those lines and arcs.
        I hope that makes sense and I'm sure there's a simple answer because surely this is something encountered regularly when trying to draw and edit designs onto curved surfaces like those in cars, vases and terrains ?
        • mitcorbM
          mitcorb
          Hi, Calstock:
          Glad you replied back. I think I see a little more in there.
          It would help if you could post either an image of what you are working on, or at least a portion of the model in skp (v6 or v8), so that others can also help get you to the goal.
          Your vase analogy does help, however, the application of the design to the side of a vessel would be better achieved with projection methods, or intersections.
          With regard to the fragmentation of the curves after engagement with the rest of the model, there is a plugin called Weld. There is also Recurve, and Curvizard.
          Comment back.
          • C
            Calstock
            Thanks for your help and patience Mitcorb. Here's a Dropbox link to a mocked up model to try to explain what I'm trying to do:
            https://www.dropbox.com/s/tfmicfwe406w6ag/drawing%20and%20editing%20on%20terrains.skp
            • JQLJ
              JQL
              Calstock,
              What you have here might be a question of selection. You have to select only the right parts of your terrain to make it reeditable in your process.
              What you should add to your workflow is that you should soften/smooth all terrain edges before draping. After that, just find your own methods of selection of draped curves, so you don't destroy original terrain info. The plugin that helps me the most with terrain curves is select curve from Thomthom
              Most importantly, if you have to reshape a complex mesh or erase something to create holes, don't do it!!! Hide stuff, group it, copy it, "backup" it, make component and "save as" external file. Any method is good but erase and loose all those hard to remake polygons.
              If you don't think this as anything to do with what you want... watch the video:
              (screencast.com)
              I hope this helps,
              JQL
              www.casca.pt
              Visit us on facebook!
              • mitcorbM
                mitcorb
                @Calstock:
                I think JQL has a very good example addressing this question, and his comments are very helpful.
                • C
                  Calstock
                  Thanks guys, some great advice there. I would normally soften the terrain, I didn't in the example I gave because I didn't realise it would affect the answers I'd receive. Good point to note for future questions that one.
                  The ThomThom curve finder plugin I didn't have and it's a great tool - thanks for that. This will definitely come in useful on future models.
                  The tip about hiding things rather than deleting them is something I do elsewhere in models quite often but for some reason I wasn't doing it when doing this task - good tip.
                  Although it's not a huge problem, we still seem to be in agreement you need to create and preserve a "flat plane" editing layer where you do all your adjustments. This is then used to drape the edited version of the path, (or whatever), onto the terrain. I know I can use plugins to draw directly onto the surface as well but I find getting the curves and tangents I want easier on a flat plane. So on that point I guess you don't necessarily have to have an editing layer, it's just easier for some tasks.
                  My next question, (if I'm not pushing my luck), would be how to easily apply a texture to the draped footpath without it being distorted into loads of different directions.
                  Sketchup - where would be without excellent forums like Sketchucation and where would we be without plugins !
                  • pbacotP
                    Apply teture. Turn on hidden geometry. Select a face and choose contextual menu texture / projected. Sample that face with the paint bucket tool. Turn OFF hidden geometry and apply the projected texture to the full surface.
                    There are plugins and ways to get a natural tiling pattern or even quad-mesh UV mapping based on the geometry of the object, but this projected texture is the simplest and easiest. Fredo ThruPaint and SketchUV are a couple of plugins that can help texturing multifaceted surfaces.
                    • C
                      Calstock
                      Thanks a million - I just tried that and it worked a treat.
                      It's not just me is it - this texturing question for instance is not that easy to find out on your own.
                      • JQLJ
                        JQL
                        You found it by your own questions here... so it's easy 😄
                        www.casca.pt
                        • mitcorbM
                          mitcorb
                          Hi, Calstock:
                          Easy is a relative term.
                          You can, while working, use the help available at the top line menu. Help>Knowledge Center, which takes you to help.sketchup.com, on which you can search for your answers. You can also use your favorite search engine and find loads of information, video tutorials, such as from YouTube.
                          If you are logged in to Sketchucation, you can do a search by typing in keywords in the search box at the very top of this page.
                          I am glad these other folks were able to help you.
                          • pbacotP
                            It seems texture support was only taken so far in SU to accommodate the basic flat surface modeling. Organic modeling wasn't a priority. Therefore it appears to the user that tools are lacking.
