    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.4k Views 18 Watching
    • FrederikF Offline
      Frederik
      Thanks for the heads up...
      Much appreciated... 👍
      I don't dare to copy any files into the C:\Windows\System32 folder...
      It seem strange that I would need to copy a file to a OS system folder... 😐
      From the videos this plugin looks very interesting...
      I'm working as Project Manager and my job is to make 2D and 3D drawings, mechanical design, building design, surface calculation, volume calculation, walk through in buildings, equipment layout in control/engineering rooms, piping design, piping and equipment support design, of the cooling systems we're going to be working on...
      On a daily basis I'm using the 3skeng plugin, which suits my needs well...
      Since this is also related to the piping industry I wanted to check it out, but as long as I can't get it to work, I will stick to the 3skeng plugin... 😉
      Cheers
      Kim Frederik
      • FrederikF Offline
        Frederik
        @driven said:
        @ Fredrick if you suspect the require is not working test it in 'Ruby Console'. e.g.
        > pform = (Object;;RUBY_PLATFORM =~ /mswin/i) ? ;windows ; ((Object;;RUBY_PLATFORM =~ /darwin/i) ? ;mac ; ;other)
        > platform = pform.to_s
        should return windows
        It sure does...
        @driven said:
        then try
        if platform == "windows"
        >   require 'CoolPipe/iconv.so' #  применяем iconv
        > elsif platform == "mac"
        >    #  не применяем
        > end
        should return true
        if it does it's not the problem, if it doesn't, check permissions on that file... 'CoolPipe/iconv.so' in that Directory, don't move it...
        A bit strange...
        It seem to only allow me to write
        I don't seem to be able to insert the remaining text... 😕
        Cheers
        Kim Frederik
          driven
          @frederik said:
          I don't seem to be able to insert the remaining text... :?
          I think that's the windows single line 'Ruby Console' thing... mac is multiline, and mines actually full page as well, sorry..
          just use the require and see if it returns true
          might need the rest of path if nothing else has loaded..
            driven
            I think single line looks like this
            if platform == "windows"; require 'CoolPipe/iconv.so'; elsif platform == "mac";  end
            but I never need it so... john
            • FrederikF Offline
              Frederik
              Cheers, John...!
              I believe I will just leave it as is for the time being...
              Like I wrote I don't like to copy anything to any system folder, so until they come up with an alternative plugin, I will stick to 3skeng... 😄
              Cheers
              Kim Frederik
              • kenK Offline
                ken
                I have tried each and every suggestion trying to get this plugin to work. The error is the same, can not find iconv.so.
                Is there anyone that has this plugin working on a Windows machine?
                And if you do have it working on a Windows machine, what size is your iconv.so. My iconv.so file is 24661 Date 2008-08-12-14:18.
                I can't believe it is so hard to get this plugin to work.
                Anyway thanks in advance. I am surprised the author doesn't offer any help.
                Ken
                  driven
                  @Ken & @Fredrick,
                  I had a look on the russian forum the authors reply to your issue is
                  Has already been written about it many times. Find the folder with the plugin file iconv.dll and throw it in the folder 😄 \ Windows \ System32 without this dll can not run so .... and no magic
                  I don't know windows at all, but he is saying to move the iconv.dll not the iconv.so as suggested in this thread.
                  I don't know if adding .dll is wise, maybe dan will comment...
                  • Dan RathbunD Offline
                    Dan Rathbun
                    Is there anyone that has this plugin working on a Windows machine? ... I can't believe it is so hard to get this plugin to work.
                    This plugin (in it's current state,) needs to go on the Plugins Quarantine list !
                    It needs a major overhaul.
                    ANY compiled Ruby binary file used, should match the Ruby version and platform of the currently loaded Ruby interpreter.
                    So.. it is a BAD IDEA to distribute so ("shared object",) dll ("dynamic linked library",) or any binary files WITH PLUGINS.
                    Users should just install the PROPER full Ruby edition, and use a load path script to push the paths to the standard Ruby library directories, into the global array $LOAD_PATH, which is used by the global methods load() and require() to find external files.
                    On SketchUp v 8.x PC this is Ruby v1.8.6-p287
                    Ruby v1.8.6-p287 Windows One-Click Installer
                    THEN ... after the above is done, the call to load the PROPER iconv.so file, from the platform specific sub-dir ("/i386-mswin32"), of the standard Ruby lib dir, .. is simply:
                    require("iconv")
                    (The line " Sketchup::require 'CoolPipe/iconv.so'" about 13th in "coolpipe_Start.rb" needs to change.)
                    He is Russian and does not speak English.
                    He likely does not read English, and cannot read the Programming Ruby book, because his code violates many rules and corrupts the SketchUp Ruby environment.
                    Sorry .. avoid using this plugin until it is fixed.
                    I'm not here much anymore.
                    • kenK Offline
                      ken
                      Dan
                      Thank you. There for awhile I just assumed I was the only one having trouble.
                      So thanks for taking the time to answer my request.
                      Ken
                        Stephlez
                        I am trying to use this plugin, i followed the 3 steps installation on their site:
                        1. unzip the file to a folder Plugins installed SketchUp
                        2. Copy the file iconv.dll to the System32 folder or SysWoW64
                        3. Reboot
                          It loads without errors. However it seems i am not getting any pipe models from the database (database looks empty)
                          Se7ven
                          From his site it seems that he will very soon be releasing version 2.0.
                            djRuska
                            Made with Cool Pipe 1.2.1 http://www.youtube.com/watch?v=Jdv3r-yRntM
                              driven
                              @djRustka
                              that is a lot of very cool coolPipe...
                              • utilerU Offline
                                utiler
                                Very nice work!! How do you do that shy in SketchUp...?
                                Just Curious...
                                • yad2000Y Offline
                                  yad2000
                                  I invite you to evaluate version Coolpipe 1.3 Beta 3))
                                  Fixes a lot of mistakes, I tried to take into account all the comments that made Dan
                                  I apologize for the bad English, it is translated by Google
                                  Set menu SU: Window -> Preferences -> Extensions -> Instal Extension ...
                                  Language: Russian, English, German, French, Spanish, Italian, Chinese
                                  Supported OS (tested): Windows 7/8
                                  Supported SU (verified): 2013, 2014, 2015 x32, x64 2015
                                  • .rbz file is a zip file in which all files are packed in its original form, ie, You can read / edit
                                  http://coolpipe.ru/load/coolpipe/testovye_sborki/coolpipe_1_3_beta_3/11-1-0-22
                                  CP1-3_Beta3.rbz
                                  CoolPipe Plugin
                                  • 4 / 4
