    Need Help: DC constrain min/max scaling size
    Scheduled Pinned Locked Moved Dynamic Components
    5 Posts 3 Posters 1.8k Views 3 Watching
    • dereiD Offline
      derei
      I want to scale a DC within two limits (min:5cm / max:500cm), but I can't figure how to constrain to both.
      To constrain for one of them I can use "if" condition, but I have no idea how to use for both ends constraining.
      Thanks.
      EDIT
      Thanks Box for pointing out the error in this post, I corrected it now. It was meant to be 5CM (but I am sure you figured it out, even if it was wrong).
      Would you be so kind to offer a solution for my problem, now? πŸ’š
      • danielbowringD Offline
        danielbowring
        If you want to avoid if statements, you can use SMALLEST and LARGEST like so
        =SMALLEST(MAX_VALUE, LARGEST(MIN_VALUE, value))
          pcmoor
          using the conditional statement is correct,(<5) then smallest (current & 50)
          note for metric you have to use 2.54 as a conversion from inches to cm when getting or using the current value
          example attached
          Philip
          5min.skp
          • dereiD Offline
            derei
            @pcmoor said:
            example attached
            Philip
            Please for SU8, thank you!
              pcmoor
              No worries....
              SU8
