    [Plugin] Components manager plugin
    156 Posts 15 Posters 71.6k Views 15 Watching
    • inteloideI
      inteloide
      Hello Gents,
      Please download last version of the plugins which solve the 2 issues you raised me :
      Version 1.11.3:
      Optimized : The modification of components don't add lots of undo/redo action in Edit menu.
      Corrected : Bug when changing filters
      Oxer, could you tell me also if the last version solve your issue about button title translation in main window ?
      JQL, thx for chasing me on the undo/redo action, actually it was just simple as reading the sketchup rubi api...
      Just one thing : for example if you delete an edge linked to a face, so edge and face are deleted, when undo the action, the component manager will tells you that your component has been modified (even if it actually reverse back to original design).
      It's not a big bug, but I'll keep thinking about a solution.
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • inteloideI
        inteloide
        @jql said:
        4 - There is a feature that is not working as I would expect too. If one refreshes the list by whatever reason it collapses (some commands also refresh it). You loose the context on the list you were on. Of course it's easy now to choose from model so this is just a minor question.
        JQL
        Except this request, I think I've complete all the other request. 😍
        But don't worry I have one idea for this request, even if I think that at the end using list in a non-tree style is easier to use.
        Other steps for plugin optimization would be :
        • Add possibility to auto-update the list when change the model with defining the update time (from 1 sec for small model, too minutes for big one) I could link this frequency to the time required to update the list : frequency auto-defined !
        • Add possibility to attached current time as modification time for component in model. This could be usefull for old model designed before having the plugin, or designed while plugin was desactivated.
        • change Option interface (options are mixed, and design just horrorful !)
        • change actions button at bottom of main window. Or allow user to defined which button he wants to have.
          If you have other request...they will be welcomed. 🎉
        If few days I will open a new topic to find some beta tester for an industrial 6 axis robot manager plugin. This will be the second plugin I'll officially release even if they are months I'm working on.
        So if you have other requests it's time, even if I won't let you down !
        Inteloide
        • JQLJ
          JQL
          Congratulations on this Milestone!
          I'll try this one... but don't worry, I'll find some feature requests for you to deal with 😄
          Thanks,
          JQL
          www.casca.pt
          Visit us on facebook!
          • inteloideI
            inteloide
            Hello,
            Today update :
            Optimized : New options windows in HTML mode.
            Corrected : Little change in code to avoid error when deleting components with merge faces (to be verified...)
            Added : Prompt before upload all définitions
            Options texts translation have to be done again...sorry for that...
            Inteloide
            • OxerO
              Oxer
              Test v1.12 on Mac:
              The Options button doesn't work, it appears this message in Ruby Console when you push the button:
              %(#FF0040)[Error: #<TypeError: can't convert false into String>
              /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:794:in `+'
              /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:794:in `options'
              /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:793:in `each'
              /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:793:in `options'
              /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:52:in `initialize_window']
              • inteloideI
                inteloide
                Hello Oxer,
                Version 1.12.1 should solve your issue.
                Inteloide
                • OxerO
                  Oxer
                  Other problems 😳
                  1. The Options "Auto-select instances in model" & "Auto-select instances in list" worked only the first time that I ran the plugin.
                  2. The Groups don't appear in the List although you have marked them in the Filters windows.
                  3. I don't know if this is important but when I create a "New File" with the Ruby Console opens, it appears this message:
                  %(#FF0040)[Error: #<NoMethodError: undefined method `execute_script' for nil:NilClass>
                  /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:132:in `maj_liste'
                  /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:1100:in `onNewModel'
                  /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:1073
                  /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:132]
                  • OxerO
                    Oxer
                    Great work!! 👍
                    All work fine now *****, nice Options window, perhaps a scrollbar, the windows size is very small on Mac and you have to resize them manually.
                    The translation works partially.
                    It works in:
                    1. Plugins Menu
                      1. Titles of the windows.
                      1. Tooltips of the items in the List.
                      1. Tooltip of the toolbar icon.
                      1. All the strings in the Filters window.
                      1. String: "List update at "
                      1. All pop-up windows.
                    The rest no.
                    ***** See the next post.
                    • JQLJ
                      JQL
                      Inteloide,
                      For me undo is working badly again, this time it says undo BGSketchup instead of undo EDIT Properties.
                      Besides that, if I do a push pull I can't define a distance I have to get a reference point.
                      I have to disable plugin and restart SU for undo or pushpull to work.
                      Best regards,
                      JQL
                      www.casca.pt
                      • inteloideI
                        inteloide
                        ok guys.
                        Last version should solve some of your issues.
                        Oxer, for the issue of option for selecting components....very strange, everything work perfect on my PC. Is it not working with groups ? (I didn't implemented this function for groups. I should include it).
                        Same remarks with Group filter. I tried successfully lot of model.
                        For your point 3, this error involve also JSQL issues, then this version should solved everything.
                        JQL please try again your undo issue, on my it works.
                        Oxer, is this version solve the scrollbar issue in option window ?
                        We keep in touch.
                        Inteloide
                        • JQLJ
                          JQL
                          Pushpull is working nicely outside groups and components, but inside a component you still are unable to set a dimension for pushpull, or Undo. This time it doesn't even undo if you press CTRL+Z a lot.
                          I'm going to PM you a model for you to test.
                          www.casca.pt
                          • OxerO
                            Oxer
                            I sent you a PM with my answers, but the scrollbars no appear in the Options window.
                            • inteloideI
                              inteloide
                              Hello
                              Just post a plugins that solve push/pull issue (and maybe some other). It was a bug not so easy to find...
                              Oxer, I will post you a special version that tries to add scrollbar on Safari. About translation, could you tell me exactly an example of a translation not working ? I change in version 1.12.4 the option translation text to the English to avoid wrong coding because of new option texts structure.
                              Version 1.12.4 :
                              Corrected : Issue when using push/pull tool in a component.
                              Optimized : Simplified attribute date change in model to open only one time for each component.
                              • OxerO
                                Oxer
                                With v1.12.4 on Mac the scrollbars continue missing and the translation works partially.
                                It works in:
                                • Plugins Menu
                                • Titles of the windows.
                                • Tooltips of the items in the List.
                                • Tooltip of the toolbar icon.
                                • All the strings in the Filters window.
                                • String: "List update at "
                                • All pop-up windows.
                                The rest no.
                                • inteloideI
                                  inteloide
                                  @oxer said:
                                  The rest no.
                                  Ok this means that "options" are not translated. Are all options not translated ? (remember that in current Localization.rb file I let everything in English, to try it you have to change translation).
                                  Also, for your window size issue, I added a option to save window size, which solve temporary your size issue.
                                  V 1.13.0 :
                                  Added : New option to save window size
                                  Added : Show refreshing time in the window status bar
                                  Corrected : Remove one unused global variable
                                  • OxerO
                                    Oxer
                                    Yes, all Options not translated. I changed the translation.
                                    The "Save Window Size" option works fine but there is a great problem, when you call the plugin the first time all work fine, then you close the Component Manager window, the second time that you call the plugin, it appears the Component Manager window with the message: "Please refresh the list" but the buttons doesn't work, no Refresh List, no Link to file, nothing.
                                    • JQLJ
                                      JQL
                                      Inteloide,
                                      I tried it again today and the problems with push-pull and undo have disappeared, but now I'm seing it messing with Fredoscale and I also believe JointPushPull. I think it's because they perform changes to components and groups visually and interactively.
                                      I think your plugin is making Fredo scale multiply a given value several times, until the mouse is clicked.
                                      I also believe it's making JointPushPull crash.
                                      May you have some conflicts with your observers and Fredo's?
                                      www.casca.pt
                                      • inteloideI
                                        inteloide
                                        Hello JQL,
                                        I check a bit Fredo's plugin code, apparently nothing should make conflict...but I will ask Fredo if we can check this toegether.
                                        Inteloide
                                        • JQLJ
                                          JQL
                                          But did you see what happens? Do you want me to make a video or something?
                                          www.casca.pt
                                          • inteloideI
                                            inteloide
                                            Hello JQL,
                                            Yes a little video would be helpful.
                                            Inteloide
                                            • 5 / 8
