π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Clipping mask to multiple objects
I discovered something nice. You can clip-mask multiple objects at once. For an occasional case it could be helpful, so I thought I'd note it for others. I found it good in importing different CAD layer setups of the same object.
Mate I've found in some cases this is risky - i've had some file corrupting crashes when clipping more that one image at a time!
Oh! Thanks!
