    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Web dialog on a Mac
    69 Posts 9 Posters 8.4k Views 9 Watching
      Garry K
      I hear you. If you change the first line of the function to this does it work correctly?
      dlg = UI::WebDialog.new( "Stair Measurements", false, "StairMaker_Web_Dialog", 570, 452, 0, 0, true );
        driven
        I think I used 628 × 500, SU include the Title-bar in it's size on most mac's...
        I'll check later
          Garry K
          One difference that I see is with margin.
          margin: 2px works on Windows = but it appears that the margin is larger in Safari.
          Perhaps the margin is simply ignored with Safari.
          The other difference that I see is the check box. I set width to 120px, the same for everything. It centers in Windows and left justifies with Safari.
          Is this the same for all MAC's ???
            Garry K
            I added this line immediately after <head> and also tried it immediately after <html>
            I tried it set to "yes" and set to "no with Windows and did not see any difference.
            There is a <style> section prior to <head>
            When I put the line immediately after <style type="text/css"> then the background color for the body failed to apply regardless if I set content to "yes" or to "no"
            So I'm not sure exactly what this metatag is suppose to do. I'm not sure where the tag should go ( although I did read a microsoft page where they placed it immediately after <head>
            Also - what will it do with Safari? Did you suggest it because the margins are different with safari?
            • jolranJ Offline
              jolran
              You could do some css reset to "try" to remove some browser specific styling..
              Has it's pros and cons. Testing needed..
                driven
                Meta goes in here above Title
                <html>
                <head>
                  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
                  <meta http-equiv="Content-Style-Type" content="text/css">
                  <title></title>
                  <style> *, body {
                  -webkit-appearance;none;
                 </style>
                </head>
                <body>
                <div>
                </div>
                </body>
                </html>
                and if you add that line -webkit-appearance:none;in your styles you get this....
                your fighting WebKit, not Safari....
                • Dan RathbunD Offline
                  Dan Rathbun
                  WITHIN the HEAD section, BEFORE any SCRIPT or STYLE sections (tags).
                  I am sorry that webpage shows the tag incorrectly.
                  It should be:
                  <meta http-equiv="MSThemeCompatible" content="Yes">
                  It will be ignored under Safari.
                  On Windows it will make the web browser control use native MS Common Control styling (just like the users dialog boxes. Buttons with hover effect, styled checkboxes etc.)
                  I'm not here much anymore.
                    Dan Rathbun
                    Activate Windows native control styling...
                    How to: <meta http-equiv="MSThemeCompatible" content="Yes">
                    EDIT: changed name= to http-equiv=
                      Garry K
                      Thanks - I will see if someone will help test this on a Mac once I get closer to releasing the StairMaker plugin.
                      • tt_suT Offline
                        tt_su
                        A bit late to the party, but if you just need simple controls and theming then you can try out SKUI: https://github.com/thomthom/SKUI/wiki/Quick-Overview
                        Takes care of all the WebDialog stuff and exposes only a Ruby object model to the GUI elements.
                          Garry K
                          Interesting idea - but what I need goes a bit above this. I want to add into the web dialog a jquery call using JSON to query a MySql database on my website. I will use PHP for the server portion.
                          In any event - good knowledge of CSS, HTML and JS is good to have.
                            Garry K
                            Well, call me frustrated.
                            The simple test application worked with the Mac. But the complete Stair Maker plugin does not work with the Mac.
                            I've added instance variables for the web dialog.
                            I've stored the text that Ruby passes over to the Web Dialog as an instance variable and built prior to calling the web dialog.
                            I must be missing something. The overall strategy now is:
                            if ( document.addEventListener )
                            document.addEventListener( "DOMContentLoaded", ready, false );
                            else if ( document.attachEvent )
                            document.attachEvent( "onreadystatechange", check_ready );
                            When the DOM is loaded it makes a call back to ruby with text == 'loaded'.
                            ruby then passes the string over to the web dialog for processing.
                            When the user clicks the button the web dialog traverses the DOM and peels out all of the text for input controls and builds up a single string. Then makes a call back to ruby and closes the dialog.
                            One question I have is can Safari handle making a call to execute script from within the ruby call back. Or do I need to consider turning this into a state machine?
                              slbaumgartner
                              Yes, WebKit can handle making an execute_script call from within a Ruby skp: callback. But you have to be careful what the script does. On the Mac, Ruby will wait synchronously for javascript to return, but javascript will not wait for Ruby, so you have to be careful. Sometimes a state machine or similar is the only solution.
                              A picky point we Mac'ers need always to reinforce: WebDialog uses the WebKit library, not Safari.
                                adt2
                                Garry - Where do I get the updated version? I can't find a download link...
                                Andy
                                  Garry K
                                  It is on the stair maker thread
                                  http://sketchucation.com/forums/viewtopic.php?f=183%26amp;t=54157%26amp;p=510178#p510178
                                    Garry K
                                    Steve,
                                    In ruby the last statement in the callback is
                                    dialog.execute_script( script )
                                    In the web side there is a parsing routine plus the populate_drop_down function
                                    function from_ruby( data )
                                    	var element;
                                    	var pair;
                                    	var pairs = data.split( '&' );
                                    	var count = pairs.length;
                                    	for ( var i = 0; i < count; i++ )
                                    		pair = pairs[i].split( '=' );
                                    		element = document.getElementById( pair[0] )
                                    		if ( element.type == "select-one" )
                                    			if ( pair[1].indexOf('|') == -1 )
                                    				element.selectedIndex = pair[1];
                                    			else
                                    				populate_drop_down( element, pair[1] );
                                    		else if ( element.type == "text" )
                                    			element.value = pair[1];
                                    		else if ( element.type == "checkbox" )
                                    			element.checked = pair[1] == '1';
                                    It almost seems like the DOM isn't really ready to receive updates.
                                      driven
                                      <head>
                                      <script type="text/javascript">
                                      var xmlHttp = null;
                                         xmlHttp = new XMLHttpRequest();
                                         xmlHttp.open( "POST", "http://cabmaker32.com//stairmaker_service.php", true );
                                         xmlHttp.onreadystatechange = handleRequestStateChange;
                                         xmlHttp.send( data );
                                      function ruby_call( text )
                                         window.location.href = 'skp;ruby_callback@' + text;
                                      function handleRequestStateChange()
                                      	if ( xmlHttp.readyState == 4 )
                                      		if ( xmlHttp.status == 200 )
                                      			ruby_call( xmlHttp.responseText );
                                      		else
                                      			ruby_call( 'error' );
                                      function check_ready()
                                      	if ( document.readyState === "complete" )
                                      		ready()
                                      function ready()
                                      	ruby_call( "loaded" );
                                      </script>
                                      </head>
                                      this is all I can grab before I get the service denied message....
                                        slbaumgartner
                                        @garry k said:
                                        Steve,
                                        > 	var element;
                                        > 	var pair;
                                        > 			else
                                        I downloaded the rbz from the curved stairs topic hoping I could help, but all I get is this error dialog...
                                          driven
                                          it's Gary's birthday and 'her that needs to be obeyed' has curtailed his explorations....lol
                                            slbaumgartner
                                            The first time I click "Stair Maker", a blank dialog window pops up at upper left and the Ruby Console displays:
                                            show 1
                                            loaded 1
                                            cb1 complete
                                            then after a moment that window disappears and the error message box appears. At that point the console adds:
                                            closed 1
                                            And I also notice that four new layers have been added to the model: Handrail, Risers, Stringers, Treads.
                                            When I click ok on the error message box, the console adds:
                                            loaded 2
                                            cb2 complete
                                            and this web dialog appears:
                                            If I click the Load button, any values I have typed into fields are reset and the console again adds:
                                            loaded 2
                                            cb2 complete
                                            If I click the OK button, the web dialog closes and the console adds:
                                            closed 2
                                            cb2 complete
                                            If I then select Stair Maker again, it immediately pops up the error message, without displaying the first three console messages about "1".
                                            Since your Ruby is scrambled, I have no idea what is happening on that side, but does this behavior correspond to what you expect? If not, what exactly is the problem?
                                            I noticed that your HTML has a bogus <body"> element. It appears that the WebDialog ignores it.
                                            Steve
                                            • 4 / 4
