    Web dialog on a Mac
    69 Posts 9 Posters 12.6k Views 9 Watching
      driven
      Meta goes in here above Title
      <html>
      <head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
        <meta http-equiv="Content-Style-Type" content="text/css">
        <title></title>
        <style> *, body {
        -webkit-appearance;none;
       </style>
      </head>
      <body>
      <div>
      </div>
      </body>
      </html>
      and if you add that line -webkit-appearance:none;in your styles you get this....
      your fighting WebKit, not Safari....
      • Dan RathbunD
        Dan Rathbun
        @garry k said:
        So I'm not sure exactly what this metatag is suppose to do. I'm not sure where the tag should go ( although I did read a microsoft page where they placed it immediately after <head>
        WITHIN the HEAD section, BEFORE any SCRIPT or STYLE sections (tags).
        I am sorry that webpage shows the tag incorrectly.
        It should be:
        <meta http-equiv="MSThemeCompatible" content="Yes">
        It will be ignored under Safari.
        On Windows it will make the web browser control use native MS Common Control styling (just like the users dialog boxes. Buttons with hover effect, styled checkboxes etc.)
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          Activate Windows native control styling...
          How to: <meta http-equiv="MSThemeCompatible" content="Yes">
          EDIT: changed name= to http-equiv=
          • G
            Garry K
            Thanks - I will see if someone will help test this on a Mac once I get closer to releasing the StairMaker plugin.
            • tt_suT
              tt_su
              A bit late to the party, but if you just need simple controls and theming then you can try out SKUI: https://github.com/thomthom/SKUI/wiki/Quick-Overview
              Takes care of all the WebDialog stuff and exposes only a Ruby object model to the GUI elements.
              • G
                Garry K
                Interesting idea - but what I need goes a bit above this. I want to add into the web dialog a jquery call using JSON to query a MySql database on my website. I will use PHP for the server portion.
                In any event - good knowledge of CSS, HTML and JS is good to have.
                • G
                  Garry K
                  Well, call me frustrated.
                  The simple test application worked with the Mac. But the complete Stair Maker plugin does not work with the Mac.
                  I've added instance variables for the web dialog.
                  I've stored the text that Ruby passes over to the Web Dialog as an instance variable and built prior to calling the web dialog.
                  I must be missing something. The overall strategy now is:
                  if ( document.addEventListener )
                  document.addEventListener( "DOMContentLoaded", ready, false );
                  else if ( document.attachEvent )
                  document.attachEvent( "onreadystatechange", check_ready );
                  When the DOM is loaded it makes a call back to ruby with text == 'loaded'.
                  ruby then passes the string over to the web dialog for processing.
                  When the user clicks the button the web dialog traverses the DOM and peels out all of the text for input controls and builds up a single string. Then makes a call back to ruby and closes the dialog.
                  One question I have is can Safari handle making a call to execute script from within the ruby call back. Or do I need to consider turning this into a state machine?
                    slbaumgartner
                    Yes, WebKit can handle making an execute_script call from within a Ruby skp: callback. But you have to be careful what the script does. On the Mac, Ruby will wait synchronously for javascript to return, but javascript will not wait for Ruby, so you have to be careful. Sometimes a state machine or similar is the only solution.
                    A picky point we Mac'ers need always to reinforce: WebDialog uses the WebKit library, not Safari.
                      adt2
                      Garry - Where do I get the updated version? I can't find a download link...
                      Andy
                      • G
                        Garry K
                        It is on the stair maker thread
                        404 Not Found
                        (sketchucation.com)
                        • G
                          Garry K
                          Steve,
                          In ruby the last statement in the callback is
                          dialog.execute_script( script )
                          In the web side there is a parsing routine plus the populate_drop_down function
                          function from_ruby( data )
                          	var element;
                          	var pair;
                          	var pairs = data.split( '&' );
                          	var count = pairs.length;
                          	for ( var i = 0; i < count; i++ )
                          		pair = pairs[i].split( '=' );
                          		element = document.getElementById( pair[0] )
                          		if ( element.type == "select-one" )
                          			if ( pair[1].indexOf('|') == -1 )
                          				element.selectedIndex = pair[1];
                          			else
                          				populate_drop_down( element, pair[1] );
                          		else if ( element.type == "text" )
                          			element.value = pair[1];
                          		else if ( element.type == "checkbox" )
                          			element.checked = pair[1] == '1';
                          It almost seems like the DOM isn't really ready to receive updates.
                            driven
                            <head>
                            <script type="text/javascript">
                            var xmlHttp = null;
                               xmlHttp = new XMLHttpRequest();
                               xmlHttp.open( "POST", "http://cabmaker32.com//stairmaker_service.php", true );
                               xmlHttp.onreadystatechange = handleRequestStateChange;
                               xmlHttp.send( data );
                            function ruby_call( text )
                               window.location.href = 'skp;ruby_callback@' + text;
                            function handleRequestStateChange()
                            	if ( xmlHttp.readyState == 4 )
                            		if ( xmlHttp.status == 200 )
                            			ruby_call( xmlHttp.responseText );
                            		else
                            			ruby_call( 'error' );
                            function check_ready()
                            	if ( document.readyState === "complete" )
                            		ready()
                            function ready()
                            	ruby_call( "loaded" );
                            </script>
                            </head>
                            this is all I can grab before I get the service denied message....
                              slbaumgartner
                              @garry k said:
                              Steve,
                              > 	var element;
                              > 	var pair;
                              > 			else
                              I downloaded the rbz from the curved stairs topic hoping I could help, but all I get is this error dialog...
                                driven
                                it's Gary's birthday and 'her that needs to be obeyed' has curtailed his explorations....lol
                                  slbaumgartner
                                  The first time I click "Stair Maker", a blank dialog window pops up at upper left and the Ruby Console displays:
                                  show 1
                                  loaded 1
                                  cb1 complete
                                  then after a moment that window disappears and the error message box appears. At that point the console adds:
                                  closed 1
                                  And I also notice that four new layers have been added to the model: Handrail, Risers, Stringers, Treads.
                                  When I click ok on the error message box, the console adds:
                                  loaded 2
                                  cb2 complete
                                  and this web dialog appears:
                                  If I click the Load button, any values I have typed into fields are reset and the console again adds:
                                  loaded 2
                                  cb2 complete
                                  If I click the OK button, the web dialog closes and the console adds:
                                  closed 2
                                  cb2 complete
                                  If I then select Stair Maker again, it immediately pops up the error message, without displaying the first three console messages about "1".
                                  Since your Ruby is scrambled, I have no idea what is happening on that side, but does this behavior correspond to what you expect? If not, what exactly is the problem?
                                  I noticed that your HTML has a bogus <body"> element. It appears that the WebDialog ignores it.
                                  Steve
                                  • G
                                    Garry K
                                    Steve,
                                    Ok we are getting somewhere. Can you tell me if the input boxes and drop downs were populated before you clicked on the "Load" button.
                                    "user not on file" at the top of the dialog is correct for an error code -21.
                                    I believe that if you edit the defaults.txt file and stick in the user and password from registering with my web site that you would be able to create a circular stair.
                                    I will temporarily make changes to the web service so that you don't have to edit the defaults.txt file. And I am going to rem out the extra messages and drop the load button.
                                      driven
                                      garry
                                      I'm not getting as far as steve...
                                      from WebKit WebInspector inside SU...
                                      [Error] SyntaxError; Expected token ')' (file;///, line 1)
                                      > ready
                                      < function ready() {
                                      • G
                                        Garry K
                                        Did you update the defaults.txt file or leave it as 'user' and 'test'
                                          slbaumgartner
                                          @garry k said:
                                          Steve,
                                          Yes, Garry, all the fields in the dialog were populated when it first appeared, including drop-down lists.
                                          Steve
                                            slbaumgartner
                                            @garry k said:
                                            Steve,
                                            I registered on your site, edited the info into the defaults.txt, and voila, got this:
                                            • 2 / 4
