    How can I run code on view-change
    8 Posts 4 Posters 477 Views 4 Watching
    • onidarbeO Offline
      onidarbe
      Can code keep on running in the background or can plugins only be run from a user command and need to finish before you can continue to work on the model?
      Or how can I write a Ruby plugin that is some event, like changing the viewing-angle?
      thank you
      • Dan RathbunD Offline
        Dan Rathbun
        Event driven is best for a GUI application. (Responding to what the user is doing.)
        This is done in SketchUp Ruby with observers. Check out all the various observer classes.. which have event callbacks that the SketchUp engine will call.
        I'm not here much anymore.
        • onidarbeO Offline
          onidarbe
          thanks!
          • onidarbeO Offline
            onidarbe
            I found out how to trigger a method when the viewing angle has changed, but I can't seem to find how to know in which viewing direction the window is.
            class MyViewObserver < Sketchup;;ViewObserver
              def onViewChanged(view)
                puts view.camera.eye.to_s
            Sketchup.active_model.active_view.add_observer(MyViewObserver.new)
            I would like to know the current viewing angle X, Y, Z and compare this to a face if that face is visible on that side or not.
            Any idea how to do that?
            thanks
            • jolranJ Offline
              jolran
              Just a sidenote. If you are only after watching orbiting, you could use tool resume(view) method. It fires after orbiting or pan and zoom as well. Then you might not need any observer.
              You could set a methodcall in there instead..
              What do you mean face visible ? Reversed ?
              Havent done any code for checking face reversed, so I'm just speculating.
              I'd reckon it will be unpredictable. Think there are some plugins for this already?
              Maybe TIG's orient faces or such..
              But you could project a ray(view pickray I think?) to the face and compare that vector to the face.normal to within some tolerance. That tolerance would be the hard part, I guess.
              But needed since view ray will not be parallel to the face normal all of the time..
              Then set conditions comparing vector directions.
                The camera has a .eye and a .target
                direction = camera.eye.vector_to(camera.target)
                BUT there's also the simpler:
                direction = camera.direction
                Now the face has a a vector 'normal':
                normal = face.normal
                If the angle between the 'direction' and the 'normal' are < 90.degrees then you are either 'behind' the face looking towards it, or 'in front' of it looking away from it. At == 90.degrees you are 'edge on'.
                ` angle = direction.angle_between(normal)
                facing = true if if angle > 90.degrees
                etc`
                If you are checking that the camera is looking 'directly at' the face... then use
                rayt = model.raytest([camera.eye, direction])
                this return nil if no hit at all, or a [point, array_of_objects] - the hit = rayt[1][-1] return what was hit, so:
                ` if hit == face || face.edges.include?(hit)
                etc`
                This tells you if the camera is looking at the face and from the 'angle' if the face is facing the camera or turned away from it...
                Additional raytesting can also check for intervening objects if you want them to be considered 'transparent'...
                ` ### Make a loop...
                while rayt || rayt[1][-1] != face
                rayt = model.raytest([rayt[0], direction])
                after the loop...
                hit = true if rayt && rayt[1][-1] == face This keeps 'mining' through until it hits nothing ' nil' OR ' face' is encountered, THEN if needed check the angle > 90.degrees` etc
                • jolranJ Offline
                  jolran
                  Nice. I knew someone had done this..
                  That looks like it will be fairly predictable ?
                  • onidarbeO Offline
                    onidarbe
                    thanks!
