📷 GIF Exporter 1.1 | create animated GIFs from SketchUp models with customizable settings
Download
Distribute objects equally
Can one distribute objects equally in SU like one can in CorelDraw?
Yes, you can move one object as a copy (CTRL+move) and repeat that operation (enter 10x e.g.).
Thanks Cotty for your swift reply.
Doesn't seem to work. Pressed "Ctrl" and right arrow key simultaneously to copy the object of the same plane, but "Redo" on the Edit menu doesn't appear in black.
Here are the steps in more detail: http://help.sketchup.com/de/article/94867
Thank you for the tip!
