    Best GPU for Sketchup + Thea GPU Rendering?
    37 Posts 14 Posters 22.5k Views 14 Watching
    • soloS
      You have too much money Pete.
      For example two GTX 680's in SLI will out perform the Titan as a whole but i dont know if Thea supports that? Pete?
      I wish, I tried selling my kids to get a Titan card, but no takers I only have a 660ti 3gb.
      The thing is you can have as many cards as you want for rendering and they will combine and speed up your renders but it will only use the Vram from one card so you are limited there, so the Titan which is a damn fast card also has 6gb of ram, so for the money it's the best option.
      • L
        liam887
        @solo said:
        @liam887 said:
        You wont really notice much difference in SU depending on your video card as it comes from the CPU. While the TITAN is great for gaming you can get other cards that do nearly as much damage when redering for substantially cheaper.
        Also did you mean 50,000 polygons or 50,000,000!
        Gotta disagree, nothing beats the Titan in rendering, the 6GB Vram is the clincher.
        EDIT
        Saying that I just googled it and you can buy one for only Β£815 (probably cheaper if you look harder). I thought they where over Β£1k.
        http://www.shop.bt.com/products/evga-geforce-gtx-titan-876mhz-6gb-pci-e-3-0-hdmi-superclocked-8KTJ.html?utm_source=google%26amp;utm_medium=ppc%20product%20search%26amp;utm_content=RR00%26amp;utm_campaign=Components%20and%20Storage%20-%20Graphics,%20TV%20Tuners%20and%20I/O%20-%20Graphics%26amp;origin=pla
        VISIT MY ONLINE GALLERY
        • L
          liam887
          Ahh I see yes. In the same boat I would like them but not going to happen any time soon...
          • L
            Liverpudlian82
            Thanks for your opinions.
            So understand that CPU is the bottle neck in SU. Problem is: it does not get much faster than what I already have πŸ˜•
            @liam: 50.000.000 πŸ˜„
            @solo: Love your avatar πŸ˜‰
            • L
              liam887
              One thing I have used in SU to get around this problem is create a model in multiple documents and then assemble in the render engine. Or only compile the model when you want to output for a render. I have special tags in my geometry so the bits piece together like lego. I can then delete that geometry in Thea if that makes sense?
              And if you cant be bothered to do that you can use the layers panel. I have managed some fairly big models in the multi million polys on my laptop.
              • soloS
                Well, I just did it, placed an order on Amazon for a Titan, expedited to arrive Friday. Base camp may be out of reach as I spent $1000 on a video card (wife cannot understand these things, kids think my work machine is their next gaming rig...dream on)
                ERROR: The request could not be satisfied
                (www.amazon.com)
                Would like to see how a GTX 660ti and a Titan work together for rendering.
                • sketch3d.deS
                  sketch3d.de
                  So understand that CPU is the bottle neck in SU. Problem is: it does not get much faster than what I already have...
                  the fastet i7-3770K@3.50GHz reaches 9.577 Passmark points, the i7-4930K@3.40GHz of the recent 'Haswell' series 13.624 Passmark points ~ 42% better number crunching.
                  combined with a nice SSD (-> Samsung 840 Pro) this may give a neat boost for SU.
                  [update]
                  oops, the 4930K is a six core CPU and thus won't help much for SU besides over-clocked... but maybe helpful for rendering though.
                  [/update]
                  • N
                    numerobis
                    @sketch3d.de said:
                    A GeFroce GTX 780 Ti is currently the fastest video card for SU, a GTX 780 or 770 probably the best bang for the buck GPU.
                    This is a DirectX benchmark... how should this say anything about sketchup performance?
                    http://www.passmark.com/products/pt.htm
                    http://www.passmark.com/products/pt_adv3d.htm
                    @sketch3d.de said:
                    Quadros typically do not show any advantage for SU display output speed, i.e. burning money for nothing.
                    I'm not sure about this... I'm waiting for a clarification for years now. Sketchup is still openGL, so theoretically there should be an advantage. I really would like to see some fundamental tests of this, but a problem is that there is no proper benchmarking method. Maybe by playing an automated sequence of a bigger scene, but then the adaptive degradation would have to be disabled for proper results...
                    But yes, i think the best way to speed up sketchup is still a high single core CPU performance.
                    πŸ˜†
                    • N
                      notareal
                      Running two cards will help, but forget connecting those to SLI, it wont help or actually may cause issues, as SLI is only for "game" graphics... it does not work with CUDA. Sure Thea can use both (darkroom), but for IR rendering it will use one dedicated to it and the other one will be used for running display, so you get good response when working with UI.
                      • soloS
                        How does one decide this, through the Nvidia panel or Thea studio? what about in the Thea4SU plugin?
                        • N
                          notareal
                          From nvidia control panel you can just enable/disable cuda for certain program/globally.
                          Thea and Thea4SU has devices panel that can be used to set priority, interactive and so... that is the place where you select what is interactive GPU.
                          • sketch3d.deS
                            sketch3d.de
                            benching the trianglation throughput speed of GPUs by processing facetted 3D meshes surely provides some valuable results to derive from for the display output performance of SU even if MS Direct3D is used. The relations of the values between the respective models will probably be very comparable if the OGL stack would be used.
                            SU is currently using the capabilities of the ol' OGL version 1.5, therefore the advanced capabilities of the Quadro FX drivers certified for high-end modelers as e.g. Catia, NX or Creo etc. are simply not required.
                            definitely, but for a fast system the components combined also need to be on a par, a fast graphics accelerator won't help if the main processor is the bottle neck and vice versa.
                              sonder
                              I currently have a 680 GTX 4gb and it is really fast. In talking with the guys over at Eon, I will be getting a Titan next.
                              • soloS
                                Is this because you got some inside info? πŸ’š
                                We are talking LumenRT or is Vue going GPU?
                                • L
                                  Liverpudlian82
                                  (www.amazon.com)
                                  @Solo: Did the card arrive yet? If so, please let us know about the rendering experience with Thea's GPU render engine πŸ˜„
                                  • soloS
                                    It did indeed and it's installed.
                                    I decided to take Giannis's advice (Thea developer) and keep my existing GTX 660ti 3GB and add the Titan in next PCI express slot, I kept my dual monitors connected to GTX 660 and left it as main GPU.
                                    Now in Lumion and Thea I set it's priority in the Geforce settings panel for the Titan as top card so now when I work (render) the Titan takes on all the work and my other card is pretty free to still surf net, work in Photoshop etc.
                                    I did a test using a Thea bench mark scene.
                                    Opening file "C;\ProgramData\Thea Render/Scenes/Benchmark/Presto/MeccanoPlane/MeccanoPlane.scn.thea"
                                    Finished in 0 seconds!
                                    Device #0; GeForce GTX TITAN
                                    Building Environment... done. (0.305 seconds)
                                    - Polys; 503556, Objects; 91, Parametric; 0
                                    - Moving; 0, Displaced; 0, Clipped; 0
                                    - Instances; 0, Portals; 0
                                    - Nodes; 158062, Leaves; 158063, Cache Level; Normal
                                    Building Environment... done. (0.315 seconds)
                                    - Nodes; 40851, Leaves; 122554, Cache Level; Normal
                                    Device #1; GeForce GTX 660 Ti
                                    Device #2; Intel(R) Core(TM) i7 CPU 940 @ 2.93GHz
                                    Device #2; memory 4189/12278 Mb
                                    Device #0; memory 503/6144 Mb
                                    Device #1; memory 476/3072 Mb
                                    Device #1; 205 s/p
                                    Device #0; 538 s/p
                                    Device #2; 140 s/p
                                    Finished in 5 minutes and 2 seconds!
                                    That's s/p 883.
                                    When beta testing (without Titan) I got s/p 330.
                                    As you can see Thea used the Titan the 660 and the CPU.
                                    So as you can see the Titan made my rendering almost 3x faster.
                                    • L
                                      Liverpudlian82
                                      That's s/p 883.
                                      Thx for the update. Appreciated! πŸ‘
                                      • L
                                        liam887
                                        Next purchase Pete:
                                        http://www.maximumpc.com/intel_release_8-core_haswell-e_desktop_processors_third_quarter_2014
                                        • soloS
                                          @liam887 said:
                                          Next purchase Pete:
                                          Firstly can you imagine the price?
                                          I was looking at a dual Xeon system recently but decided to rather stick with my very tired 1st generation i7 (never did get the funds to take advantage of the deal I arranged early this year for community) I instead gathered up all my sheckles, borrowed a few from wife and bought a Titan card instead.
                                          My thinking...
                                          What do I need a computer for, well it's modeling, rendering and animation, so with Thea now being GPU and as an insider i know it will only get better and support all features very soon, so I really needed GPU power as animation pretty much is all GPU, and now I only render with GPU and with my new 6GB card even heavy scenes are a breeze, so why need more CPU? In fact the Titan card extends my machine another year...at least that is what I hope.
                                          • L
                                            liam887
                                            Indeed. Rumours is will be priced around 1k.
