    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 402.6k Views 80 Watching
      dtrarch
      Hi Anton
      Good news to be able to drag.
      Will it lock to other SU captions ?
      Very handy to set a typ screen org for templates.
      Here is how I use them in any case.
      (in line here)
      SU Window Settings is on screen #2
      Your plugin should have been part of SU from the very beginning.
      Thanks for getting back too.
      Dave
        Anton_S
        4.1.0 has been released!
        • Added pick, drag and clip feature to the new dialog.
        • Made borders hide faster.
        • Added localization to dialog.
        Click on green caption to drag the dialog, easy as that...
          dtrarch
          Anton
          V4.1.0 did not drag (or move) green title and would not close menu when arrow was clicked.
          SU title hide was still slow.
          Show/Hide toolbars and dialogs killed all my on screen settings for both when invoked.
          Sorry
          Dave
            Anton_S
            @dtrarch said:
            Anton
            Sorry
            Dave
            It works well on my windows 7. What operating system are you using and what internet explorer version?
            Edit: I tested on my Windows XP (with IE9) and it doesn't work just like you described. There is not much I can do about compatibility other than retrieving the original version. So, if you use IE9, use the old version which is compatible in SU2014 and below. You need AMS Library 1.0.9 for the old version too. Here are the links:
            ams_lib_1.0.9.zip
            ams_WindowSetttings_3.8.1.zip
              dtrarch
              Hi Anton
              I have Win 7 pro
              SU 2015 pro
              (this is the problem SU version)
              (Not much else installed)
              Tig extrude lines.rb
              Wiki tools
              Works fine on SU 2014 Pro
              Firefox browser most updated
              Win Explorer 11 installed
              Dave
                Anton_S
                Ok, I will look into it
                  Anton_S
                  By your screenshots I noticed you're using windows classic theme. If that so, try settings it to aero theme in see how it goes.
                    dtrarch
                    Hi Anton
                    I tried Aero and no change. 😒 😒
                    Dave
                      Anton_S
                      In prior post you mentioned that works fine in SU2014, but not in SU2015. If that so, are you speaking of version 4.1.0? I.E do you have 4.1.0 installed on both SU versions? With regards to that, do you have AMS Library 2.0.0 installed in SU2014 and SU2015?
                        dtrarch
                        Anton
                        Here are my setups for your plugin.
                        SU 2014 Pro (works properly)
                        Lib 1.0.8
                        Win 3.8.0
                        SU 2015 Pro 64
                        Lib 2.0.0
                        Win 4.1.0
                        Perhaps the problem is in not having the SU title stay with your menu(s)then attached.
                        In SU 2014 I select the SU title to drag and your menus stick to it and go along with it when dragged.
                        Also my SU 2015 is 64 bit version.
                        Hope that helps
                        Dave
                          Anton_S
                          Version 4.1.5 Had been released!
                          • Fixed pick and drag bug.
                          • Adjusted close button size.
                          • Disabled high contrast optimization.
                          • Made compatible with IE9.
                          Thanks do dtrarch for reporting the bug.
                            dtrarch
                            Noel Anton
                            FYI
                            Last update works properly but when moved to second screen and saved as template/file your title/pull down menu location is not remembered.
                            It shows up on primary screen as SU title and then changes to your title when moved.
                            I know you do not like the way the SU tiles look but I think this SU title must stick/remain when moved so that the saved file can remember the location as a SU function.
                            Thanks again so much for all your good work and this super Plugin. πŸ‘ πŸ‘ πŸ‘
                            Cheers
                            Dave
                              Anton_S
                              MMMOkay, I will look into this. πŸ˜‰
                                dtrarch
                                Hi Anton
                                Any chance to look at the Menu/remember location question.??? πŸ’­
                                In any case.
                                Happy New Year in the Wetlands of Ore.
                                Dave
                                  Anton_S
                                  Sorry, I forgot.
                                  There, try this one! There was literally a bug in script that moved the dialog to the upper right corner of the viewport. I think it is fixed now. I would like you to verify it before I post it to the PluginStore though.
                                  Here it is:
                                  [attachment=0:3bp9dg2h]<!-- ia0 -->ams_WindowSettings_4.2.0.zip<!-- ia0 -->[/attachment:3bp9dg2h]
                                    dtrarch
                                    Anton
                                    I checked multiple times and good news as it sticks as SU Title on selected screen or window location.
                                    The select mode to access your menu is a little odd as when the SU title is selected one must then move the cursor off the title box and then the Window Settings title shows but is greyed out until the pull down arrow is selected.
                                    Double click on SU title has no effect to get the WS menu.
                                    Hmmmmm??
                                    Dave
                                      Anton_S
                                      Okay, thanks for the good news.
                                      Are you asking why WindowSettings drop-down menu doesn't activate when you select the WindowSettings title bar, move the cursor, and then deselect it?
                                      That's because the title bar is designed for two purposes. One to move it and the other to activate the drop-down. It will be odd if the person moves the dialog and figures that the drop-down has activated too.
                                      So, here is how it works:
                                      If user selects the title bar without moving the cursor the drop-down mode is activated.
                                      If user selects the title bar and moves the cursor (while the mouse button is down) the move mode is activated.
                                      Is that what you were indicating odd?
                                        dtrarch
                                        OK Anton
                                        Yes it works as you have intended and described. πŸ‘ πŸ‘
                                        I guess when I saw the SU title box I expected to double click on it to get/select your Green title bar/options.
                                        I did not expect to have to move off the SU title bar to get to your app.
                                        That's all. β˜€
                                        Thanks for all the trouble too.
                                        Dave
                                          Anton_S
                                          Thanks for confirming.
                                          I posted the new release and added usage instructions.
                                          • shake1S Offline
                                            shake1
                                            Hi, first of all, - thanks for the plug!
                                            Question: when I click "hide floatin dialogs" v-ray windows are still visible.
                                            Is it possible to do these windows have been hiding?
                                            Win 7/64
                                            SU 2015/64
                                            V-ray 2/64
                                            http://i.imgur.com/5i0Bzsa.jpg
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
