Transformation (copy) by vector and distance ?
hi experts,
i did not really find an answer in the api, sowhen i draw a 3d line (any direction) ,
can i take it's vector and then transfom an object from its origin (= startpoint of my vector)
ALONG this vector with a defined (@distance_z) distance ?instead of calculation the target 3d-point ? this would make placing object along a line much easier.
thanx stan
If
@drawn
is an edge, then:from = @drawn.start.position move_vec = from.vector_to(@drawn.end.position)
hi dan,
ok, this one moves any object along the vector , but for this i have again to calculate the start and end point of the edge first.the question is, when i already have a calulated and drawn line of any length,
how can i move along this line (=vector) by defining a DISTANCE (in the 3d-direction of this line?so the endpoint would be calculated automatically by the ruby ?
like:
vector = edge xxx
object = whatever
distance = float-value
object.move (vector, distance)stan
startp = edge.line[0] ### edge.line is [start_point, vector_to_end_point]
vector = edge.line[1]
object = reference_to_a_group_or_instance
distnc = a_length ### 1.234.m etc, remember that a float is always taken as 'inches'
vector.length = distncthen
object.move!(vector)
or
object.transform!(vector)
IF moving a
Group
:vector = edge.start.position.vector_to(edge.end.position) group = whatever distance = edge.length vector.length = distance group.move!(vector)
P.S: use
transform!
instead ofmove!
, if you want the operations on the undo stack. -
IF moving an primitive object:
vector = edge.start.position.vector_to(edge.end.position) group = whatever distance = edge.length vector.length = distance object.parent.entities.transform_entities( vector, object )
hi dan,
i came now back to this part of the ruby.
is it possible to COPY instead of MOVE somehow? i tried several things, but ther is nogroup.copy!
obviously in the ruby syntax.
the trial of mine:
#within a bigger loop >>> FL #..... new_line1 = @entities2.add_line @rl1a, @rl2a # define line for vector length = new_line1.length # rasterarray_h = length.divmod(5.0/@faktor/@teiler_cm ) # gaps shall be near 5 cm raster = length / rasterarray_h[0] # calculate gap between verticals ( == true length) # @stab = @entities2.add_group @stab.name = "stab_senkrecht" entities_stab = @stab.entities # the group to be copied along new_line1 @rl1a = [(fl)* const1+var2*var3 , (fl)* const2+var4 , 0 + (fl)*(@pmod * @rise)+@railsgapunten] @rl2a = [(fl)* const1+var2*var3 , (fl)* const2+var4 , 0 + (fl)*(@pmod * @rise) + var6+@railsgapunten] # edge = entities_stab.add_line @rl1a, @rl2a # create 1st vertical in the group # puts "#{__LINE__} ; edge created" puts "#{__LINE__} ; raster ; #{raster}" puts "#{__LINE__} ; length ; #{length}" puts "#{__LINE__} ; rasterarray_h[0] ; #{rasterarray_h[0]}" # for v_line in 1..rasterarray_h[0] # copy group along new_line1 in distance raster #puts v_line vector = new_line1.start.position.vector_to(new_line1.end.position) vector.length = v_line*raster # every step 1 raster more #@stab.move!(vector) # TRIAL 1 ??????? #@stab.parent.entities.transform_entities( vector, @stab ) # TRIAL 2 ??????? end # v_line loop
thanx for helping again. copying in 3d by distance would be a great step further......
stan
http://www.sketchup.com/intl/en/developer/docs/ourdoc/group.php#copy
group2 = group.copy
This makes a copy of the group exactly on the top of original group, AND in the same context as the original group***.
You can then transform that copy.group2.transform!(some_transformation)
Be aware that this group2 copy is a 'second instance' of the original group, so any changes you make to one will appear in the other [just like with a component] - you can use
group2.make_unique
to resolve this; it will generate a warning about deprecated methods BUT this is a known error in the API code and should be removed one day when the API is upgraded...Also be aware that group.copyt can fall foul of some entities-observers from other tools, and cause them to splat - it's a known bug in the API and should get fixed one day...
***Another way to add a 'copy' of a group, BUT put it into another context uses this:
group2 = another_entities.add_instance(group.entities.parent, group.transformation)
Then transform the group2 as desired...
You can of course apply the new group's transformation as you add its instance...
Here's an example including the make_unique...group2 = another_entities.add_instance(group.entities.parent, another_transformation) group2.make_unique
To do it in the same context use:
group2 = group.parent.entities.add_instance(group.entities.parent, another_transformation) group2.make_unique
hi tig,
thanx so much, but this one really makes me crazy.....what ever i do , the move! - instructions MOVES but does not copy, it's magical...( i tried all your codes, the code from the api....)
my code so far ( i am on the level of @entities2 (coming from a method above this one)
new_line1 = @entities2.add_line @rl1a, @rl2a # define line for vector length = new_line1.length # rasterarray_h = length.divmod(5.0/@faktor/@teiler_cm ) raster = length / rasterarray_h[0] # calculate gap between verticals ( == true length) # # so the raster is the 3d-distance on the vector from new_line1 # group = @entities2.add_group entities_stab = group.entities @rl1a = [(fl)* const1+var2*var3 , (fl)* const2+var4 , 0 + (fl)*(@pmod * @rise)+@railsgapunten] @rl2a = [(fl)* const1+var2*var3 , (fl)* const2+var4 , 0 + (fl)*(@pmod * @rise) + var6+@railsgapunten] # edge = entities_stab.add_line @rl1a, @rl2a # create 1st vertical # #entities = @entities2 # tried this, too.. # for v_line in 1..rasterarray_h[0] # vector = new_line1.start.position.vector_to(new_line1.end.position) distance = v_line*raster vector.length = v_line*raster/2 # group2 = group.copy group2 = group.move!(vector) # and the line is moved, not copied....or the original group disappears? there shold be lots of vertical lines in distance of "raster"..... # end #
grrrrhhh....
i make a break now, the brain is just about to explode.......stan
group2 = group.copy group2.move!(vector)
Should leave group where it was ???
