    Access database files
    11 Posts 4 Posters 6.1k Views 4 Watching
      swajime
      I'm trying to connect to an Access database file, but I'm getting an error "unknown OLE server" error.
      From SketchUp's ruby console:
      require 'win32ole'
      true
      connection=WIN32OLE.new('ADOBD.Connection')
      Error; #<WIN32OLERuntimeError; (eval);27;in `initialize'; unknown OLE server; `ADOBD.Connection'
          HRESULT error code;0x800401f3
      I must be missing something. How do I open an Access database file?
      Thanks,
      John
        You need to do some homework on how to call a method from WIN32OLE
        http://www.nntp.perl.org/group/perl.beginners/2006/03/msg81806.html
        http://rubyonwindows.blogspot.co.uk/2007/06/using-ruby-ado-to-work-with-ms-access.html
        Isn't it ADODB NOT ADOBD !!!! ๐Ÿ˜’
          swajime
          Thanks for the quick reply and the homework assignment.
          I switched ADOBD to ADODB like you said (silly me) ... but I still have the same error. I don't get far enough to call any WIN32OLE functions.
          connection = WIN32OLE.new('ADODB.Connection')
          Error; #<WIN32OLERuntimeError; (eval);27;in `initialize'; unknown OLE server; `ADODB.Connection'
            swajime
            I should also mention that I'm not usning Windows. I'm using Sketchup 2013 in wine-1.6 on Ubuntu 12.04.3. I installed WIN32API.so and WIN32OLE.so as directed in this thread -> http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=42732%26amp;p=500870.
              So if connection = WIN32OLE.new('ADODB.Connection') fails you can't do it in Linux ? ๐Ÿ˜•
              At least not without changing something...
                swajime
                Hmmm ... I'm hoping that that isn't the case.
                WIN32OLE has methods ... I would think that if the methods exist that they would work?
                WIN32OLE.methods
                ["const_load", "const_missing", "new", "methods", "allocate", "protected_instance_methods", "include?", "taint", "class_eval", "instance_variable_defined?", "name", "ole_free", "class_variables", "__id__", "singleton_methods", "private_instance_methods", "respond_to?", "nil?", "ancestors", "ole_reference_count", "__send__", "protected_methods", "tainted?", "untaint", "instance_of?", "equal?", "method", "method_defined?", "ole_show_help", "class_variable_defined?", "private_methods", "hash", "constants", "send", "autoload", "kind_of?", "freeze", "eql?", "public_method_defined?", "object_id", "codepage", "id", "codepage=", "public_methods", "connect", "instance_eval", "const_get", "is_a?", "private_method_defined?", "type", "superclass", "instance_variables", "autoload?", "frozen?", "const_set", "to_a", "protected_method_defined?", "instance_method", "class", "public_class_method", "<=>", "instance_variable_get", "==", "===", "to_s", "extend", "instance_methods", ">=", "<=", "clone", "private_class_method", "const_defined?", "included_modules", "instance_variable_set", "=~", "<", ">", "inspect", "public_instance_methods", "display", "dup", "module_eval"]
                • BoxB Offline
                  Can you get to work with an excel file, because you can always link an access to an excel.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    REAL Windows comes along with ODBC drivers that support ADO, ADOX, etc.
                    In %windir%\system32 we have the odbcad32.exe utility that "Maintains ODBC data sources and drivers." (quoted from the comment in it's file properties)
                    So check into Wine and see if you need to install some ODBC 3rd party support.
                    Google Search: "odbc under wine" These hits look promising:
                    NativeOdbc - The Official Wine Wiki
                    Below is a tutorial for getting native Windows ODBC drivers working under Wine. Access 2000 can work with Wine, but this how-to doesn't ...
                    Using Windows ODBC drivers - Wine
                    • In fact, some like MSSQL > can > only be accessed on Linux through a Winelib app. Rather than > just copying DLL files, most ODBC drivers ...
                      ... and many more hits ...
                    like: [SOLVED] Howto connect MS ACCESS to MySQL with ODBC in wine ...
                    MSDN REFERENCES:
                    ADO
                    ADO Programmer's Guide
                    ADO Programmer's Reference
                    Microsoft OLE DB Provider for ODBC
                    MS Access uses Jet
                    Microsoft OLE DB Provider for Microsoft Jet
                    ๐Ÿ’ญ
                    I'm not here much anymore.
                      Dan Rathbun
                      Just for ref... on Win7 the "goods" are located in this directory and subdirs:
                        swajime
                        On a Windows Vista machine that I have access to, ADODB.Connection appears to be working, but attempting to work with Excel.Application is not working:
                        C;\Users\john>type xls.rb
                        require 'win32ole'
                        excel = WIN32OLE;;new('Excel.Application')
                        # access = WIN32OLE;;new('ADODB.Connection')
                        puts "Hello, World"
                        C;\Users\john>ruby xls.rb
                        xls.rb;2;in `initialize'; unknown OLE server; `Excel.Application' (WIN32OLERunti
                        meError)
                              Invalid class string
                                from xls.rb;2;in `new'
                                from xls.rb;2;in `<main>'
                        Neither work on the linux box.
                          Dan Rathbun
                          I stumbled onto this download at Microsoft (looking for something else.)
                          Microsoftยฎ SQL Serverยฎ ODBC Driver 1.0 for Linux
                          The Details say it's for 64bit RedHat 5/6. (But maybe if your Linux uses the same Core..)
                          ๐Ÿ’ญ
