    Can dynamic Components be scaled from the center of part?
    Scheduled Pinned Locked Moved Dynamic Components
    3 Posts 2 Posters 892 Views 2 Watching
    • V Offline
      Vigy
      Hi there,
      Can dynamic Components be scaled from the center of part? So I can insert a hole or a 45 degree cut-out and they should still stay the same position and size?
      Please link me if this topic already exists. Thanks!
        pcmoor
        Yes, can when creating by positioning the axis at the centre or position you want. You can also move or place the axis afterwards by opening the component, right clicking the axis, (context menu) and picking place. A warning will ensue but if should be okay provided you have not already place position attributes formulas within the component already (if I change at a later date I check that X,Y,Z have no formulas or redo them to suit)
        Philip
        • V Offline
          Vigy
          Thanks Pcmoor for your respond, but I was referring to something else, Perhaps I didn't explain myself correctly, Sorry! besides I found a relative discussion where you do anticipate so I will continue there…
          Topic: Variable Rabbet and Dado Depth/Width for a Dynamic Component
          Thanks again! Vigy.
