    Transforming an array of points
    27 Posts 7 Posters 2.2k Views 7 Watching
    • jolranJ
      jolran
      Yes there is. Create a Geom::BoundingBox object and add points to it.
      However I do not see a transform method that applies to bounding boxes
      ☀ Forgot about that one. Will be useful, even if not in this case.
      I think that we gain performance in the actual transform but may loose it accessing the points in the mesh.
      If polygonmesh.polygons returned arrays of Points that woulden't be the case.
      Have you tried recollecting points to a new Array and Transform! them in place ?
      Array.Dup does not work with Point3D objects 😞
      As far as I know one have to recollect points into new Array. Comes with a timecost of course..
      • jolranJ
        jolran
        Ok. Did some tests and it seams like Polygonmesh transform scales quite well.
        Note this test may not be constructed optimaly, I'm still green. But still quite interesting to see how fast polygonMesh transforms many Points.
        The test might provide different result if arrays are flattended, but I need to keep the polygon/Points hierarchy.
        Edit: I saw that newlist actually don't keep the hierarchy So the result would probably be slower. Can't really Output the result in ruby consol 😉
        # Square Polygon
        pts = [
          Geom;;Point3d.new(-5,-5,0),
          Geom;;Point3d.new(5,-5,0),
          Geom;;Point3d.new(5,5,0),
          Geom;;Point3d.new(-5,5,0)
        vec = [10,0,0]
        tr = Geom;;Transformation.new( vec )
        # Create som polygons for testing..
        polys = {}
        vec2 = vec.clone
        for i in 0...50
          polys[i] = pts.collect{|pt| pt.offset(vec2) }
          vec2.offset!([15,10,0])
        # Mesh
        msh = Geom;;PolygonMesh.new
        for k,v in polys
          msh.add_polygon(v)
        # Array of points
        polygonials = polys.values
        puts "total nr Point3dObjects; #{polygonials.flatten.length}"
        #group = Sketchup.active_model.active_entities.add_group
        #group.entities.fill_from_mesh(msh, true, 12)
        #Tests On My computer Gave;
        #PolygonMesh Transforms; 0.03
        #Array Transforms; 1.052
        #Array Transforms And Collect; 2.335
        start = Time.now
        10000.times {
            msh.transform!(tr)
        puts "PolygonMesh Transforms; #{Time.now - start}"
        start = Time.now
        10000.times {
        for list in polygonials
          for p in list do p.transform!(tr) end
        puts "Array Transforms; #{Time.now - start}"
        start = Time.now
        newlist = []
        10000.times {
          newlist << list.collect{|p| p.transform(tr) }
        puts "Array Transforms And Collect; #{Time.now - start}"
        • G
          Garry K
          What about a benchmark for a hash?
          • jolranJ
            jolran
            start = Time.now
            10000.times {
            for key,val in polys
              for p in val do p.transform!(tr) end
            puts "Nested Hash Transforms; #{Time.now - start}" # => 1.274
            It is a Hash? If I don't nest the Hash the "polygon-Points" relation will be impossible to retrieve afterwards:
            Hash = { 0 => [pt,pt,pt,pt] etc }
            Do you mean 1 layer Hash structure { key => pointd3d etc } ?
            There may off course be better structures for this, I'm all ears.
            Edit: I tried running each test separately muting the other timers with following result:
            PolygonMesh Transforms: 0.047
            Nested Hash Transforms: 1.191
            Array Transforms: 1.066
            Array Transforms And Collect: 2.328
            Maybe I'm confusing the matter... And I haven't outputed the resulting mesh(which would stall Sketchup) so there is a matter of knowing if the resulting Mesh is qualified as well.
            • jolranJ
              jolran
              Ah you mean put result in Hash ?
              start = Time.now
              newHash = {}
              10000.times {
              for i in 0...polygonials.length
                newHash[i] = polygonials[i].collect{|p| p.transform(tr) }
              puts "HASH Transforms And Collect; #{Time.now - start}"
              =>2.381
              • G
                Garry K
                You could render the mesh after the timers to maintain benchmark validity.
                Have you tried traversing your polygons?
                mesh.polygon_points_at( index )
                Shouldn't this give you the same results as an outer_loop on a face?
                The question I would have is although you can get the points for each polygon - Is there a way to tie in a reference to the faces in the model once you have rendered the mesh?
                I would hope that the entities in the group immediately after a fill_from_mesh would be in mesh polygon index order. So there should be a 1 to 1 relationship.
                I haven't played with hashes yet - so my question is probably confusing to you. Although I've programmed for many years and also played with CAD for many years I've only logged 3 or so months with Sketchup since I got serious about it (guess I caught the Sketchup virus).
                • jolranJ
                  jolran
                  Yeah, for those tests that edit in Place. Otherwise it would be too intense for Sketchup.
                  I'm just moving Points in this code. I reckon you'd have to recollect faces afterwards
                  and do some boolean tests. There's normal_at which could be used for ex.
                  It all depends on (referring to your other question) if face order == polygon index order. I should test that as well unless someone else already knows..
                  I'm pretty new to programming, so there can be lots of holes in the logic of my tests.
                  But what better way to learn than trying to solve a problem, right?
                  Hashes in Ruby are supposed to have much faster lookup than arrays. I think that's what Thomthom tried to point out earlier.
                  • tt_suT
                    tt_su
                    Geom::PolygonMesh.points? http://www.sketchup.com/intl/en/developer/docs/ourdoc/polygonmesh.php#points
                    • G
                      Garry K
                      Sorry - bad terminology. I was talking read and write access.
                      the only write access we have is mesh.add_point.
                      I'm still thinking as a C / C++ programmer.
                      • tt_suT
                        tt_su
                        PolygonMesh.set_point
                        http://www.sketchup.com/intl/en/developer/docs/ourdoc/polygonmesh.php#set_point
                        • jolranJ
                          jolran
                          Yet Another test 👊
                          Don't know how reliable this test is but it appears face get appended in the same order as indexed in Polygonmesh. But Polygonmesh Count indexes starting at 1.
                          Edit: Updated for adding c_point in polygonmesh index as well. But wonder how hidden edges affect the Index ordering..
                          The API says:
                          The negative values should not be used as an index for point_at, take the positive value of the index value in the polygon array
                          Perhaps hidden edges will only happend if mesh is constructed from a collection of Sketchup::Face's. Not relevant in this case.
                          In that case maybe use index.abs or perhaps double negation: index = index<0 ? -index : index
                          ents = Sketchup.active_model.active_entities
                          def centerpoints(f)
                            cx = (f[0].x + f[1].x + f[2].x + f[3].x)/4
                            cy = (f[0].y + f[1].y + f[2].y + f[3].y)/4
                            cz = (f[0].z + f[1].z + f[2].z + f[3].z)/4
                            return Geom;;Point3d.new(cx, cy, cz)
                          face1 = [
                            Geom;;Point3d.new(-5,-5,0), Geom;;Point3d.new(5,-5,0),
                            Geom;;Point3d.new(5,5,0), Geom;;Point3d.new(-5,5,0)
                          #create points for 4 faces
                          faceHash = {}
                          for i in (0...4)
                             faceHash[i] = face1
                             face1 = face1.collect{|pt| pt.offset([20,0,0])}
                          #get refference to the center of "face"#3 Before appending to mesh.
                          fC = centerpoints(faceHash[2])
                          ents.add_cpoint(fC)
                          # Bit strange to loop hash this way, but they get ordered.
                          for n in (0...faceHash.length)
                            msh.add_polygon(faceHash[n])
                          #Test PolygonMesh index. How does hidden edges affect indexes for this ?
                          # +1 index for polygons in Mesh. 2 c_points should get added at same spot
                          meshface3 = msh.polygon_points_at(2+1)
                          mc = centerpoints(meshface3)
                          ents.add_cpoint(mc)
                          group = ents.add_group
                          group.entities.add_faces_from_mesh(msh)
                          faces = group.entities.grep(Sketchup;;Face)
                          #Red material to face 3
                          faces[2].material = "red"
                          • 2 / 2
