    Transforming an array of points
    27 Posts 7 Posters 1.9k Views 7 Watching
    • G
      Garry K
      That is why I suggested it would be a viable option in some circumstances.
      I think that we gain performance in the actual transform but may loose it accessing the points in the mesh.
      If there was a bulk operation to move points from one mesh to another without invoking the built in check - then you would probably benefit even on a smaller data set.
      • Dan RathbunD
        Dan Rathbun
        @jolran said:
        So there is a way to group Point3d objects ?
        Yes there is. Create a Geom::BoundingBox object and add points to it.
        However I do not see a transform method that applies to bounding boxes.
        I'm not here much anymore.
        • jolranJ
          jolran
          ☀ Forgot about that one. Will be useful, even if not in this case.
          If polygonmesh.polygons returned arrays of Points that woulden't be the case.
          Have you tried recollecting points to a new Array and Transform! them in place ?
          Array.Dup does not work with Point3D objects 😞
          As far as I know one have to recollect points into new Array. Comes with a timecost of course..
          • jolranJ
            jolran
            Ok. Did some tests and it seams like Polygonmesh transform scales quite well.
            Note this test may not be constructed optimaly, I'm still green. But still quite interesting to see how fast polygonMesh transforms many Points.
            The test might provide different result if arrays are flattended, but I need to keep the polygon/Points hierarchy.
            Edit: I saw that newlist actually don't keep the hierarchy So the result would probably be slower. Can't really Output the result in ruby consol 😉
            # Square Polygon
            pts = [
              Geom;;Point3d.new(-5,-5,0),
              Geom;;Point3d.new(5,-5,0),
              Geom;;Point3d.new(5,5,0),
              Geom;;Point3d.new(-5,5,0)
            vec = [10,0,0]
            tr = Geom;;Transformation.new( vec )
            # Create som polygons for testing..
            polys = {}
            vec2 = vec.clone
            for i in 0...50
              polys[i] = pts.collect{|pt| pt.offset(vec2) }
              vec2.offset!([15,10,0])
            # Mesh
            msh = Geom;;PolygonMesh.new
            for k,v in polys
              msh.add_polygon(v)
            # Array of points
            polygonials = polys.values
            puts "total nr Point3dObjects; #{polygonials.flatten.length}"
            #group = Sketchup.active_model.active_entities.add_group
            #group.entities.fill_from_mesh(msh, true, 12)
            #Tests On My computer Gave;
            #PolygonMesh Transforms; 0.03
            #Array Transforms; 1.052
            #Array Transforms And Collect; 2.335
            start = Time.now
            10000.times {
                msh.transform!(tr)
            puts "PolygonMesh Transforms; #{Time.now - start}"
            start = Time.now
            10000.times {
            for list in polygonials
              for p in list do p.transform!(tr) end
            puts "Array Transforms; #{Time.now - start}"
            start = Time.now
            newlist = []
            10000.times {
              newlist << list.collect{|p| p.transform(tr) }
            puts "Array Transforms And Collect; #{Time.now - start}"
            • G
              Garry K
              What about a benchmark for a hash?
              • jolranJ
                jolran
                start = Time.now
                10000.times {
                for key,val in polys
                  for p in val do p.transform!(tr) end
                puts "Nested Hash Transforms; #{Time.now - start}" # => 1.274
                It is a Hash? If I don't nest the Hash the "polygon-Points" relation will be impossible to retrieve afterwards:
                Hash = { 0 => [pt,pt,pt,pt] etc }
                Do you mean 1 layer Hash structure { key => pointd3d etc } ?
                There may off course be better structures for this, I'm all ears.
                Edit: I tried running each test separately muting the other timers with following result:
                PolygonMesh Transforms: 0.047
                Nested Hash Transforms: 1.191
                Array Transforms: 1.066
                Array Transforms And Collect: 2.328
                Maybe I'm confusing the matter... And I haven't outputed the resulting mesh(which would stall Sketchup) so there is a matter of knowing if the resulting Mesh is qualified as well.
                • jolranJ
                  jolran
                  Ah you mean put result in Hash ?
                  start = Time.now
                  newHash = {}
                  10000.times {
                  for i in 0...polygonials.length
                    newHash[i] = polygonials[i].collect{|p| p.transform(tr) }
                  puts "HASH Transforms And Collect; #{Time.now - start}"
                  =>2.381
                  • G
                    Garry K
                    You could render the mesh after the timers to maintain benchmark validity.
                    Have you tried traversing your polygons?
                    mesh.polygon_points_at( index )
                    Shouldn't this give you the same results as an outer_loop on a face?
                    The question I would have is although you can get the points for each polygon - Is there a way to tie in a reference to the faces in the model once you have rendered the mesh?
                    I would hope that the entities in the group immediately after a fill_from_mesh would be in mesh polygon index order. So there should be a 1 to 1 relationship.
                    I haven't played with hashes yet - so my question is probably confusing to you. Although I've programmed for many years and also played with CAD for many years I've only logged 3 or so months with Sketchup since I got serious about it (guess I caught the Sketchup virus).
                    • jolranJ
                      jolran
                      Yeah, for those tests that edit in Place. Otherwise it would be too intense for Sketchup.
                      I'm just moving Points in this code. I reckon you'd have to recollect faces afterwards
                      and do some boolean tests. There's normal_at which could be used for ex.
                      It all depends on (referring to your other question) if face order == polygon index order. I should test that as well unless someone else already knows..
                      I'm pretty new to programming, so there can be lots of holes in the logic of my tests.
                      But what better way to learn than trying to solve a problem, right?
                      Hashes in Ruby are supposed to have much faster lookup than arrays. I think that's what Thomthom tried to point out earlier.
                      • tt_suT
                        tt_su
                        Geom::PolygonMesh.points? http://www.sketchup.com/intl/en/developer/docs/ourdoc/polygonmesh.php#points
                        • G
                          Garry K
                          Sorry - bad terminology. I was talking read and write access.
                          the only write access we have is mesh.add_point.
                          I'm still thinking as a C / C++ programmer.
                          • tt_suT
                            tt_su
                            PolygonMesh.set_point
                            http://www.sketchup.com/intl/en/developer/docs/ourdoc/polygonmesh.php#set_point
                            • jolranJ
                              jolran
                              Yet Another test 👊
                              Don't know how reliable this test is but it appears face get appended in the same order as indexed in Polygonmesh. But Polygonmesh Count indexes starting at 1.
                              Edit: Updated for adding c_point in polygonmesh index as well. But wonder how hidden edges affect the Index ordering..
                              The API says:
                              The negative values should not be used as an index for point_at, take the positive value of the index value in the polygon array
                              Perhaps hidden edges will only happend if mesh is constructed from a collection of Sketchup::Face's. Not relevant in this case.
                              In that case maybe use index.abs or perhaps double negation: index = index<0 ? -index : index
                              ents = Sketchup.active_model.active_entities
                              def centerpoints(f)
                                cx = (f[0].x + f[1].x + f[2].x + f[3].x)/4
                                cy = (f[0].y + f[1].y + f[2].y + f[3].y)/4
                                cz = (f[0].z + f[1].z + f[2].z + f[3].z)/4
                                return Geom;;Point3d.new(cx, cy, cz)
                              face1 = [
                                Geom;;Point3d.new(-5,-5,0), Geom;;Point3d.new(5,-5,0),
                                Geom;;Point3d.new(5,5,0), Geom;;Point3d.new(-5,5,0)
                              #create points for 4 faces
                              faceHash = {}
                              for i in (0...4)
                                 faceHash[i] = face1
                                 face1 = face1.collect{|pt| pt.offset([20,0,0])}
                              #get refference to the center of "face"#3 Before appending to mesh.
                              fC = centerpoints(faceHash[2])
                              ents.add_cpoint(fC)
                              # Bit strange to loop hash this way, but they get ordered.
                              for n in (0...faceHash.length)
                                msh.add_polygon(faceHash[n])
                              #Test PolygonMesh index. How does hidden edges affect indexes for this ?
                              # +1 index for polygons in Mesh. 2 c_points should get added at same spot
                              meshface3 = msh.polygon_points_at(2+1)
                              mc = centerpoints(meshface3)
                              ents.add_cpoint(mc)
                              group = ents.add_group
                              group.entities.add_faces_from_mesh(msh)
                              faces = group.entities.grep(Sketchup;;Face)
                              #Red material to face 3
                              faces[2].material = "red"
                              • 2 / 2
