    šŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    I have this warning - "importer not found"
    10 Posts 8 Posters 10.5k Views 8 Watching
    • cmeedC Offline
      cmeed
      Does anybody know what has happened my SU? I get "Importer not found" when i try to import......
      on a Mac 10.5.6
      HELP!!! looks bad to me
      chris
      • AndrewSA Offline
        AndrewS
        on a Mac 10.5.6
        chris
        Chris,
        It would help to know the exact text of the whole message, as well as which importer you were trying to use at the time. And are we talking Free or Pro?
        Andrew S.
        SketchUp Release Engineer
        • cmeedC Offline
          cmeed
          False alarm, I was trying to import files that didn't have the right file name. sorry for the anxious tone to the post. my sketchup life flashed before me as I'd never seen that before. all is well now, apologies for the blip.
          c
            rouke
            Hi, I have the same problem, I“m running SU on mac, pro version, it pops out a warning saying: "importer not found" I“m trying to import a 2010 autocad file
            • Chris FullmerC Offline
              Could you upload a dwg file that display that message here to the forum for us to look at?
                KingExia
                hi, this morning i tried to import a .dwg file to sketch up and this warning appears instantly: "warning, importer not found". I need to fix it quickly.
                thanks.
                I'm running sketch up pro 8 on Mac osx 10.9, and the .dwg file is 2010.
                  As a Pro user you can contact SketchUp help and provide your license info and they can help you fix it quickly.
                    anthonypearton
                    thanks.
                    Same problem here. Is it a problem with Mavericks compatibility? Any solutions yet?
                      rcavenecia
                      my guess is it is related to Maverics... this never happened to me before... this is disastrous!!
                      • sketch3d.deS Offline
                        sketch3d.de
                        validate that this is a real DWG (and not another format with a renamed file extension) by opening in the free Teigha Viewer f. Mac OS X v10.6+.
                        hth,
                        Norbert
