    Onload issue with web-dialog window on Mac.
    7 Posts 3 Posters 780 Views 3 Watching
    • renderizaR
      renderiza
      I received this suggestion to fix my "Rename by Layer" plugin but I am not sure how to solve it. Can someone help me figure this out? I have no mac so its hard to work bugs for them. πŸ˜•
      In RND_Renamer/rnd_renamer.html:
      Comment on line 8:
      <body onLoad="startup(), stopwatch(this.value);">
      Using BODY onLoad will cause a blank WebDialog windows under OSX when it opens. The content appear after right clicking or resizing. To work around this, move the functions calls from this event to a SCRIPT element at the bottom of the page, or use the DOMContentLoaded event. (Though this need more work for cross browser compatibility unless you use a framework like jQuery.)
      Not sure how to solve it.
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        slbaumgartner
        @renderiza said:
        Comment on line 8:
        Move the script from the onLoad event to the last element in the body. This is a much discussed and criticized aspect of the WebDialog startup on the Mac.
        • renderizaR
          renderiza
          I am sorry but I don't know what you mean by last element in body. 😳
          Can you provide an example:
          <html>
            <head>
            </head>
            <body onLoad="startup();">
            </body>
          </html>
          <script>
            function startup() {
              nextFrame();
          </script>
          Thanks in advance
            slbaumgartner
            <html>
            >   <head>
            >   </head>
            >   </body>
            > </html>
            > <script>
            >     nextFrame();
            > </script>
            Thanks in advance
            Remove the onLoad from <body> and then move the <script> … </script> up as the last element before </body>. You will also need either to invoke the startup() function you have defined after the } or else just call nextFrame(); without the function (if you don't also need it elsewhere). The script will be run as the last step of loading the body on both Windows and Mac.
            • renderizaR
              renderiza
              Thank you so much I think I got it with your help! πŸ‘
              Can't test it since I don't have a Mac but will upload an update in hopes that someone can verify if it works. Again thank you very much!
              • tt_suT
                tt_su
                If your code looked like this:
                <html>
                  <head>
                  </head>
                  <body onLoad="nextFrame()">
                  </body>
                </html>
                Change it to this:
                <html>
                  <head>
                  </head>
                  <body>
                  <script>
                    nextFrame();
                  </script>
                  </body>
                </html>
                That will prevent the initial white dialog under OSX.
                On a sidenote, I always recommend jQuery or similar frameworks. They take care of most cross compatibility issues - even in this case because jQuery.ready() event uses the DOM ready event which doesn't cause any white out.
                • renderizaR
                  renderiza
                  Yes I did that and received feedback from a Mac user that the dialog was loading ok.
                  I will need to study how to implement this for future...thanks!
