    Curved Staircases
    171 Posts 19 Posters 33.1k Views 19 Watching
      Garry K
      Here is a less expensive version of the spiral. No stringer. Spindles hold the outside of the treads.
      No stringer
      • KrisidiousK Offline
        Krisidious
        If you build it I will buy it... How about irregular curves? Free form curved stairs? I tend to get a little wild.
        By: Kristoff Rand
          Garry K
          I'm not sure what you mean by irregular curves.
          But I have been able to reduce all the stairs that I've built into mathematical calculations.
          For me it is all about the pitch of the stair along the travel path. This path is a vertical line between your legs down to the treads which is aprox 20" front the outside of the handrail. The consideration is for adults as kids have shorter legs and are going to be closer to the rail - that is on the shortest path. If the run - thus the pitch - varies too much then you can trip.
          Having said all that - I can design a stair that is very comfortable and yet does not meet the building code or I can design a stair that is not comformatable ( in my opinion not safe ) and yet it meets the building code.
          For me - safety is number 1. I can always make it look good.
          My web site is CabMaker32.com - you can leave me a message. We can then exchange email addresses and perhaps you can send me examples of some stairs.
            Krisidious
            here's some of my "irregular curved staircases"...
            By: Kristoff Rand
              Garry K
              You will probably have to modify a model. Some of the designs that you have wouldn't quite fall into the categories that I have built. Regardless, you would probably still end up saving time even with a modification.
              Here is another variant of the spiral - this one uses a saw tooth stringer and slightly closer spindle spacing.
              Sawtooth Spiral
              • pbacotP Offline
                Thing with spiral stairs, I end up making new ones when the rare occasion arises, in CAD or SU because the rise and style are always different. If I had a couple models with say 9', 10', 11' then they'd at least serve for a quick fill-in for preliminaries.
                  Krisidious
                  I already have a few that make spiral and standard straight, 90 and return stairs... The curved would be my interest like your first examples.
                  By: Kristoff Rand
                    Garry K
                    Here is a stair that is framed on site. It is all about getting the math correct.
                    This stair uses 1" plywood for treads and 3/4" plywood for risers. The risers are dado'd into the tread by 1/2".
                    Bottom and top curved plates are built up with layers plywood.
                      Krisidious
                      that's sweet...
                      By: Kristoff Rand
                      • soloS Offline
                        Up for a challenge?
                          Garry K
                          So Pete - did you build or model this stair?
                          It is doable - but it is one of a kind stair case and would probably have to considered a secondary means of egress ( a utility stair ) as I'm fairly sure the building inspector would give this one a hard time.
                          I'm busy right now working on CNC GCode for my panel optimizer. The curved staircase software that I'm considering building will follow the 80 / 20 rule. A stair like this I would most likely model from scratch.
                            Garry K
                            As far as modeling goes - I was pretty impressed with the ease of use of IRender nxt.
                            Here are a couple of models - a Kitchen and a couple of stairs.
                            Drawn automatically with CabMaker32 and rendered with IRender nxt
                            Rendered with IRender nxt
                              Charlie__V
                              Garry,
                              Nice examples shown. 👍
                              Thought I would share a stair set that I was "forced to build" as the existing framing prohibited conventional stair set options. (rise & run extremely "short" & HVAC tightly roughed over head)
                              Not sure of the proper term for this type of stair set...but "card fan" comes to mind.
                              I maintained 10" tread at the "walk line"........12" "in".
                              Built the stair set as individual "carriages".
                              Cannot seem to locate the actual finished pics....will upload if I find some.
                              Charlie
                              Card Fan......Stair
                                Garry K
                                I would call this stair a modified winder. As far as the Walk Line is concerned - you need to consider the outside edge of the handrail to a distance that is directly vertical between your legs. You also need to look at the speed of egress. This is considered to be moving quickly and moving down the stairs and thus out of the building. The slower that you walk the closer you are to the edge of the stair - the problem of safety is when you are moving quickly. You also have to consider larger people. These considerations dictated our walk line to be 20" from the outside edge.
                                The trick is to build a safe stair - and one that is reasonably easy to build and also easy on the eyes.
                                I would work out calculations to see if it was possible to have a consistent pitch at the inside stringer, the outside stringer and also at the walk line and all the while maintaining a safe stair. That is the challenge.
                                  Garry K
                                  I have started to build the curved staircase plugin.
                                  Hopefully this shows you where I am going with it.
                                  The input box remembers your settings between uses while in the same session.
                                  I may include a text file of defaults that you can change so that your own defaults appear every time you start sketchup and run the Stair Maker.
                                  I plan to add an option so that your stair will straighten out for x treads at top and at bottom. The default will be 0 straight treads. You will also specify the run of the straight treads.
                                  Any feedback during this stage would be much appreciated.
                                  Curved Stair case plugin.
                                    Krisidious
                                    awesome... imperial too?
                                    By: Kristoff Rand
                                      Garry K
                                      Yes it sees what your setup is at startup and stays with that - metric or imperial.
                                      You are stuck with that choice until next startup.
                                      I've got the plugin working so there aren't any extra faces that need to be deleted.
                                      The soften tool shows that up in a hurry.
                                      I have the sawtooth working for open risers (set Riser Thickness to 0.inch or 0.mm). I need to adjust the sawtooth for risers that have thickness.
                                      The Stair width will be overall width of stair which includes the stringer thickness if housed and includes the tread overhang ( same amount as nosing ) if sawtooth.
                                      The only extra work that I have done so far is orient faces and apply the softening.
                                      Not a real big problem.
                                      I want to add in stringer feet and stringer heels which will represent a fair bit of work.
                                      So I'll probably go to treads next. I will create a curved tread as component and then copy rotate and move ( which I believe are transforms - I'll find out when I get there ).
                                      Curved Stair Plugin works in imperial.
                                        Krisidious
                                        That's fantastic Garry... Very exciting.
                                        By: Kristoff Rand
                                          Garry K
                                          I had a bit of issue with some coding - but I believe that I am past that now.
                                          In the mean time. Here are 2 more stairs. The first one has a single center stringer that I set to 120 mm thick and 400 mm wide. The treads are 3 layers of 3/4 plywood glue laminated - so I set the tread thickness to 57 mm. I set the outside stringer to none so it wouldn't build it.
                                          Notice that I told the plugin 0 for riser thickness. I built the stair and then deleted the treads. I did add texture to the stringer and then when the treads were created I added texture to them and then I uses the round corners tool to ease all the treads to 1/2" bullnose.
                                          I ran the plugin a second time ( it remembered all my settings ) and changed the inside stringer to none as well as the inside. I then changed the inside radius to 2400 and built the stair without stringers on top of the first one.
                                          The second stair is an example of an outside concrete stair. In this case I set the outside stringer to none and turned of risers and treads by setting their corresponding thicknesses to 0.
                                          Center stringer
                                          Stair with 1 stringer
                                          Concrete stair
                                            Garry K
                                            Here is an unusual stair case. Anyone up for this challenge?
                                            1 unusual stair
                                            • 9 / 9
