    Curved Staircases
    171 Posts 19 Posters 71.7k Views 19 Watching
    • G
      Garry K
      Here is a stair that is framed on site. It is all about getting the math correct.
      This stair uses 1" plywood for treads and 3/4" plywood for risers. The risers are dado'd into the tread by 1/2".
      Bottom and top curved plates are built up with layers plywood.
      • KrisidiousK
        Krisidious
        that's sweet...
        By: Kristoff Rand
        • soloS
          Up for a challenge?
          • G
            Garry K
            So Pete - did you build or model this stair?
            It is doable - but it is one of a kind stair case and would probably have to considered a secondary means of egress ( a utility stair ) as I'm fairly sure the building inspector would give this one a hard time.
            I'm busy right now working on CNC GCode for my panel optimizer. The curved staircase software that I'm considering building will follow the 80 / 20 rule. A stair like this I would most likely model from scratch.
            • G
              Garry K
              As far as modeling goes - I was pretty impressed with the ease of use of IRender nxt.
              Here are a couple of models - a Kitchen and a couple of stairs.
              Drawn automatically with CabMaker32 and rendered with IRender nxt
              Rendered with IRender nxt
              • C
                Charlie__V
                Garry,
                Nice examples shown. šŸ‘
                Thought I would share a stair set that I was "forced to build" as the existing framing prohibited conventional stair set options. (rise & run extremely "short" & HVAC tightly roughed over head)
                Not sure of the proper term for this type of stair set...but "card fan" comes to mind.
                I maintained 10" tread at the "walk line"........12" "in".
                Built the stair set as individual "carriages".
                Cannot seem to locate the actual finished pics....will upload if I find some.
                Charlie
                Card Fan......Stair
                • G
                  Garry K
                  I would call this stair a modified winder. As far as the Walk Line is concerned - you need to consider the outside edge of the handrail to a distance that is directly vertical between your legs. You also need to look at the speed of egress. This is considered to be moving quickly and moving down the stairs and thus out of the building. The slower that you walk the closer you are to the edge of the stair - the problem of safety is when you are moving quickly. You also have to consider larger people. These considerations dictated our walk line to be 20" from the outside edge.
                  The trick is to build a safe stair - and one that is reasonably easy to build and also easy on the eyes.
                  I would work out calculations to see if it was possible to have a consistent pitch at the inside stringer, the outside stringer and also at the walk line and all the while maintaining a safe stair. That is the challenge.
                  • G
                    Garry K
                    I have started to build the curved staircase plugin.
                    Hopefully this shows you where I am going with it.
                    The input box remembers your settings between uses while in the same session.
                    I may include a text file of defaults that you can change so that your own defaults appear every time you start sketchup and run the Stair Maker.
                    I plan to add an option so that your stair will straighten out for x treads at top and at bottom. The default will be 0 straight treads. You will also specify the run of the straight treads.
                    Any feedback during this stage would be much appreciated.
                    Curved Stair case plugin.
                    • KrisidiousK
                      Krisidious
                      awesome... imperial too?
                      By: Kristoff Rand
                      • G
                        Garry K
                        Yes it sees what your setup is at startup and stays with that - metric or imperial.
                        You are stuck with that choice until next startup.
                        I've got the plugin working so there aren't any extra faces that need to be deleted.
                        The soften tool shows that up in a hurry.
                        I have the sawtooth working for open risers (set Riser Thickness to 0.inch or 0.mm). I need to adjust the sawtooth for risers that have thickness.
                        The Stair width will be overall width of stair which includes the stringer thickness if housed and includes the tread overhang ( same amount as nosing ) if sawtooth.
                        The only extra work that I have done so far is orient faces and apply the softening.
                        Not a real big problem.
                        I want to add in stringer feet and stringer heels which will represent a fair bit of work.
                        So I'll probably go to treads next. I will create a curved tread as component and then copy rotate and move ( which I believe are transforms - I'll find out when I get there ).
                        Curved Stair Plugin works in imperial.
                        • KrisidiousK
                          Krisidious
                          That's fantastic Garry... Very exciting.
                          By: Kristoff Rand
                          • G
                            Garry K
                            I had a bit of issue with some coding - but I believe that I am past that now.
                            In the mean time. Here are 2 more stairs. The first one has a single center stringer that I set to 120 mm thick and 400 mm wide. The treads are 3 layers of 3/4 plywood glue laminated - so I set the tread thickness to 57 mm. I set the outside stringer to none so it wouldn't build it.
                            Notice that I told the plugin 0 for riser thickness. I built the stair and then deleted the treads. I did add texture to the stringer and then when the treads were created I added texture to them and then I uses the round corners tool to ease all the treads to 1/2" bullnose.
                            I ran the plugin a second time ( it remembered all my settings ) and changed the inside stringer to none as well as the inside. I then changed the inside radius to 2400 and built the stair without stringers on top of the first one.
                            The second stair is an example of an outside concrete stair. In this case I set the outside stringer to none and turned of risers and treads by setting their corresponding thicknesses to 0.
                            Center stringer
                            Stair with 1 stringer
                            Concrete stair
                            • G
                              Garry K
                              Here is an unusual stair case. Anyone up for this challenge?
                              1 unusual stair
                              • KrisidiousK
                                Krisidious
                                and I thought I was strange...
                                By: Kristoff Rand
                                • G
                                  Garry K
                                  Plugin is at the next stage. Treads and Risers are finished. Notice that there are still some things to do. The Housed stringer at the bottom and at the top is not finished. I need to extend the housed stringer 2 X Nosing. Also the Nosing on the top riser is missing.
                                  I've added a floor thickness which currently makes the top riser board flush with the floor.
                                  Also added a stair_defaults.txt file which contains a few items that aren't controlled by the input box. Every entry in the input box has a metric and an imperial entry in the text file. So you will be able to set your own defaults like tread thickness and dado values etc.
                                  The Plugin does not bullnose (round over) the treads. I've use the Round Over 3D plugin to accomplish this task as it only takes a couple of minutes. For a sawtooth, housed stair with riser boards I first drew a vertical line on the back of tread 12.7mm from the inside curve.
                                  This is to control the extent of the round over. I then picked the edges that I wanted to round over and then performed the roundover. Notice that it does work properly where the riser board dado is. Just make sure that you pick the edges as in the picture.
                                  Curved Stair showing plugin input box
                                  Rounding over one tread component
                                  After rounding over
                                  • G
                                    Garry K
                                    Here is what the stair_defaults.txt file looks like.
                                    stair_defaults.txt
                                    • G
                                      Garry K
                                      Top nosing and extending housed stringers are now working.
                                      Here is a 180 degree housed, stair with open risers.
                                      To make the handrails I set both the Riser Thickness and Tread Thickness to 0. I then adjusted both stringer widths and stringer thicknesses to 90 mm. This tells the Stair Maker plugin to build handrails and have the tops of the rails at 800 mm above the nosings which is building code for indoor residential stairs.
                                      Stair and rail
                                      • G
                                        Garry K
                                        I have created a video on you tube
                                        http://www.youtube.com/watch?v=TQ94u6bpLq0
                                        • KrisidiousK
                                          Krisidious
                                          that would save me like 3 hours... or maybe more.
                                          By: Kristoff Rand
                                          • G
                                            Garry K
                                            You must be pretty fast. It was taking me the better part of a day to draw stairs. Perhaps because of the amount of detail that I was interested in.
                                            Did you view the You Tube video? What did you think of it? Do you have any suggestions or comments on what I have done so far? Have you been to my website?
                                            With your input, this post could be even better šŸ’—
                                            • 2 / 9
