    Dome
    9 Posts 4 Posters 507 Views 4 Watching
      smhbrv
      Hi everyone. İ need help about my dome.
      That is a triangel and triangel center has got three arcs and these three arcs must be three different dome but i dont do that.
      Please help me, how can i do that ?
      .Skp file in there...
      Thank you.
      abc.skp
      • ely862meE Offline
        ely862me
        Hey there,
        Did you want the triangle to be equilateral ?
        See attached video , if it is what you need .
        [web 100%,396:39vfq5wt]http://www.screenr.com/embed/apDH[/web:39vfq5wt]
        Elisei (sketchupper)
        Come and See EliseiDesign
          smhbrv
          Thank you for your help but floor is not triangle ?
          And triangle is not to be equilateral ?
          • ely862meE Offline
            ely862me
            If the triangle is not equilateral then just make each arch a group and create a circle for the base, then use follow me tool to create the different domes.
            If you have a picture of what you are trying to create would help .
              smhbrv
              I have not picture about that but i want to do this.
              On triangle center, each arc must be a part of part dome.
              Each part is different part of dome on center.
                You can try the free Soap Skin Bubble for have different forms in a second! 😉
                Select a closed 3D line
                Press Skin button
                A group is created
                Select this group
                Press twice Enter
                press pressure button
                Enter + - pressure
                You can enter a tensile ratio when a group is selected
                http://forums.polyloop.net/imagehosting/196491035cd97702.jpg
                • BoxB Offline
                  Is this the shape you want?
                  • ely862meE Offline
                    ely862me
                    Ahh, indeed that is way different from what I've done.
                    Box's attempt seems to be what you are looking for,isn't it? I believe he used Curviloft plugin to do that .
                    • BoxB Offline
                      I actually used Tig's Extrude tools, but Curviloft would certainly do it.
