SketchyPhysics doesn't install
Hie. In application support/ google sketchup 8 / i create a folder named "plugins". I puted the decompressed folder sketchyphysic in.
But it just don't work when i launch sketchup. Any has the same problem ?
thank -
SketchyPhysics it's an installer (.exe) so you need to run it not place it into the Plugins folder.
Just a head's up if you decide to go forward with using SketchyPhysics...it's on the Quarantine list because it interferes and modifies some things about SketchUp.
You can of course still install and use it, just know that you might get some funky behavior and busted tools/behavior. I didn't know this when I first used it, and it gave me a lot of headaches.
