    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 160.1k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      If you put layers in a group, and hide that group, all the nested layers will be hidden.
      But maybe you're talking about selecting multiple layers and hide them all with one click? I'm not sur about that workflow
      • cmeedC Offline
        cmeed
        I have another one for you....
        With the layer Panel open I can't use my shortcut key 'P' assigned to Create new scene. Turn panel off and shortcut key works as it should.
        Does that happen for anyone else?
        In the model I'm using i have a lot of layers going on. I've just had a major bug splat too, thankfully no lost data or corrupted files. on opening the the file again after the bugsplat, the bugsplat happened again and again - straight away before SU seemed to even open - restarted Machine seems Ok- File opened as Usual
        mmmmm
        c
          jiminy-billy-bob
          Were you trying to delete/purge layers with outliner opened ?
          http://sketchucation.com/forums/viewtopic.php?f=180&t=54161
            jiminy-billy-bob
            Not sure about the P shortcut, I'll look into that.
            • cmeedC Offline
              cmeed
              before the major bugsplat I was trying to create new scenes outliner could have been open. When i pressed P no scene tabs appeared which drew my attention
              then i opened the 'Scenes window' and noticed the scenes were there - but as i said no scene Tabs at the top of the SU Window. Then the crash
                Bimbalas
                Hi, jiminy-billy-bob,
                very nice job. Thanks.
                I'm discovered a new bug.
                On renamaming layers or groups directly on Layers Panel with letters from non ASCII character set (e.g. ąžįėš) this letters was changed to unicode codes.
                Can you look for this?
                  breezy
                  JBB,
                  Thank you for designing the Layers panel, it is great to be able to nest layers. 😍
                  But when I tried to remove a layer and delete the contents Sketchup throws a Bug Splat. 👎
                  This happened first with 0.2 but again with 0.3.1. I am using Sketchup 2013. The layer that I tried to delete had no components assigned to it. I had the Outliner window open and just before the bug splat was thrown I noticed a bundle of groups appear on the bottom of the Outline tree. The model statistics are 201 components definitions, 35 layers, 31 materials all created before installing Layers panel. Some of the layers were hidden at the time of the bug splat. I submitted the bug splat #43650, if it is any help I still have a copy of the splat files Undo.log, Sketchup.dmp and .xml.
                  Regards,
                  Arie.
                    jiminy-billy-bob
                    Bimbalas > I'll look at non-ASCII characters.
                    Breezy > That's a known bug and Dan helped me fix it : http://sketchucation.com/forums/viewtopic.php?f=180&t=54161
                    It will be fixed in the next release (out in a few days)
                      breezy
                      jiminy-billy-bob,
                      Thank you. I refrain from using your delete button!
                      A possible future feature is the ability to colour the layers as in Sketchup's layers window. Also to rollup the window by clicking on the title bar.
                      Thanks again for what you have produced, I have found it easier to control the layers in my projects. 😍
                      Regards,
                      Arie.
                      • MichaelNeysesM Offline
                        MichaelNeyses
                        Ive got some problems with the layer panel.
                        1. It is asking for me to update the current ie explorer. But i already installed version 10 although it is not my standard browser, which is firefox.
                        2. When I use the features as explained s. a . creatíng groups and layers and sort the whole structure, then i will not be able to open this very drawing again after saving and closing it properly. The comment is: ²wrong file format!² , the file is actally lost.
                          I am glad i did not blindly change any important file and put too much time in doing so.
                          Glad there is a thing called .skb! I think this is a rather serious issue.
                          I wonder if i am the only one with this experience!
                        Michael
                        nothing beats the joy of accomplishing a design that meets previous vision
                          jiminy-billy-bob
                          Unfortunatly, the API doesn't allow me to do that...
                          Can you go to http://whatsmyua.com/ with Internet Explorer, and tell me what it says ?
                          1. When I use the features as explained s. a . creatíng groups and layers and sort the whole structure, then i will not be able to open this very drawing again after saving and closing it properly. The comment is: ²wrong file format!² , the file is actally lost.
                          Did you create these groups with a version of Layers Panel older than 0.3.1 ? Like 0.2, 0.3, etc
                          • cmeedC Offline
                            cmeed
                            I'm having issues with renaming layers - only some though others work fine.
                            deleting layer and starting again this dosen't happen - I can rename again
                            (i didn't have to make a video for this but I've never done it, so there you go....)
                              jiminy-billy-bob
                              Is it renamed in SU's layer window ?
                              • cmeedC Offline
                                cmeed
                                I didn't see but this isn't the fist time this has happened so will keep a better note next time.
                                • gullfoG Offline
                                  gullfo
                                  i've found an issue? i added layers after placing a bunch into groups and when i drag the unassigned layer into a group i get a javascript error. attached is the file and the screenshot. i'm using SU 2013 pro 13.0.4812 on Windows Vista SP2. i have full permission in SU prog dir.
                                  screenshot of error
                                  sketchup file
                                  Glenn
                                  http://www.runnel.com
                                    jiminy-billy-bob
                                    Ok, thanks.
                                    I think it's related to Observers watching layers change. I had these kind of issue in the past and resolved a lot of them, but it's possible that some remain. If it's indeed related to observers, it should occur only with old layers created before Layers Panel was installed.
                                    gullfo > I'll look at your file.
                                      jiminy-billy-bob
                                      Ok Glenn, I found the issue. You simply have too many layers. It's related to the max length a url can pass between the dialog and SU. I forgot about this... I'll need to rewrite some code.
                                      • cmeedC Offline
                                        cmeed
                                        Thats it- it was an old layer. The reason i was changing it was to give it a capital letter, I started out with non-capitalised layer names......
                                        • cmeedC Offline
                                          cmeed
                                          does that mean theres a limit on layers?
                                          c
                                            jiminy-billy-bob
                                            For now, yes. I had this planned, but completely forgot about it. So I don't know the current limit. But in next version, it should be fixed.
                                            • 33
                                            • 34
                                            • 5 / 34
