    Photo Composite
    15 Posts 10 Posters 1.7k Views 10 Watching
      jpalm32
      ๐Ÿ‘ ๐Ÿ‘
        ScottPara
        Stunning work
        Love the fact that some HATE my avatar.....
        • allanxA
          allanx
          Very nice Jason...
          allanx
          Portfolio
          • srxS
            srx
            ๐Ÿ‘ I suggest adding noise etc. to render to make it more part of the photo.
            www.saurus.rs
            • jo-keJ
              jo-ke
              Wow! Very good!
              http://www.zz7.de
              • marked001M
                marked001
                Thanks guys.. much much appreciated.
                srx.... sometimes noise/dirt is a catch 22 in projects like this. it would definitely help it blend in a bit more, but at the same time a client doesnt want to see their new project all muddied up and 'real' ๐Ÿ˜„
                http://www.revision21vis.com
                instagram: revi21on
                  jpalm32
                  Your precinct pilot interior is one of my favs.
                  • srxS
                    srx
                    Than you should remove reality (noise, mud) from the photo. ๐Ÿ˜„ A new approach is - Don't make render look real, turn reality into render. I sometimes used photo sketcher to unite real and unreal.
                    www.saurus.rs
                    • marked001M
                      marked001
                      haha...yeah, that could work too but the whole point of this is that its going to be at a Zoning hearing and in front of a bunch of lay people, so they need it served to them as clearly and simply as possible.
                      instagram: revi21on
                      • marked001M
                        marked001
                        ..while we're on the subject, here is another. This is for a location shot for a series I worked on last week and seemed like it was going to be really simple. The designer wanted to replace the tree/plantings in the front of the house and the tree ended up covering up most of the front. I had to recreate the bay in 3d and then pshopped the bits of window/door/railing.... certainly far from seamless, but didn't have much time left in my day and underestimated it.
                        instagram: revi21on
                        • ElibjrE
                          Elibjr
                          Nice work marked001. I truly understand when you do a model for a client you don't always have an opportunity to make things perfect. The deadline is the deadline and the idea is to convey the point usually and not the just the image itself. May I ask what render-er you use? Or are you using just Photomatch?
