    Fix Your Plugins
    extensions
    14 Posts 10 Posters 19.2k Views 10 Watching
    • GaieusG
      I don't think it's not trusting you but just generally speaking folks who don't know what they're doing, shouldn't "play" with them. πŸ˜‰
      • H
        heitorkooji
        Sure it's more confortable to download from dll-files.com.
        The solution worked here, msvcr71 and msvcp71 were missing.. Thanks a lot!
        • F
          farfalla
          i do all the steps and it doese not working
          • Dan RathbunD
            Dan Rathbun
            Get them DIRECT from Microsoft, .. no place else.
            Microsoft Visual C++ 2005 Redistributable Package (x86)
            (see bottom of page for links to IA64 and x64 downloads.)
            I'm not here much anymore.
            • EscapeArtistE
              EscapeArtist
              Would have been better to let this thread die rather than resurrect it, but good advice.
              Low post-count member uploading potentially dubious files followed by praise posts by single post members. Has "danger" written all over it.
                saikidsid
                thanks a lot. u saved my life. I had exactly the same problem n nw my vray works.
                • Dan RathbunD
                  Dan Rathbun
                  @chris fullmer said:
                  I'm hesitant to let this post stay up. It's essentially advising people to install encrypted files into the Windows system folders.
                  Chris,.. it's time to remove the OP zip file. He never posted more than 4 times!
                  You can use the link in my post above to the MSVC runtime download.
                  • dkendigD
                    dkendig
                    we bundle the C++ redistributable with our installer, I don't see why this is necessary at all unless you installed V-Ray without having those redistributables checked in our installer (it's checked by default)
                    Devin Kendig
                    Developer
                      mitm
                      how to fix the same problem in mac os?
                      • dkendigD
                        dkendig
                        I've never seen this error with V-Ray, if you choose the correct install path, and use default installation options checked.
                        Devin Kendig
                        Developer
