    Strange behavior in derived class
    11 Posts 6 Posters 709 Views 6 Watching
      tjrob
      Here is a set of commands in the SU Ruby console:
      ` > class A; end; puts A.new.class
      A
      nil
      class B <A; end; puts B.new.class
      B
      nil
      class C <Geom::Transformation; end; puts C.new.class
      nil
      (Ignore the "nil"s -- they are unused return values.)`
      How is it that C.new does not return an object with class C?
      How/why does a class derived from Geom::Transform lose its identity?
      How can I fix this -- I have a special coordinate system in my plugin and need to distinguish transformations using it from transformations using the standard coordinates.
      Note that Transformations are complicated enough that I don't want to implement them myself; I would surely get something wrong. I suppose I could make my transformation class have an instance of Geom::Transformation as a class object, but that means I need to implement a large number of functions that just pass through to that object....
      • fredo6F Offline
        This seems to happen for all GEOM classes (Point3d, Vector3d).
        Frankly, I don't see why, and there must be an unknown or secret Ruby mechanism behind. Probably the Geom classes are proxies to C code and do not have all the bell and whitstles of normal SU object classes.
        I am sure Dan will have an enlightning explanation.
        • Dan RathbunD Offline
          Dan Rathbun
          I will pass.
          Let the "official" representatives of SketchUp explain their API's behavior.
          I'm not here much anymore.
          • Chris FullmerC Offline
            I'm watching and discussing internally....
            from what I can gather, the behavior is just plain ol' incorrect. We are actually looking at fixing it in a future release. But I realize that will not help with backwards compatibility. At this point, we could find no way to make it work the way you want for the classes that are broken.
            • tt_suT Offline
              tt_su
              An alternative, which I use myself, is to put all the methods etc you had intended for the sub-class into a module and perform an instance extend after you have the Geom::Point3d instance.
              You can see the module I use in TT_Lib2 for instance: https://bitbucket.org/thomthom/tt-library-2/src/2bb264f27d9bc00c1b1f9a969e481c19385042ad/TT_Lib2/point3d_ex.rb?at=Version%202.9
              When I receive a Point3D object I can use: point.extend(TT::Point3d_Ex)
              From that point on all the content of that module is available for that instance.
              • fredo6F Offline
                The strange thing about subclassing Geom::Transformation (or Geom::Point3d) is that it does not even execute the initialize method of the inherited class.
                For instance
                class A < Geom;;Transformation ; def initialize() ; puts "Self = #{self}" ; end ; end
                nil
                a = A.new
                #<Geom;;Transformation;0xc808ae8>
                There must be a trick since I have no clue how Ruby can do that, even if the initialize method of Geom::Transformation is a singleton method.
                • tt_suT Offline
                  tt_su
                  That's because SketchUp used an old method of allocating and initializing the data for the classes defined in C. The allocation is done explicitly in .new - which was something one had to do in Ruby 1.6. I noticed this myself when I tried to initialize an instance in Ruby C Extension using rb_class_new_instance - which failed. I had to explicitly call the .new method of the SketchUp classes.
                    Aerilius
                    Subclassing SketchUp's core classes is currently impossible (see my tries with [extend()](https://bitbucket.org/Aerilius/color/src/e837419cfb80a5b29fb2c152a107447737f03f53/ae_Color.rb?at)ing the returned object).
                    Try to create maybe a wrapper class, instead of a subclass? Create a class that stores the Geom::Transformation in a variable, and create derived methods to access/modify the original transformation.
                    • tt_suT Offline
                      tt_su
                      .extend should work... It has worked for Geom::Point3d classes for me. Not tried Transformation, but it'd be surprised if it's different.
                        tjrob
                        Thank you all for the discussion and suggestions.
                        I had not known about .extend() -- it works well, and does precisely what I wanted to do: distinguish different types of transformations (I use .respond_to? to tell if this instance is normal or special, and then use the function only for special ones). This is sort of "inverted inheritance", which is a very Ruby-ish thing to do πŸ™‚ .
                        • tt_suT Offline
                          tt_su
                          If you extend and instance with module "FooBar" then you can use instance.is_a?(FooBar)
