    Strange behavior in derived class
    11 Posts 6 Posters 893 Views 6 Watching
    • fredo6F Offline
      This seems to happen for all GEOM classes (Point3d, Vector3d).
      Frankly, I don't see why, and there must be an unknown or secret Ruby mechanism behind. Probably the Geom classes are proxies to C code and do not have all the bell and whitstles of normal SU object classes.
      I am sure Dan will have an enlightning explanation.
      • Dan RathbunD Offline
        Dan Rathbun
        I will pass.
        Let the "official" representatives of SketchUp explain their API's behavior.
        I'm not here much anymore.
        • Chris FullmerC Offline
          I'm watching and discussing internally....
          from what I can gather, the behavior is just plain ol' incorrect. We are actually looking at fixing it in a future release. But I realize that will not help with backwards compatibility. At this point, we could find no way to make it work the way you want for the classes that are broken.
          • tt_suT Offline
            tt_su
            An alternative, which I use myself, is to put all the methods etc you had intended for the sub-class into a module and perform an instance extend after you have the Geom::Point3d instance.
            You can see the module I use in TT_Lib2 for instance: https://bitbucket.org/thomthom/tt-library-2/src/2bb264f27d9bc00c1b1f9a969e481c19385042ad/TT_Lib2/point3d_ex.rb?at=Version%202.9
            When I receive a Point3D object I can use: point.extend(TT::Point3d_Ex)
            From that point on all the content of that module is available for that instance.
            • fredo6F Offline
              The strange thing about subclassing Geom::Transformation (or Geom::Point3d) is that it does not even execute the initialize method of the inherited class.
              For instance
              class A < Geom;;Transformation ; def initialize() ; puts "Self = #{self}" ; end ; end
              nil
              a = A.new
              #<Geom;;Transformation;0xc808ae8>
              There must be a trick since I have no clue how Ruby can do that, even if the initialize method of Geom::Transformation is a singleton method.
              • tt_suT Offline
                tt_su
                That's because SketchUp used an old method of allocating and initializing the data for the classes defined in C. The allocation is done explicitly in .new - which was something one had to do in Ruby 1.6. I noticed this myself when I tried to initialize an instance in Ruby C Extension using rb_class_new_instance - which failed. I had to explicitly call the .new method of the SketchUp classes.
                  Aerilius
                  Subclassing SketchUp's core classes is currently impossible (see my tries with [extend()](https://bitbucket.org/Aerilius/color/src/e837419cfb80a5b29fb2c152a107447737f03f53/ae_Color.rb?at)ing the returned object).
                  How can I fix this -- I have a special coordinate system in my plugin and need to distinguish transformations using it from transformations using the standard coordinates.
                  Try to create maybe a wrapper class, instead of a subclass? Create a class that stores the Geom::Transformation in a variable, and create derived methods to access/modify the original transformation.
                  • tt_suT Offline
                    tt_su
                    .extend should work... It has worked for Geom::Point3d classes for me. Not tried Transformation, but it'd be surprised if it's different.
                      tjrob
                      Thank you all for the discussion and suggestions.
                      I had not known about .extend() -- it works well, and does precisely what I wanted to do: distinguish different types of transformations (I use .respond_to? to tell if this instance is normal or special, and then use the function only for special ones). This is sort of "inverted inheritance", which is a very Ruby-ish thing to do πŸ™‚ .
                      • tt_suT Offline
                        tt_su
                        If you extend and instance with module "FooBar" then you can use instance.is_a?(FooBar)
