    Sine Law?
    9 Posts 2 Posters 921 Views 2 Watching
      tomot
      I need help in writing a Ruby equivalent sine law......TIA!
      example: Calculate angle B
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        Let's call angles aa, ab etc, and lengths da, db etc...
        Notes: if the angles you have are in 'degrees' then pass it in 'radians' to the Math function using the aa.degrees method, otherwise if they are already in radians use their float value...
        To turn a 'radian' result into 'degrees' use the .radians method...
        Math.sin(aa) / da = Math.sin(ab) / db = Math.sin(ac) / dc
        First pick the pair of == which contain three knowns and the one unknown value you want - ' ab'...
        Math.sin(**ab**) / db = Math.sin(ac) / dc
        Change the subject of the formula [i.e. multiply both sides by ' db']...
        Math.sin(ab) = db * Math.sin(ac) / dc
        or to get ' ab' in radians use ' .asin'...
        ab = Math.asin(db * Math.sin(ac) / dc)
        Then to see ' ab' in degrees: ab = ab.radians
        db=4.7; dc=5.5; ac=63.degrees; ad = Math.asin(db * Math.sin(ac) / dc).radians
        49.5882674686285
        To round the answer to 1 d.p. use:
        ad1 = sprintf("%.1f", ad)
        49.6
        The higher the .Nf the more d.p.s
        Note that in the above example '[ruby:anl6c1ws]ad1[/ruby:anl6c1ws]' is a string - to get a float use:
        [ruby:anl6c1ws]ad1=ad1.to_f[/ruby:anl6c1ws]
        πŸ€“
          tomot
          2 added issues which I have not been able to find diagrammatically illustrated in the Ruby math code:
          (I use globals only to verify the values in the console after the ruby has run)
          1. How to subtract angles?
          # Angle aaa = 180 degrees - angle aa
          $aaa=180-$aa
          # 119.026476570893
          # Angle ccc = 90 degrees - (Angle cc +Angle bb)
          $ccc=90-($cc+$bb)
          # 27.2834559031268
          1. How to append an angle value to angle value.degrees?
            incorrect:
          # Sine Law; does not give the right answer
          $da=Math.sin(($aaa)*$dc/Math.sin($ccc)).radians
          # 56.3706471942142
          correct answer after I manually added .degrees:
          # Sine Law; with the correct answer
          $da=Math.sin(119.026476570893.degrees)*dc/Math.sin(27.2834559031268.degrees)
          # 135.21551555127 !OK
          Tan angle to degrees?
          # Angle aa
          $aa=Math.atan(($raheight-$radepth)/($length/6)).radians
          # 60.9735234291066 !OK but .degress is missing
          Find length $da
          tomot
            Yes... you must always work in radians.
            Most programming languages use them for angles.
            SketchUp has the useful numeric additions, so 60.degrees converts an angle of 60 degrees into radians for you, and conversely 1.0471975511966.radians converts that value to ~60.0 degrees...
              tomot
              I see some gaps exist in my previous query: 😒
              The Ruby Math Module has the job of evaluating math expressions. Its up to the programmer to provide the proper units. In fact regardless of the units I provide, the resulting evaluation only provides the numeric value, the units are never displayed in the ruby console.
              In this particular case, I need the ruby code to include the value and the units: , which is .degrees in this example.
              But because the global contains only the numeric value, the global substituted into the sine law, provides the wrong answer.
              I order for the Sine Law to provide the correct answer, the global substitution needs both the numeric and unit value:
              I would like the ruby code to make the correct substitution. Not manually as I illustrated.
              tomot
                And the problem is πŸ˜•
                There is no problem... just decide on what units are used and then use .degrees or radians if the input is not in 'sensible values'...
                I fail to see what issue you have here 😞
                  tomot
                  Ok!...... one more time, lets see if can get my question across πŸ˜„
                  Lets take a portion of your nicely illustrated example of the Sine Law.
                  49.5882674686285
                  ad = 49.5882674686285 but more importantly if I were to use the value ad and substitute its into lets say another sine formula I would NOT get the correct answer. because the .degress is missing.
                  So my question is How do I get ruby to append .degrees to the value ac = 49.5882674686285
                  tomot
                    The method .degrees turns an angle that is in degrees into radians.
                    The method .radians turns an angle that is in radians into degrees.
                    So... db=4.7; dc=5.5; ac=63.degrees; ad = Math.asin(db * Math.sin(ac) / dc).radians 49.5882674686285
                    Then later... ad.degrees 0.865478537687162
                    BUT of course if you has missed off the final .radians 'ad' would already be in radians... and therefore to see it in degrees you'd need to use ad.radians later...
                    I suggest you get input in degrees AND also return amgle angle answers in degrees too: only changing the angles to be radians when you use Math functions that are needing them...
                    So ac=**63.0** and then in the equation ad = Math.asin(db * Math.sin(ac**.degrees**) / dc).radians
                    Now 'ad' is in degrees again, so when you Math equation processes it uses ad.degrees
                    You are over thinking this... it's pretty straightforward.
                    Don't mix up degrees and radians as you'll get confused...
                    Keep the 'degrees' for the 'human-side- and just use .degrees to convert to 'radians' for Ruby's 'Math-side'... πŸ€“
                      tomot
                      I was not confused between degrees and radians. Its the same way angles are treated in many languages, I'm quite familiar having written AutoLisp routines years ago, which also uses degrees and radians. Its more about me learning how to write the same code in Ruby
                      .........I finally see in your example how .degrees gets added, its really simple once I saw your example. πŸŽ‰
                      tomot
