    Drawing a ray or line from a vector
    3 Posts 3 Posters 517 Views 3 Watching
      jach9009
      I am currently retrieving a vector from sketchup and I am trying to draw a line from that retrieved vector. Is there a way to do this?
        mptak
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/entities.php#add_cline
        This will give you a construction line defined by a point and a vector. If you want to draw a line segment aka edge you could get the second end point by applying a scaled transformation to your initial point.
          A vector defines a 'direction', which essentially is not determined in its location in space.
          To define an 'edge' you need a start point - let's call it 'point1'...
          Then set your vector's length using:
          vector.length=length
          and find 'point2' for the end point:
          point2=point1.offset(vector)
          Now you have two points representing the start/end-points of a potential new edge.
          Use
          Sketchup.active_model.active_entities.add_line(point1, point2)
          or
          Sketchup.active_model.active_entities.add_edges([point1, point2])
          Don't confuse edge & line - confusing the API does when adding one edge it calls it a 'line'!
          Actually a 'line' is a special geometrical construct of [point, vector], which us infinitely long passing through the point, along the vector. Lines can intersect etc...
