    Deleting first instance of copied items
    Scheduled Pinned Locked Moved Dynamic Components
    6 Posts 2 Posters 1.3k Views 2 Watching
    • aarondietzenA
      aarondietzen
      Hi all,
      Hopefully one of you smart people can help me out with an issue I am having.
      I have a dynamic component in which both a vertical and horizontal divider are created and repeat based on the user's input. I was able to put in the members without issue, but I was hoping there was a way to remove (or hide) the first copy.
      The member at the left and the bottom in the images are marked with a red arrow. I need to get them gone!
      Thanks in advance!
      "Imagination is more important than knowledge..."
      - Albert Einstein
      • P
        pcmoor
        How about moving the position of the first instance and do one less copy.
        • aarondietzenA
          aarondietzen
          Not sure how that would work... right now I am using this for the Z location:
          =copy*(Window!LenZ/(Copies+1))+1/2
          Which divides the span of the window by the number of dividers (plus 1/2 the divider width to account for material thickness).
          I know there is a COPY attribute which allows you to manipulate individual copies, but cannot find an example or explanation of how it works.
          - Albert Einstein
          • P
            pcmoor
            Try =Window!LenZ/(Copies+1) + if(copy>0,(copy-1)*(Window!LenZ/(Copies+1)),0)+1/2
            the first distance + copy less one * distance + 1/2
            the if statement to make zero if copy = 0, otherwise copy-1 would be -1
            However this places the first and second instance @ the same position. So probably better to reduce the copies number
            ie for Copies: = window!number-1
            exact syn tact would be whatever you choose for the variable "window!number"
            then lenZ= Window!LenZ/(Copies+2) + copy*(Window!LenZ/(Copies+2) + 1/2
            Hope this helps
            Philip
            • aarondietzenA
              aarondietzen
              I ended up adding a HIDDEN attribute (=IF"copy=0,1,0) to hide the first instance.
              I will try what you suggested, though, Phillip. Better to have it not there than to have it hidden!
              - Albert Einstein
              • aarondietzenA
                aarondietzen
                Philip,
                Tried your solution and it worked PERFECTLY! Thanks a ton!
                - Albert Einstein
