    Aborting a .rbz install
    16 Posts 4 Posters 1.2k Views 4 Watching
      By the time you get the message it has installed, and at least started to load !
      Of course you can prevent most of the code loading by testing for the system not being MAC then stopping...
      Of course you could also write a File.delete() set of code, to remove all of the files/folders that are installed on a PC in error - after you have put up the message !
      The message should also say to restart SketchUp to remove any residual code that was loaded - although if you trap the system mismatch early on little should be loaded...
        driven
        just tested and it doesn't even show the message, loads the support folder, but not the file with the error, so you'd end up with an orphaned folder...
        I think this is the way to go, maybe with an option to move to desktop if someone wants to easily have a look?
        everything [else] is in the one folder and any rubys can have the abort so they never load into SU, the unix bin files are pretty safe from loading...
        Seems it would be useful if SU did an initial screening for platform specific and we just add a sherbang !#mac or !#win or similar at the start of each file...
          IF you put the 'IS_MAC' test at the start of the Plugins-folder-level script that is 'auto-loading' as the file installs [perhaps outside of the main module] and then you add 'the-message' + then delete itself AND all other just-added subfolders' files, AND then delete those empty-subfolders, AND THEN 'return nil' [before any other other code in the 'loader' is run] then NO other code should load at all ... The subfolders of support files will have been installed and then immediately deleted if !IS_MAC ???
            driven
            On the mac this removes everything, except my main targets
            i.e the primary folder is retained containing a [dot] folder containing a mac binary file
            I get Error: #<Errno::ENOTEMPTY:
            The question is, would Windows 'protect' these file types or would they be deleted as well?
            if( ( RUBY_PLATFORM =~ /darwin/i) )
            UI.messagebox("\n This code is for Mac only! \n
            It will not run on Windows or Linux \n
            Loading will now abort \n
            Contact the Author if you wish to port the source \n
              path = File.expand_path(__FILE__)
              dirname = path.sub(".rb", "")
              Dir[(dirname + "{**/**/**/*")].sort.reverse.each do | p |
               if File.directory? p then
                        Dir.rmdir p
                    elsif
                        File.exists? p then
                        File.delete p
                    else
                 File.delete path
                 Dir.rmdir dirname
                 return nil
              On a PC [and MAC?] this deletes a folder, even with deeply nested folders/files
              def self.delete_folder(d)
              		return nil unless File.directory?(d)
              		Dir.entries(d).each{|f|
              			next if f=='.' || f=='..'
              			x=File.join(d, f)
              			if File.directory?(x)
              				self.delete_folder(x)
              			else ### file
              				File.delete(x)
              		begin
              			Dir.delete(d)
              		rescue ### fails if it's not empty!
              Usage: self.delete_folder(full_path_to_folder_to_delete)
              You can't delete the . or .. entries in a folder, BUT you can delete an empty folder that only contains those two entries... It has the 'self.' only because I had this example in a module...
                driven
                cheers,
                I got it working by 'naming' the difficult ones
                but I'll have a play with your version tomorrow...
                I think it's worth not loading the binary into a PC, even if it won't hurt...
                your up late
                • danielbowringD
                  danielbowring
                  Deleting it seems like overkill, you could employ something like this instead
                  module AuthorModule
                      def self.is_mac?()
                      module PluginModule
                      end if is_mac?
                      mac_only_warning unless is_mac?
                  Or in the extension file
                  if is_mac?
                      extension = # ...
                  else
                      mac_only_warning
                    driven
                    having 'only works on mac' should be enough, but never is.
                    I'm just wanting to avoid the 'this isn't working' posts from 'PC' users.
                    Beside anything else, it would be trivial for SU to pre-screen for files marked as os dependant.
                    • danielbowringD
                      danielbowring
                      Note the if is_mac? at the end of PluginModule. That will prevent the plugin from "loading" anything more. Same if you just don't register the SketchupExtension. You could also write a setting to prevent it re-showing the message using Sketchup.write_default / Sketchup.read_default
                      Edit: Demo
                      module MyModule
                          puts "This section will never be executed!"
                      end if false # because of this!
                      puts "But this will!"
                      puts defined?(MyModule)
                      Gives
                      But this will!
                      nil
                        BUT we are trying to stop an RBZ install of a plugin onto an incompatible OS [a relatively rare occurrence?]...
                        So we need to check the OS early on, then tell the user what we are doing and delete the files/subfolders of files that ship in the RBZ [including itself!] ans stop loading anything at all.
                        It pointless having a plugin installed into an OS where it won't work...
                          driven
                          @aerilius said:
                          .. or maybe the plugin folder is synced with another system on which the plugin is supposed to be used).
                          Excellent point I hadn't considered.
                          I was already leaning towards adding the [ is_mac? ] to the menu/toolbar loader, which which will prevent unusable menu items when on the wrong platform...
                          As my plugin's 'logic' is dynamically loaded into SU by either of these items being 'clicked', then it will also remain inert without any additional screening.
                          This, in addition to setting the extension i.e.
                          Sketchup.register_extension( add_icon_to_mac_skp, false) unless is_mac?
                          should accommodate a shared Plugin folders.
                          further thoughts?
                            If you have mixed OSs on a network which share plugins you are making some issues for yourself... 😕
                            Only a few plugins ship in PC and MAC 'version's anyway, and handle OS differences within their methods...
                            So just allow the plugin to install on any OS...
                            but as suggested... test in the main 'loader' for the appropriate OS and only set up its Extension if there's an OS match...
                            That way you could have it installed on a shared folder that resides on a PC, that can never actually load it, but it can successfully load from that shared folder if it's called by a MAC etc...
                              Aerilius
                              Are there no risks when messing around with file deletions?
                              [If such a method existed] I would prefer to use corresponding API methods for (un)installation, or more generally put:
                              The same method for uninstallation that was used for installation (by hand, API or EWH).
                              What is the problem of keeping the plugin and just telling the user about the issue. This gives the clearest explanation and the least surprise. Also the user could maybe have reasons to keep the plugin installed without using it actively (like only inspecting how it works, or maybe the plugin folder is synced with another system on which the plugin is supposed to be used). Suddenly disappearing files would rather make a user worried and would blur the line between good software and malware.
                              Edit: Another thing is: Using ruby to delete files circumvents the trash. If we let the user manage "his" files (that the user installed), there is the chance to restore them.
                                driven
                                one last idea
                                what happens on Windows if I add this to the top of each script
                                windows use = nil
                                If done correctly on a mac it returns nil and the ruby continues.
                                you cantype non-breaking spaces directly on OS X with Option+Space.
                                I'm under the impression Windows will see it as a space and error out
                                Error: #<NoMethodError: undefined methodwindows' for #Object:0x56b89ec>`
                                If so, I can add it and even if the file/folders are there, nothing will run unless your on a mac...
                                pilfered from here:
                                http://www.rubyinside.com/the-split-is-not-enough-whitespace-shenigans-for-rubyists-5980.html
                                • danielbowringD
                                  danielbowring
                                  Depends what encoding you save it in.
                                  Western (Windows 1252) gives this:
                                  Error; #<SyntaxError; (eval);5231;in `load'; path/to/nbsp.rb;1; Invalid char `\240' in expression>
                                  UTF-8, however, will load and work fine
                                  windows use = "o.~"
                                  puts "Success #{windows use.inspect}"
                                  load 'path/to/nbsp.rb'
                                  Success "o.~"
                                  true
                                  Note: Browsers will replace the character in question (160, "non-breaking space") with a regular space (32, "space"), but I did correct for this for this test.
