    Method for circular or radial railing- help please.
    19 Posts 5 Posters 5.9k Views 5 Watching
    • ShyamscoolS
      Shyamscool
      1. This youtube video explains how to create the lower face plate for a circular stair.
      however I have question, how did they make the sides? If you watch the video,it shows three stages to make the stair and I am stuck with the first one.. Plz help.
      1. Before using "follow me" to make the hand rail, how to I draw that "follow me" line that is bent in x, y and z axis?
        Look at the ground there is the section drawn! πŸ˜‰
        Simply traditionnal sketching!
        You make elevation for each step and then draw the sides' junctions πŸ˜‰
        Something like that!
          When you have a step "module" (above it was one step and the lines under + sides' faces )
          you can of course use some cool plugins for make Rotation + Move Z in the same time!
          The more elaborated are "Grow" By TIG it makes Move + Rotation + Size in the same time! πŸ‘
          Memory Copy (clone) by Plot-Paris + Adam B simple but very efficient! πŸ‘
          If you want just Rotation + Move you have
          Copy Rotation by Sdmitch very cool because you can click anywhere for the copy! πŸ‘
            Its just the lines (so a curve) that you have previous drawn under the steps! πŸ˜‰ (as shown on my images)
            Copy move it in Z!
            • pbacotP
              In the sample video the curve of the steps is many segments, not just one per step. Probably not an even layout--considering riser points-- in plan (though that would be good way to start, to appease SU which is little help in this case). So Shyamscols question is a good one.
              • ShyamscoolS
                Shyamscool
                http://i44.tinypic.com/ixwp5g.jpg
                i was too impatient for y'all to reply... found my own redneckish way to do it...
                ~i made the usual spiral stair boxes and put them in their places,
                ~just like the youtube video, i made the lower face using curviloft
                ~exploded the lower face
                ~now curvilofted' the sides for every single step.. and finally
                ~a bunch of smoothin
                next time i will do it the easy way πŸ˜„
                • ShyamscoolS
                  Shyamscool
                  exactly!!!!
                  some other guy has commented on the video asking how the sides were made, a year ago!
                  • ShyamscoolS
                    Shyamscool
                    Copy move it in Z!
                    but since i unnecessarily made my circle of 500! segments, that line you talking about is a buncha segments, is there a way to make it one nice smooth curve?
                    • pbacotP
                      Copy move it in Z!
                      You can select the curve and weld it with weld rb. or recurve plugins. But how did you draw it? It would be nice to just pull up the (welded) arc from the floor to a relative height based on the nosings, but that distorts the curve out of the circle. There's some good ways but I can't rememeber....
                      I think it is possible with Fredoscale "Planar Shearing (Free)" take the plan curve and group a copy, raise it up to the first nosing, draw a rectangle down from start point to end point, Use the rectangle to set the plane of shear. Shear it up to the end nosing. drop it down for the thickness of your structure. Smooth any existing vertical lines and if you weld the resulting sheared curve BEFORE exploding the group, all should be well.
                        More practical
                        For Weld: Recurve by Diggsey
                        And there an existing one other by Fredo 6 πŸ˜‰ (some excellent tool in the same place) πŸ‘
                        Inside Curvizard (Make curve)
                        It's yet a nice curve! ; For select it just a double click is sufficient then use the tools above πŸ˜‰
                        • ShyamscoolS
                          Shyamscool
                          follow me and keep" like he meant follow me and STAY! ( how i want you to stay!)
                          nice plugin any way.. works fine on win7+skp13+vray1.6
                          Awesome help folks!
                          thanks yall CO guys and all extension developers!
                          Happy 4tha July πŸ˜„ Fire works time... oh wait there is a fire ban πŸ˜‰
                          • ShyamscoolS
                            Shyamscool
                            http://i41.tinypic.com/6ep0f8.jpg
                            still all choppy and sketchupish, how do i make that rail smoother?
                            i pulled up the 100+ segment circle line for the railing from the plan
                            next used it for follow me and KEEP... = choppy railing
                            • pbacotP
                              It looks like only 8 or so segments judging by the edges and endpoints. You would need more. What happened to the 100 segments?
                              Perhaps you do know as well: Endpoints style will make the image look rougher. Output of image AA quality depends on resolution, will also look better in a render, etc.
                              You will also get a more realistic smooth look if you add rounded edges to the rail profile. Weld (recurve) them prior to FMAK--they should be smooth for curved profiles. Even if you are looking for a chamfered appearance, all the corners look more realistic if rounded to some extent. They don't need too many facets, but should be softened/smoothed edges.
                              • ShyamscoolS
                                Shyamscool
                                Perhaps you do know as well: Endpoints style will make the image look rougher. depends on resolution, will also look better in a render, etc.
                                "Output of image AA quality".maybe that's what it is? how do i mess with that? what IS that?:D
                                http://i44.tinypic.com/2jb77fo.jpg
                                so i am saying ~no matter how many segments you made your plan for railing, it turned out choppy/ first try was 25 segments.. second was 500 segments... same result... but thats a rough render there..( idk why my carpets fup like that)
                                • ShyamscoolS
                                  Shyamscool
                                  and i Weld (recurve) them prior to FMAK by.....using which plugin?
                                  weld? πŸ˜›
                                  • pbacotP
                                    If you are rendering then the SU AA output doesn't matter. I was referring to if you are looking for a better image direct from SU.
                                    You can use Weld.rb or Recurve.rb
