    The Bridge
    15 Posts 11 Posters 1.5k Views 11 Watching
    • KrisidiousK Offline
      Krisidious
      I scanned down looking for the 3D and then realized... It's all 3D. very nice. Really like the concept. I think you accomplished the light goal. It's very appealing and elegant.
      By: Kristoff Rand
        No twisting due the cables are only on each inversed half sides ?
        • Large_BlackL Offline
          Large_Black
          Thanks to all of you guys,
          @ Bryan K:
          Thanks man, yes I think so,
          I've asked administrator for move the post in the right gallery section. Waiting for a reply.
          @ Pilou:
          From the first mild structural surveys (it is mainly a contest of ideas) we found that the stiffness of the bridge deck body formed concomitantly with its pillars positioned at both ends of the platform is likely to win the torsion exercising by the cables on opposite sides of the roadway, in reality could fit on even without the antennas, but these allow to greatly reduce the amount of steel and the density of the concrete necessary for the structure to hold.
          Ciao πŸ˜„
          • boofredlayB Offline
            boofredlay
            Very impressive.
            • elmerE Offline
              elmer
              Very interesting bridge concept and glorious rendering.
              4 days work....wow πŸ‘
              • allanxA Offline
                allanx
                This awesome work..great job...
                allanx
                Portfolio
                  Large_Black
                  Thanks guys,
                  I am very pleased that you enjoyed these images, the result of hard work for 16 hours per day.
                  Many things can certainly be improved, as the curves at the ends of the bridge (could be much smoother), and the materials (being able to work on and doing some more tests surely I can achieve more realistic results).
                  But we are not complaining, the important thing is to be paid .... 😎
                  Ciao πŸ˜„
                  • elmerE Offline
                    elmer
                    Oh! Good, I though one day ment 24 hours..... πŸ˜‰
                    • pbacotP Offline
                      It's great! Thanks for sharing these images here.
                      • tademaT Offline
                        tadema
                        Great set of images. Thea seems to produce a fantastic render.
                        John
                          Milo
                          Very good job. I appreciate the photographic integration because it is not so easy to do. I like your concept but I do not understand the link between cort-en and white masts. Anyway good luck for the contest πŸ˜‰
                          FaceBook
                            Large_Black
                            Thank you again guys,
                            @ Tadema: Thank you!
                            Yes, thea gives a lot of satisfaction, in my opinion has enormous potential, and it seems that the latest release can do remarkable things. The materials laboratory is a little complex, but when you start to pick up confidence you can get impressive results.
                            @ Milo: Thank you man, image composition and integration of the bridge with the surrounding environment was the hardest of the work, I'm glad that the result is credible. I did not understand what you mean with "link between cort-en and white masts."
                            Here a wireframe, just to take a look of the structure behind.
                            Ciao πŸ˜„
