    Render Question....
    extensions
    27 Posts 9 Posters 3.7k Views 9 Watching
    • StinkieS Offline
      Stinkie
      @andyc said:
      And it looks like Thea will be adding me to their list of users very soon.
      While I think Thea is great, I cannot stress this enough: try extensively before you buy.
      • CadFatherC Offline
        CadFather
        i wish i could post the original pictures - they were 3600x1600 but i can't.
        however, if thea sounds good, you will not be disappointed - it's really a must have.
        still, i'd get a copy of KT just in case - i found myself using someone else's computer (students) with all the trouble about installation, security etc. and of course licensing for a new machine (only if for 1 day) - i was glad i had KT on my flash drive...! ๐Ÿ‘
          andyc
          It certainly seems like a must-have ๐Ÿ˜„
          I had a quick play with Kerkythea several years ago, but didn't really have enough time to look into it properly, and clearly the software has moved on a long way since.
          Thanks again guys - I think you have solved my problem for me ๐Ÿ˜„
          A.
          • dkendigD Offline
            dkendig
            andyc - We're working towards matching features and workflow between V-Ray for Max and V-Ray for SketchUp, so our plugin is more consistent from one platform to the next. We are currently looking for good feedback with our 1.6 beta, from users that are migrating from other modeling apps to SketchUp, and are basically in the situation you have found yourself in. If you think you might be interested in trying V-Ray out, we'd love to hear your 2 cents.
            CadFather - you are absolutely dead on, we are striving to have tighter SU integration, and a more complete feature set moving forward. We now have 64bit support, proxy support is looking better with each release, and we aren't done adding new features just yet ๐Ÿ˜‰
            Devin Kendig
            Developer
            • StinkieS Offline
              Stinkie
              @dkendig said:
              We now have 64bit support (...)
              Wait, wait ... there's a 64-bit VfSU now?
              • soloS Offline
                The new version of Thea has just been released, new field mapping and Presto GPU version.
                • StinkieS Offline
                  Stinkie
                  Trying it out right now. Seems really good.
                  • dkendigD Offline
                    dkendig
                    http://www.spot3d.com/vray/help/sketchup/150PB/distributed_rendering.htm
                    ::winks::
                    Devin Kendig
                    Developer
                    • StinkieS Offline
                      Stinkie
                      • dkendigD Offline
                        dkendig
                        you're quite welcome. I like how it was just snuck in to a minor beta release ๐Ÿ˜„ Wonder what the next one will have! Oooooh
                        Devin Kendig
                        Developer
                        • ashscottA Offline
                          ashscott
                          This thread is really helpful but I want to get more input from you folks who have a little more rendering experience.
                          I do object animations from time to time that require rendering and they can be from anywhere between 30 seconds and four minutes. I currently use Twilight and I love its ease of use as I don't do this enough to justify learning all the ins and outs of complex render software. However, when I do a longer object animation at higher resolutions in Twilight it really makes my machine (i7 laptop with Nvidia GPU) work its guts out and the animations take an inordinate amount of time.
                          There seems to be very little support from render farms for Twilight, I understand that this is because it is based on KT and KT isn't very network render friendly.....
                          What I need is a renderer that I can preview short animations with by rendering overnight on my local laptop and then send off to a renderfarm once Im happy with the final job. I love Twilight but I'm not sure it is the right tool for this.
                          I have checked out Thea, Maxwell and Indigo and they all seem to support multiple nodes.
                          What do people recommend as good "bang for buck"?
                          If you recommend Thea, please explain why it won't face the same network render limitations as Kerkythea.
                          I'm also interested as to how difficult it would be to run renders on AWS with these renderers that support multiple nodes....
                          Just some stuff I do with Sketchup.
                          • tibetT Offline
                            tibet
                            hi,
                            iยดve a question if you donยดt mind.
                            thereยดare many excellent rendering apps for sketchup, many of them almost perfect.
                            some of them are almost unbeatable like vray.
                            lumion and keyshot are easy to use with cool effects, and with plenty of materials.
                            a friend of mine is curious, if there is any renderer to have the same qualities
                            together like those three i mentioned.
                            i hope to find the answer here , eventhough everyone usually votes for his/her product
                            has been using. so i mean the best impression, when you see eg. tut on youtube and so on.
                            thanks for understanding !
                            SU 2015 Pro on Win10 x64
                            • N Offline
                              notareal
                              Kerkythea never been planned to use in any larger render farms, only with few nodes (still some have used it with Amazon EC2 http://www.kerkythea.net/forum/viewtopic.php?f=6&t=7051). It's safe to say that there are issues in KT network rendering, but it works if you have time to fiddle...
                              On the other hand Thea has rather robust network rendering and it has actual build in support for farms. You can build your own farm with tutorials available here http://www.thearender.com/cms/index.php/resources/render-farms.html or use some commercial farms.
                              • ashscottA Offline
                                ashscott
                                So Thea is built differently to KT? - My assumption was that they are built on the same base...
                                The example you linked to on the KT forum is pretty elementary - I haven't seen anything with KT that supports multiple instances...
                                • N Offline
                                  notareal
                                  It's different. Twilight uses Kerkythea engine, but Thea is a different beast. If you have more Thea related questions, please join into http://www.thearender.com/forum/
                                  You mean at EC2? If you read carefully http://www.kerkythea.net/forum/viewtopic.php?p=62415#p62415
                                  "... it is possible to network render inside EC2 by opening two instances...".
                                  or in just local network between your own computers http://www.kerkythea.net/forum/viewtopic.php?t=4234
                                  Like said, KT network rendering is pretty crude and requires manual scene management... PITA to handle if you have several nodes.
                                  • ashscottA Offline
                                    ashscott
                                    Thanks for the info - thats a lot of help.
                                    I do so many hacky little tricks with SU that I've reached a point where I just want solid stuff that works, rather than spending time trying to figure out whats going wrong and where (entirely my fault most of the time)
                                    Ash
                                    • 2 / 2
