    Safe place to store user-defined parameters
    114 Posts 9 Posters 17.6k Views 9 Watching
      Aerilius
      That's very easy, if the OS vendor finger-points at the one who plays bad, then everyone has to try to play nice.
      User's personal data (settings on one side and user data (works, templates, user-managed plugins on the other side) belong to the user level also on other operating systems (of which Windows is only one special example, I even do not use Windows). Then there would not be permission problems. It has often enough been pointed out that plugins in the Windows version SketchUp are in the wrong place.
      The permission problem story on Windows has its origin that it was designed as a single user OS at a time when also security models where basic or non-existing. Microsoft decided to keep compatibility instead of "deprecating" older applications (or applications that don't follow the new rules), which lead to this inconsistency.
        slbaumgartner
        @fredo6 said:
        @slbaumgartner said:
        Guys,
        Please forgive an old fart for a brief history lesson.
        The tmp, temp, and similar directories/folders came into being as a means for a program to create a working file during a run without concern for the physical location of the file. The intent was that the file would no longer be needed after the program exits and could be cleaned up by the OS at any time after the program closes. The fact that an OS may have a lazy cleanup policy that lets such files hang around for a long time is not a good excuse for ignoring the basic idea that these files are meant to be temporary! These are not reliable places to store persistent parameters. The policy could change at any time!
        Steve
        I understand.
        But where can the persistent parameters be saved on Mac?
        What are other applications doing?
        Fred
        On a Mac under OS X, the conventional/approved place for user configuration parameters is a .plist file in ~/Library/Preferences. The file name starts with a dot-separated sequence like a reversed domain name that identifies the relevant app, and then adds more segments to specify what about that app. For example, com.trimble.sketchup.fredo.magictool.plist.
        There are API calls for storing and retrieving info from plist files, but I don't think they are exposed in the SU Ruby API, so using them would probably require an external helper program or added Ruby file to get at plists in a clean way (Apple discourages reading and writing the files manually). I have no experience with them, but there are some plist generator and parser Ruby files on source forge.
          driven
          @Steve,
          that's exactly what this pair does, your entry in the com.sketchup.SketchUp.plist
           result = Sketchup.write_default "section",
             "variable", "my_value"
          result = Sketchup.read_default "section",
           "variable", "default"
          in the .plist that shows as
          	<dict>
          		<key>variable</key>
          		<string>"my_value"</string>
          	</dict>
            slbaumgartner
            @Steve,
            	<dict>
            > 		<key>variable</key>
            > 	</dict>
            Which leaves me somewhat confused about what fredo is seeking to accomplish. Unless you are determined to keep your info somewhere separate from SketchUp's "defaults", what's the problem with using these methods?
            Steve
              Aerilius
              I think for simple configurations (keys, values etc.) Sketchup.write_default is the ideal solution because it uses the API, and the API makers care about that it works.
              But sometimes one wants to store more data or even files, so called "user data" (vs. "config").
              I don't know what Fredo has in mind.
              • fredo6F Offline
                Aerilius is right.
                There are situation where you can persist parameters in the Sketchup section of the registry and some where this is not desirable or not possible.
                My scripts use the registry for some parameters, and files for some others. By principle, it is never advised to overload the registry of a system, as it may easily get corrupted.
                In addition, there are cases where you simply need to store files, not data, say components, materials, etc... that are created on the fly by the plugin based on user inputs.
                Windows makes provision for a 'application data' location on disk. On MAC, there must also be a 'natural' place where such user files are stored. For instance, Microsoft Office use templates and other option files and they are not stored in the registry.
                I think Sketchup cannot continue to propose only the Sketchup root directory to store files underneath. All new versions of operating systems are very picky on security and won't let you access this area from a program or embedded script like Ruby.
                The objective of this post was to see whether the developer community would have ideas and would agree on a convention, because I assume many scripts are in the same situation.
                • Chris FullmerC Offline
                  I'm recently beginning to learn Mac - would:
                  ~/Library/Application Support/
                  be the folder that is comparable to Application Data on Win?
                    driven
                    hi
                    have a look at this, it explains Apples viewpoint.
                    301 Moved Permanently
                    (developer.apple.com)
                    Apples basic philosophy is
                    Every app is an island
                    this includes any plugins written for any app.
                    Apple are moving away from any need for "uninstaller software", as far as they're concerned if a User or the "App Store", trashes or updates an app, then 'all' the files associated with the outgoing 'app version' will be gone on next restart of the mac. To achieve this, it's limiting 'where' you can easily write to, and for 'app approval' you have to prove this can be achieved.
                    If I remove anyones 'Plugin' for SU, I expect 'all' it's support files to disappear from my system. So does Apple.
                    I have one 'Plugin' that moves items all over the place, but if I remove it or even just disable it from the 'Extension Manager' it puts everything back in place and deletes it's 'watch-file'. If I then restart it it writes everything back again. The only thing that ever resides external to SU folder structure are temporary or the outcome of User input i.e. document files I want to keep.
                      So John, what is the simple answer to Fredo's question? How does he safely write files to the HD on a Mac?
                      if Chrome downloads a plugin, it has to put it somewhere. Does it put it in the app bundle?
                        driven
                        @Chris
                        for SU the is most comparable to
                        is ~/Library/Application Support/SketchUp 2013/SketchUp
                        if I add a folder in there...
                        Sketchup.find_support_file("SketchUp", "john") SHOULD work, but it doesn't.
                        PS:
                        we cross posted so I'll add 2 answers
                        1.
                        Google Chrome installs the extension into a randomly generated directory in ~/Library/Application Support/Google/Chrome/Default/Extensions and registers it in its Preferences file.
                        1. The User "Plugins" folder unless it needs to work when plugins are disabled. [really only for debugging or maybe a timekeeping tool]
                          driven
                          @Fredo
                          I feel your pain, love your plugins, maybe someone at Trimble or Steve can tidy this up better then me.
                          it writes a binary .plist in Users Plugins Folder, in your plugins subdirectory, you can then access it as you would the SU one, but it's your own.
                          Once written, it can be read/write i.e. doesn't need a restart [unlike SU's which does]
                          you can store all types of thing in it include binary images etc...
                          #!/usr/bin/env ruby
                          # DON'T RUN DIRECTLY FROM SKETCHUP SEE USAGE BELOW
                          # put this in your folder and call it to create a binary .plist on the Users mac
                          # write what you will
                          require "osx/cocoa"
                          require "pp"
                          # Create the plist and assign values
                          my_path = File.expand_path("~/Library/Application Support/SketchUp 2013/SketchUp/Plugins/FredoHome/__me_first/com.fredo.example.plist")
                          myfile = my_path
                          my_dict = OSX;;NSMutableDictionary.dictionary
                          my_dict['The_Color'] = 'blue'
                          my_dict['count'] = 15
                          # Output to File and print
                          my_dict.writeToFile_atomically(myfile, true)
                          pp my_dict
                          =begin
                          ### Usage
                          make_plist = %x(exec ~"/Library/Application\ Support/SketchUp\ 2013/SketchUp/Plugins/FredoHome/__me_first/mac_plist.rb" 2>&1)
                          my_plist = File.expand_path("~/Library/Application Support/SketchUp 2013/SketchUp/Plugins/FredoHome/__me_first/com.fredo.example")
                          add2my_plist = %x(defaults write "#{my_plist}" animation-duration -float 0.12)
                          inQuire = %x(defaults read "#{my_plist}")
                              "The_Color" = blue;
                              "animation-duration" = "0.12";
                              count = 15;
                          inQuire = %x(defaults read "#{my_plist}"  The_Color)
                          blue
                          =end
                          the format of this bit is important com.fredo.example.plist for defaults to read and write.
                          Lifted from the man page... https://developer.apple.com/library/mac/documentation/Darwin/Reference/ManPages/man1/defaults.1.html
                               Specifying value types for preference keys;
                                           If no type flag is provided, defaults will assume the value is a string. For best results,
                                           use one of the type flags, listed below.
                               -string     Allows the user to specify a string as the value for the given preference key.
                               -data       Allows the user to specify a bunch of raw data bytes as the value for the given preference
                                           key.  The data must be provided in hexidecimal.
                               -int[eger]  Allows the user to specify an integer as the value for the given preference key.
                               -float      Allows the user to specify a floating point number as the value for the given preference
                                           key.
                               -bool[ean]  Allows the user to specify a boolean as the value for the given preference key.  Value must
                                           be TRUE, FALSE, YES, or NO.
                               -date       Allows the user to specify a date as the value for the given preference key.
                               -array      Allows the user to specify an array as the value for the given preference key;
                                                 defaults write somedomain preferenceKey -array element1 element2 element3
                                           The specified array overwrites the value of the key if the key was present at the time of
                                           the write. If the key was not present, it is created with the new value.
                               -array-add  Allows the user to add new elements to the end of an array for a key which has an array as
                                           its value. Usage is the same as -array above. If the key was not present, it is created
                                           with the specified array as its value.
                               -dict       Allows the user to add a dictionary to the defaults database for a domain.  Keys and values
                                           are specified in order;
                                                 defaults write somedomain preferenceKey -dict key1 value1 key2 value2
                                           The specified dictionary overwrites the value of the key if the key was present at the time
                                           of the write. If the key was not present, it is created with the new value.
                               -dict-add   Allows the user to add new key/value pairs to a dictionary for a key which has a dictionary
                                           as its value. Usage is the same as -dict above. If the key was not present, it is created
                                           with the specified dictionary as its value.
                               Specifying a host for preferences;
                               Operations on the defaults database normally apply to any host the user may log in on, but may be
                               restricted to apply only to a specific host.
                                         If no host is provided, preferences operations will apply to any host the user may log in on.
                               -currentHost
                                         Restricts preferences operations to the host the user is currently logged in on.
                               -host hostname
                                         Restricts preferences operations to hostname.
                            Talking it over a little bit here with a Mac person, I still think that the ~/Library/Application Support/ folder is the right starting point. It exists on all Macs, and is specifically designed to be the location that support files get saved to. To me, that is the definition of what Fredo is looking for, and it is sanctioned by Mac. So it CAN'T be against their own "Every app is an island" viewpoint, or else they wouldn't have created it, right? ๐Ÿ˜„
                              Ok, I'm reading through that great Link John (very helpful to me as I try to wrap my head around Macs). 2/3 of the way down, in Table 1.3 it does explain the purpose of the Application Support folder:
                              Use this directory to store all app data files except those associated with the userโ€™s documents. For example, you might use this directory to store app-created data files, configuration files, templates, or other fixed or modifiable resources that are managed by the app. An app might use this directory to store a modifiable copy of resources contained initially in the appโ€™s bundle. A game might use this directory to store new levels purchased by the user and downloaded from a server.
                              All content in this directory should be placed in a custom subdirectory whose name is that of your appโ€™s bundle identifier or your company.
                                driven
                                I'll wait till your finished before I bite your head off...
                                  slbaumgartner
                                  On iOS, apps are quite strictly sandboxed. Each app gets its own virtual disk image and can't read or write anything outside that image.
                                  But in Mac OS X, this is not yet the case. An app can read and write anything for which the user has adequate permission anywhere on any drive. And, using shell scripting such as John has provided, a plugin can ultimately bypass the app's own API and rules to execute arbitrary UNIX commands.
                                  The sandboxing rules today on OS X only exist as conventions that developers are asked to respect (required to respect if their code is published via the App Store). But, as John has alluded, Apple is trying to beef up the sandboxing because so many apps spew files all over the disk and this makes it difficult or impossible to completely remove an app. Rumor is that the next edition ("Mavericks", expected in the Fall) will have some changes in this regard.
                                  So, whereas ~/Library/Application Support/<appnane>/... has been the conventional place for applications to save helper files, this could change.
                                  Based on all of this, it seems to me that the only place that simultaneously provides:
                                  • assured read and write permission for the user
                                  • logical/code consistency between Windows and Mac
                                  • support within SketchUp for readily finding the folder by a plugin
                                  is a plugin's own subfolder within whatever folder SketchUp is using to store user-added extensions. That is, when you tell SU to add an extension, SU itself chooses the appropriate folder ("Plugins" somewhere) and unzips your rbz file there. You have to have write permission in that folder, else SU couldn't install the extension. At that point your plugin code can query to find out where it was installed and can create more subfolders as well as write and read arbitrary files there. The plugin should not hard code any path such as "C:\Program Files\SketchUp\Plugins" or "~/Library/Application Support/SketchUp 2013/SketchUp/Plugins". It should use either Sketchup.find_support_file(...) or File.dirname(FILE) or something similar to get SU to reveal where the extension was loaded, and then use relative paths from there.
                                  That approach both allows arbitrary files to be written and read, but also will survive if SU is compelled to change the physical folder where extensions are stored because OS security rules were tightened.
                                  Steve
                                    I'm done John, you can start chewing ๐Ÿ˜†
                                      @Steve - Writing to a plugin's folder on Windows can fail though, so its not really a god solution for Windows. And up until 2013, it should have been equally likely to fail on Mac as well, because plugins were being written to /Library/Application Support, which is public, which requires admin rights. Only since 2013 have Plugins been written to ~/Library/Application Support/..., which is completely writeable by the current user.
                                      Also, we're not writing in iOS, so their extreme sandboxing isn't a concern here (yet?). It will be interesting to see what Maverick implements. But its hard enough to develop for backwards compatibility and current compatibility....forward speculative compatibility might be a little too speculative for my taste.
                                      PS - for the record, I have nothing to do with Macs and the decisions we make about how we handle the Mac files system, so don't let me ignorance scare you too much. They won't let me ruin SU on your Mac any time soon ๐Ÿ˜„
                                        slbaumgartner
                                        Chris - why would the write fail? It seems that if the user could install a plugin there, he should also be able to write a file there. I'm missing something about the real core of the problem...
                                        Yeah, /Library/Application Support really should be only for files installed along with the app itself that need to affect all users. User-installed extensions, etc, should have been in ~/Library/Application Support all along. Before anybody bites my head off, I know that there have been previous discussions here disparaging ~/Library, but I think they were and still are wrong. However, that does leave the question on a shared computer of where/how to install extensions that you want to affect all users' instances of SU.
                                        Yeah, I know SU isn't for iOS, just thought I'd throw that in as an example of how Apple's thought processes may be running. OS X is ultimately a wrapper around a full Unix system, and without losing all of the users (like John and I) who like to step behind the curtain now and then, there are limits on how far Apple can go.
                                        And don't worry - whatever you come up with to mess up SU on my Mac, I'll find a way to defeat it
                                        Steve
                                          driven
                                          For the record, SU could always use User Library and Steve and myself as well as many others have mostly done so...
                                          AS far as I'm aware @Last suggested User Library or at least didn't stop it. It was always the mis-matching that caused problems,.
                                          Progressbar.rb bought it to a head when yourself and others started linking to it and when it was in the 'other' folder your plugins would fail.
                                          Unfortunately the wrong solution was quickly established on SCF and Google 'then' followed suit.
                                          that my recollection, though flawed it my be...
                                          • fredo6F Offline
                                            On Mac, there seems to be difference between copying a file in a directory and creating the file or folder from within a program. This is a basic things for security. The problem users have with DEFPARAM_Dir folder is exactly that. Ruby cannot create it, but you can create it manually.
                                            What I am looking for is a safe place where Ruby can create folders and files.
                                            Now, if, as suggested by Chris, I use /Library/Application Support/ as the root, the question is whether the root should not be /Library/Application Support/Sketchup, so that all SU plugins could create their own subfolders there. This would be much cleaner than if I create my folder at /Library/Application Support/LibFredo6.
                                            My feeling is that this question should be taken seriously by the Sketchup application itself and supported from Ruby so that script writers don't have to bother.
                                            Final word: excuse my ignorance, but what is the subtle difference between /Library/Application Support/ and ~/Library/Application Support/
                                            Final word: excuse my ignorance, but what is the subtle difference between /Library/Application Support/ and ~/Library/Application Support/?
                                            • 2 / 6
