    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      tak2hata
      Hi,All.
      I update to v2.0.5.
      Include new language file for Spanish and Chinese.
      Thanks Oxer and Hebeijianke!
      Enjoy!
      by TAK2HATA
        meoa
        Preview shows fur on the selected face but after clicking make fur, quite a number of it go off the selected face. The ones on the face are also scattered unevenly unlike the preview.
        Is this what should happen or am i doing something wrong ?
        Ok, sketchup just crashed. I tried it again and it seems to be fine now. Fur stays on the faces. I stil don't know what happened before and the cause.
          tak2hata
          Hi,meoa.
          I need more information for your problem.
          I can not know what happened, too.
          Please upload your model and the picture of the fur setting and selected face.
          Thanks.
          by TAK2HATA
            meoa
            @tak2hata said:
            Hi,meoa.
            Thanks.
            Sorry tak2hata, it was my mistake.
            I deleted geometry in a component and for some reason it did not rescale or i may have moved the axes by mistake so the component size was far larger than the content(space when you edit the component). Thus, the make fur moved the components further away than the size of the content which explains why they were off the face.
            make fur on the rectangle's surface using the component beside it
              tak2hata
              @meoa said:
              @tak2hata said:
              Hi,meoa.
              Thanks.
              Hi,meoa.
              This problem is solved by yourself.
              by TAK2HATA
                menes
                Hello there,
                First thanks tak2hata for the wonderful plugin.
                I'm trying long time now to use this for create a nice Olive tree.
                While the plugin work perfectly for create the single element.
                I can not in any way create the proper effect randomizing the element using the "leaf" mode.
                any suggestion?
                thanks
                • srxS Offline
                  srx
                  Wonderful plugin. Here is Serbian translation. Just to feel the excitement of taking part in an international project 😄 .
                  fur_lang_srb.txt
                  www.saurus.rs
                    tak2hata
                    I upload to v2.0.6.
                    Include the language file for Serbian by SRX.Thanks!
                    Hi,menes.
                    I try it!
                    finished
                    component for leavs
                    Component for leaves lay along to X-Axis(RED) with litte slope.
                    And place it with large Z value of "direction" and "force" in fur dialog.
                    It make like this placement.
                    Thanks.
                    by TAK2HATA
                    • N Offline
                      nektares
                      i loved this plugin already, and now it´s even better! Arigato Gozaimasu Tak2Hata
                        menes
                        Thank you very much indeed! TAK2HATA
                        Will try and let you know
                          menes
                          Thanks TAK2HATA
                          You put me in the right way 😍 thank you!
                          My values were different
                          Main Detail
                          type : leaf top jitter :8
                          Density: 60.000 width jitter: 19
                          Max n. :60.000 stiffness jitter : 50
                          length :1 valid distance: 0,000
                          rootwidth : 0,200 direction (x): 0,000
                          stiffness : 1 direction (y): 0,000
                          divide :2 direction (z): 1
                          force (x):0
                          force (y):0,000
                          force (z):-30
                          now the only thing to try ,it's to avoid many leaves at the bottom of the branches and have more on the top.
                          • thkian92T Offline
                            thkian92
                            Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
                              mwm5053
                              Great plugin 👍 I updated to 2.0.6 but not getting sliders or realtime preview like video shows I get the older dialog style. I'm using latest SU8 Pro on Mac 10.7.5
                              2011 iMac
                              SU 2015 Pro, 2017 Make
                              V2 Twilight
                              macOS Sierra 10.12.5
                                tak2hata
                                Hi,Walt.
                                I will test it on Mac.
                                Please wait.
                                Thanks.
                                by TAK2HATA
                                  mwm5053
                                  2011 iMac
                                  V2 Twilight
                                    tak2hata
                                    Hi,Walt.
                                    I tested on mac.
                                    Screen shots here.
                                    files in plugin folder
                                    work fine on mac.
                                    I think the problem is folder.
                                    The webdialog lost the sight of "JS" folder or "CSS" folder.
                                    But I think no problem about the non-alphabetical character file names on mac.
                                    So please tell me your plugin folder.
                                    Thanks.
                                    by TAK2HATA
                                      mwm5053
                                      Path can be seen at bottom of screen shot.
                                      2011 iMac
                                      V2 Twilight
                                        tak2hata
                                        I think there is no problem.....
                                        The problem becomes the mystery.
                                        I will create test code for you.
                                        Please wait.
                                        by TAK2HATA
                                        • Z Offline
                                          Zacchia
                                          Hi tak2hata
                                          Many thanks for your wonderful plugin! See attached an idea, hope you can understand 😒 It is just an idea.
                                            tak2hata
                                            Hi,Walt.
                                            I create the test ruby for you.
                                            test ruby
                                            It shows the folders for fur and Test Slider on Webdialog.
                                            Select from menu bar.
                                            Plugins -> Fur Test For Walt
                                            It will show like this.
                                            Show like this
                                            Hi,Zacchia.
                                            I understand your idea.
                                            But It will add new many properties.
                                            They take long time.
                                            Wait for Fur v3.0.
                                            Now I must sleep soon for tomorrow.
                                            Thanks.
                                            by TAK2HATA
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 32
                                            • 33
                                            • 17 / 33
