    Hatches/surfaces from AutoCAD-dwg doesnt show in Sketchup.
    12 Posts 4 Posters 8.8k Views 4 Watching
      davidjohansson
      Is there a way to import dwg-drawings in to Sketchup that include hatches/surfaces?
      D
      • arail1A
        arail1
        Not as hatches.
        You can explode the hatch in AutoCAD and it will then Import as lines into SketchUp but not as a hatch.
          davidjohansson
          Do you know if there is a way to get the surfaces in to sketchup? I tried with AutoCAD surfaces instead of hatches but it didnt work either. I just get the boundary lines.
          • KrisidiousK
            Krisidious
            if you explode a hatch in autocad it should come into sketchup as vectored linework. I know of no other way to get a hatch into sketchup.
            By: Kristoff Rand
            • N
              numerobis
              If you only need the face and not the pattern, you can convert the hatches to regions and sketchup should import them as faces.
              They come in triangulated but you can use clean tools to merge them.
                davidjohansson
                Thanks for your help! How do i convert the hatches to regions?
                • N
                  numerobis
                  enter "region" or use the toolbar button. Then select the hatch object you like to convert.
                    davidjohansson
                    hmm it doesnt work? "0 Regions created."
                      davidjohansson
                      enter "Region" - enter. Select Hatch - enter?
                      • N
                        numerobis
                        ah, ok... it looks like it doesn't work with overlapping lines. You need a closed boundary.
                        So you would have to draw some polylines using "_boundary" first and then convert them to regions. And one other thing... regions can not have "holes". If there are openings/islands in the hatch they will produce a separate region and you will have to combine the two groups in sketchup...
                        So maybe it's faster to draw the faces directly in sketchup... πŸ˜‰
                        • N
                          numerobis
                          yes
                          • N
                            numerobis
                            ahh... now i see that you can produce a boundary as region using the "edit hatch" command - then you will get one object with holes that gets imported as one group in sketchup.
