Component Match Plugin possible?
Hi, John:
I saw your reply. I could not find anything in the [Plugins]Repository here. I thought TIG had done something along those lines. Seems that a script could be done to reassign a name to make each an instance of the main component. -
Simply select all the ones you want to replace, then in the component browser right click on the one you want to replace them with and select, Replace selected.
@mitcorb said:
Hi, John:
I saw your reply. I could not find anything in the [Plugins]Repository here. I thought TIG had done something along those lines. Seems that a script could be done to reassign a name to make each an instance of the main component.Thanks for the try.
If it's that simple I'm going to bang my head on my keyboard.!
I've replaced components before like this.
Going to give it a try.
Bang! Bang! Can't believe I was that stupid.
I can't believe I deleted and copied them all.
There were so many, I guess I went blank.
I was used to replacing one type of component for another (one for one)
Never thought to replace one for many.
Thanks for the help. -
good tip very helpful for some obj imports.
Well John, I'll see your
and raise you two more for me. (i gotta go back to school)
To be honest, that was my answer when I read your post before anyone had replied, but I thought it was too simple and I must have been reading your question wrong so I didn't suggest it.
I use this all the time. I draw a lot of things with many highly detailed components so I "construct" the drawing using simple versions of each. This way nothing slows down because of too much geometry etc, then when I'm ready I just replace the relevant ones. You do know you can "select instances" in the component browser and replace them all in a click. Also if they are all over the place with different names and hard to manually select you can select them via the outliner window then replace them from the component browser. Or if they are all on a separate layer..........I think you get my drift
The more I learn, the more I forget. I guess it's age.
Strange, I can go back to AutoCad, after a while and little by little everything starts coming back.
It seems I never retain much of the some rarely used features for long in SU.
It's always Duh! Duh! -
I was working on a plugin that would detect geometric similarities between groups/components and make them use the same definition. Unfortunately I've not gotten around to completing it.
Do you ever sleep??
Unfortunately, yes.
Experiment is here btw: http://sketchucation.com/forums/viewtopic.php?t=30143
Problem is that in order to make it work with nested groups/components I need to make some big refactoring.
