    Webdialogs for SketchUp ......RIP!
    55 Posts 15 Posters 7.6k Views 15 Watching
    • danielbowringD
      danielbowring
      @thomthom said:
      Yeah, I'm not finding any references of such a python framework - let alone just a framework in any language.
      And considering the advances of HTML5 and CSS3 - not only on the web but in apps on both mobile and win8 I don't see WebDialogs as a dead end. However, WebDialogs needs a cleanup and ship with a custom webcontrol independent from the OS and consistent across platforms.
      This whole thing after to rather be a UI concept, which would be limited to language.
      I think having the ruby<->js interactions done through XMLHTTPRequests would be great too, because then we know for certain it's asynchronous can can use existing frameworks to aid the communication.
        hmm... I can see times where async can be useful, but more often I want synchronous communication.
          Aerilius
          Sometimes I want a method to wait until a webdialog is closed to give a return value. But all tries so far have frozen SketchUp and then also the webdialog. (Example usage: unit tests or API methods that don't work with async Proc callbacks)
          WebDialogs are more cross-platform and scale better than SketchUp's own antique UI. Text fits on buttons. Following best practices makes them easily work with any dpi.
          • AdamBA
            AdamB
            Can you not just set a semaphore in the closure?
              Aerilius
              Do you have an example code snippet? When I search for a ruby semaphore, I find threads etc.
              • AdamBA
                AdamB
                actually, I don't think you even need atomic structures like semaphores.
                All I'm saying is that in your *on_close()*or add_action_callback() methods, just set a flag.
                So your (pseudo-) code is:
                dlg.show
                <wait until your flag has been set by the dialog callbacks>
                  Aerilius
                  I will experiment again, but as far as I remember the single thread of SketchUp's Ruby freezes so that either the flag can not be set (because it is busy waiting) or whatever I do to wait never gets time to notice the changed flag.
                  • danielbowringD
                    danielbowring
                    How often does it actually need to be synchronous though? That is, the code must be executed before the next line. Also, how often can that not be turned into a async form (callbacks, promises, ...)?
                    My main point is that predictability and expectations are important in API design. Also, the current implementation (window.location = ...) can have side effects - for example it will block/cancel any current requests, such as redirects or xhrs.
                      Oh - haven't noticed that yet! ...that should be in the Lost Manual... that's important stuff.
                      • I
                        ilay7k
                        I vote for python. I work with it in cinema4d; ironpython - revit, robur(road software). And small [highlight=#ff4040:1yirh56j]c[/highlight:1yirh56j][highlight=#4000ff:1yirh56j]ythoning[/highlight:1yirh56j] ๐Ÿค“
                        and it has 64bit framework or anyCPU type...if current sku team can not port ruby to x64.
                        • T
                          tomot
                          I forgive Dan, he was probably off his meds again, although you can always count on him to give you his undivided attention when one is looking for a problem that needs solving. ๐Ÿ˜„ I'm not talking about dumping Ruby.
                          You can see the Visual Programming, in the attached pic, the underlying Scripting is what makes the 3d surface appear, but its not something the user has to concern him or herself about. If you want to experiment you can replace a DIV module with a MULTI module and see the 3d result instantly, or replace TAN with a COS module, etc. etc.
                          In addition, Download a free copy of Houdini from http://www.sidefx.com/index.php
                          and you will see the same principles as grasshopper. Houdini calls it Procedural modeling, as opposed to Visual programming. The process is the same.
                          other examples of what grasshopper can do generating experimental Architecture. http://formularch.blogspot.ca/
                          my plugins
                          tomot
                            Well, yea. Procedural modelling is a mighty interesting topic. However, there is nothing preventing that being done with the current Ruby API and WebDialog we already have.
                            Procedural modelling can be implemented in whatever underlying scripting or programming language is available.
                            I'm all for procedural modelling and I'm mighty interested in whatever project jolran is plotting.
                            • jolranJ
                              jolran
                              Yet another Grasshopper framegrab...
                              One thing not discussed here regarding visual-flow-mombo-jumbo-programming is the complexity behind evaluating the chain of hierarchy, and when or what to update as soon as something changes in the gui.
                              I'm not sure Python would have any advantages over Ruby solving that computation..
                              But I guess that discussion is OT.
                              The GUI part is all very possible with webdialogs. In fact it's already happening ๐Ÿ˜‰
                                ๐ŸŽ‰
                                • jolranJ
                                  jolran
                                  What I've produced after months of work you or some of the others JS-nerds around here(you know who you are!) could probably have duddled together in a weekend or less, Thomthom ๐Ÿ’š
                                  Although the connector framework took some time to get acquainted with..
                                  • Dan RathbunD
                                    Dan Rathbun
                                    @tomot said:
                                    I forgive Dan, he was probably off his meds again, ...
                                    Or ON them. Sinus cold this past week!
                                    It's not feasible to have the app engine making two callbacks into 2 different scripting sub-processes.
                                    IN truth... I am so weary of waiting for the Ruby API to be fixed, that I no longer care what language it is.
                                    As long as it is fixed and kept updated.
                                    If it's not Ruby, it is more likely to be Javascript IMHO.
                                    I'm not here much anymore.
                                      Aerilius
                                      Javascript IMHO.
                                      Especially since such a partly implemented API already exists, and even a first plugin.
                                      Even if JS is not a beauty of a language, it's benefits are the wide-spread and the billions that have been invested into its speed optimization (although Python/Ruby&Co. have also benefited from such developments).
                                      For the original topic of this thread, neither webdialogs nor SketchUp's choice of scripting language matter. Node-based interfaces (previously mentioned as visual programming) are neither a replacement nor conflicting with webdialogs.
                                      • I
                                        ilay7k
                                        Interesting, why does ex-Asgvis use port of Ruby to Python and pyQt dialogs in vray for sketchup?
                                          They use such a bridge because they make V-Ray for SketchUp and V-Ray for Rhino share the same code-base so they can be developed in parallel.
                                          • DavidBoulderD
                                            DavidBoulder
                                            Interesting discussion. I work on OpenStudio which is a C++ SDK that includes a SketchUp plugin that uses ruby. We use tool called SWIG http://www.swig.org that gives us bindings to Ruby, Python, C# and potentially many other languages. Ruby is our most supported binding, but users are starting to use other bindings as well.
                                            David
                                            David Goldwasser
                                            OpenStudio Developer
                                            National Renewable Energy Laboratory
                                            • 1 / 3
