    [Plugin] zoom_selection.rb
    21 Posts 11 Posters 21.1k Views 11 Watching
    • H Offline
      hoangpi
      Thanks alot!
        rv1974
        It'd act as 'zoom extents' when nothing selected (a-la 3ds max)
        Jim could you expand this rb please?
          Jim
          This is what it does.
            rv1974
            Jim thanks for attention.
            I'm afraid it doesn't.
            What I mean is the ruby should:
            1. When nothing selected it'd zoom out (not zoom out by a factor of 2). It'd respect group\component extends while editing with the 'hide the rest of model' mode .
            2. With item selected it'd zoom to object (no complains it's already OK).
            3. It'd be 'two in one' command: one shortcut for 2 states (see p.1&2)
              Edit: If I already got you 😎 could you please-please-please add the scale tweaking to your Mover 2? I love this tool but random\exact\by axys scaling is really missing.
              Thank you in advance.
            • halroachH Offline
              halroach
              This plugin is a wonderful idea when I have an imported DWG with real far away geometry that I'd like to select "blindly" geometry that I cannot see. I've tried it though, placing a bunch of components at the 0,0,0 and one component far - 1000 meters away... I select the far away component and it just won't zoom on it... it kind of zooms to extents or something similar, cause if I zoom extents I get something else... ideas?
              FlexTools - Super Quick Windows, Doors, Slats...
                The native Zoom Extents is an interesting tool. If you use Zoom extents from the toolbar, it zooms to fit all of the model that is displayed. If you make a selection and use Zoom Extents from the Context menu, it zooms to the selection.
                Often, when I import a CAD file or open a SketchUp file from someone else, I hit Zoom Extents on the toolbar. If the camera zooms out so the obvious geometry is relatively small in the model space, I drag a right to left selection box around the apparently empty space making sure I don't get any of the model. Then I hit Delete and Zoom Extents again to see if I've removed the unneeded stuff.
                • halroachH Offline
                  halroach
                  That is exactly what I do. I zoom extents and select the geometry I can't see and delete it. I was hoping though that with this plugin I could zoom in to the selected geometry to see what it is that I am going to be deleting... but it just won't zoom...
                    So use Zoom Extents from the Context menu.
                    I used to have a Zoom Extents on a custom toolbar that Jim did that would zoom in to the selection. I'll see if I can find it.
                      Check this out.
                      There's a command for Center Selection which would probably get you started. On my PC I have his toolbar set up so Zoom Extents zooms to a selection if there is one.
                      • halroachH Offline
                        halroach
                        @dave r said:
                        Check this out.
                        The plugin from Jim's website (Is it the same Jim?) works!! It zooms to the selected item no matter how far or where it is.
                        The plugin can be found here:
                        https://sites.google.com/site/jimfoltz/my-sketchup-plugins/zoom-selection-extents
                        • 2 / 2
