    HDR import?
    6 Posts 3 Posters 536 Views 3 Watching
    • olisheaO Offline
      olishea
      Any way I can import a 32 bit HDR into SU as a texture or image? Or am I going to hit a brick wall?
      Any help would be much appreciated, even if to say it's not possible. πŸ‘
      oli
      • cottyC Offline
        cotty
        I think it is not possible, because you need the tonemapping for a correct view and this is not a part of SU.
        my SketchUp gallery
        • olisheaO Offline
          olishea
          hmm my head is tingling, I keep racking my brain to work it out. I also fear it's not possible. 😞
          oli
          • cottyC Offline
            cotty
            http://bit.ly/11w2wON 😎
            my SketchUp gallery
            • jolranJ Offline
              jolran
              Hi.
              If keeping the HDRI as a HDRI isen't a must. Then you could always convert it to 8bit in PS(gimp?) and save as JPEG for a smaller format.
              If you blur it you can get away with artifacts.
              After that, maybe map it to a sphere with face normals pointing inwards if it's for rendering.
              UV-layout may have to be done exteriorly or with a plugin I guess..
              Maybe you have already considered thoose possibilities.
              Just putting it out there if not....
              And I do reckon it's for making a Dome Γ½ou want too use the HDRI ?
              Good luck!
              • olisheaO Offline
                olishea
                I can not discuss the project, sorry. Yeah JPEG won't help me and I've already considered the ideas you mentioned, but thank you.
                oli
