    Music - which format is best?
    23 Posts 10 Posters 1.8k Views 10 Watching
    • Jean LemireJ Offline
      Jean Lemire
      Hi folks.
      A couple years ago I compared a music piece from Yello that I have on CD and in iTune, as a mp3 file.
      The mp3 file's dynamic cannot compare at all with the CD. I get deeper bass and better sound overall while using the CD.
      Of course, all this depends on your sound system. If you have a sub average sound system with ordinary speakers, you cannot probably hear much difference. Also, hearing changes with age. This must be factored in.
      Just ideas.
      • N Offline
        numerobis
        flac!
        http://wiki.hydrogenaudio.org/index.php?title=Lossless_comparison
        and for mp3... only with 320kb/s
        If you want to level your mp3's you can use mp3gain: http://mp3gain.sourceforge.net/
        http://lifehacker.com/230105/alpha-geek-whip-your-mp3-library-into-shape-part-i-+-level-the-volume
        • utilerU Offline
          utiler
          Thanks to you all; some great advice! I too prefer my CD's; always rather buy a CD than download.
          Just Curious...
          • N Offline
            numerobis
            Yes, it's still the best quality i think (excluding SACD and DVD-Audio...)
            And i really never understood, how someone can buy a 196kbps or 256kbps crap download on itunes or something else for almost the same money as a CD...
            • HieruH Offline
              Hieru
              When first looking at digital formats I did he same thing, but I could still hear the difference between mp3, WAV and lossless formats on an iPod and low quality hi-fi equipment. For that reason (and the fact that I mostly use high-end hi-fi) I download or convert to WAV where possible and then convert again to a lossless format for use on my iPod*.
              If WAV isn't available or you are concerned about storage (which is really cheap these days) then I agree with Numerobis - Flac is the way to go.
              *I still prefer my vinyl and CDs though πŸ˜„
              www.davidhier.co.uk
              • HieruH Offline
                Hieru
                That.......and kids who only listen to music playing out loud via their phone 😒. It's like choosing a broken down degraded VHS over Blue-ray!
                Then again, from the day I first got into good hi-fi I found that most people just cannot tell the difference between cheap stereos and audiophile quality equipment.
                www.davidhier.co.uk
                • utilerU Offline
                  utiler
                  Hieru, I think you said it best; I listened to a few albums that I have ripped to itunes that I have had for 15 years or so and yes they are considerably softer. I wonder how to get volumes similar to say a new CD? Maybe trial and error..
                  @numberobis - you mention 196 and 256kbps for itunes downloads; Can you explain what that means? I assume level of quality... πŸ‘
                  Just Curious...
                  • HieruH Offline
                    Hieru
                    I'm not sure that there is a way to control the levels. Besides which, when ripping from a CD I suspect that raising the output would screw with the sound quality and engineering.
                    Whilst the recordings are softer they also tend to cover a broader dynamic range. The simple solution is to adjust the volume during playback. The only time this becomes a problem is when listening on an MP3 player (they don't usually go loud enough for older/quality recordings). You can compensate with a portable headphone amp - which you should probably look at getting anyway.
                    www.davidhier.co.uk
                    • N Offline
                      numerobis
                      http://lifehacker.com/230105/alpha-geek-whip-your-mp3-library-into-shape-part-i-+-level-the-volume"
                      But store a copy of the original! It is meant not to affect the quality, but who knows...
                      yes sure, kbps, kb/s or kbit/s is the bitrate of the tracks, the level of compression. Uncompressed CD-audio material has 1411 kbit/s - so even the best mp3 quality is with 320kbit/s much worse. (You can get 640kbit/s with LAME encoder but this is not standart)
                      As far as i remember itunes (and others) only sold 160/192 kbit/s "low quality" files, even only 128kb/s earlier.
                      http://en.wikipedia.org/wiki/MP3
                      http://en.wikipedia.org/wiki/Compact_Disc_Digital_Audio
                      FLAC is also compressing the data stream, but in a lossless way.
                      http://en.wikipedia.org/wiki/FLAC
                      • HieruH Offline
                        Hieru
                        That's OK for Mp3, but is there an equivalent for lossless formats that doesn't mess up the way songs have been mixed/engineered?
                        www.davidhier.co.uk
                        • N Offline
                          numerobis
                          I think this could be done by ReplayGain
                          http://en.wikipedia.org/wiki/ReplayGain
                          but the player has to support it
                          • utilerU Offline
                            utiler
                            Ta, will take a look.... πŸ‘
                            Just Curious...
                            • michaliszissiouM Offline
                              michaliszissiou
                              Flac is the best compressed format you can have.
                              Still, PCM format sounds a bit better though. (wav, aiff, SD2, PCM etc )
                              Of course, a 24 96 or 192 sound format is much much better.
                              Being a mac user, indeed, iTunes under OSX is a superb playback device, but not the crap that itunes sells around.
                              And, yes, I have a very very expensive HI End system here. (still professionally mixing and mastering works of some friends)
                              Nothing to compare with the already mentioned setups on this forum.
                              BTW, indeed Pete, vinyl sounds great, if you have the appropriate hi end player and the original vinyls. Else, better not. A 24 96 format, using HiEnd equipment like A to D converters, phono stage (valve based-better) etc, can capture most of it on a digital format.
